Post new topic Reply to topic  [ 20 posts ]  Go to page 1, 2  Next
 Post subject: MOD - Lock Pass-Through
PostPosted: Thu Aug 18, 2005 4:56 pm
Here's one of the first mods that I did to my Ruckus when I first got it. Basically I wanted a nice clean way of getting my cable lock through the frame. So I decided to punch a hole through the plastic deck and put a grommet in there to get a nice clean look.
This is V1.0
What you'll need:
Hole grommets at least 3/4" preferably 1" or more, make sure your cable lock will clear it. $3.00 for three.
A hole saw drill attachment appropriate for the size grommet. $4.00.
A drill.
An exacto knife.
The stock plastic deck.
A hole grommet.
Drill a 1" hole through the deck. Make sure you know what's underneath the deck so you don't drill through anything important. Use an exacto knife to shave off loose bits of plastic.
Finished product.
Total time about 15 easy going minutes...
V2.0 improves upon V1.0 by enlarging the hole so that it's easier to work the cable lock in there. The grommet in V1.0 made for a tight fit. In V2.0 I used a plastic part that you can pick up in most hardware stores and is used to get cables trhough a desk.
What you'll need:
Exacto knife
Computer desk hole thingy...
PostPosted: Fri Sep 23, 2005 3:46 pm
Nice i made the same thing on mine like u "first mods"
Woorks realy nice :)
Science !!!!!!!!!!!!!!!!!! My Zoomer is a---a---a Camping machine
PostPosted: Sat Oct 01, 2005 7:45 pm
I have got to do this to mine.
:banger2:
PostPosted: Wed Sep 19, 2007 6:44 pm
I have yet to see this mod but it looks nice and clean, and COOL!
There is one quality that one must possess to win, and that is definiteness of purpose, the knowledge of what one wants, and a burning desire to possess it!
PostPosted: Wed Jul 09, 2008 9:41 pm
I run my cable through the holes, in the rim, of the front tire. Nobody is cutting through the tire or the rim and if they take it off, well, they won't get very far on one wheel.
I thought about running the cable around the frame but it wouldn't take long with just a simple hacksaw to slice right through and toss my scoot into the bed of a waiting pickup.
That's my $0.02
PostPosted: Wed Jul 09, 2008 10:02 pm
This is such a great phreaking idea!
Here in Hawaii, people usually steal scoots with pick up trucks, so they will leave behind a wheel and just 2 people toss it in the pickup truck. But with this, they can't! unless they take the time to unbolt, but people will definately see what's going on!!
PostPosted: Thu Jul 10, 2008 12:10 am
That's my $0.02
The rare double play
Here's how mines turned out, I did it about a month ago. I decided to go on the side so that I can give my U-lock a longer reach.
PostPosted: Sat Jul 12, 2008 12:05 am
Nice mod! Those rubber grommets come in handy and they are cheap. 8) Off to Lowe's..
PostPosted: Sat Jul 12, 2008 10:26 pm
i use a u lock also but i stick it through the wheel. to even if they manager to cut the cable the u lock prevents them from rolling the bike. if they want it bad enough they'll get it. but i might as well make it a pain in the ass for them.
the ride....no dip sticks allowed
and..........no dip sticks allowed, still
LilRedRidingHood wrote:
....It is like travelling through time.
PostPosted: Sun Jul 13, 2008 9:45 am
I made an update to my grommet pass through. I enlarged the hole to about 2-inches and used a rubber toilet washer that I found at OSH, $1.99.
Here's a crappy pic that I took of it in action while at work. Facing the key hole downward helps prevent access to drilling.
My Vethpa
Ruckless since 9-10-08
 Post subject: CHAIN LOCK OR U LOCK?
PostPosted: Tue Aug 26, 2008 11:39 am
I'm trying to determine if a U-lock is sufficienit enough or should I be getting a chain lock? And if I get a chain lock should I get one that's 5'? or is 3.5' enough? I was looking at buying the Onguard Beast lock but I'm not sure how long I need? What do you guys suggest?
 Post subject: Re: MOD - Lock Pass-Through
PostPosted: Wed Aug 27, 2008 9:10 pm
SpoonKiller wrote:
I don't use a lock often, but this just looks fucking cool.
I'm doin' it.
And you can't stop me!
Pedal the the Metal? Fuck that shit. Wrist to Full Twist. WOT
PostPosted: Sun Oct 05, 2008 12:52 pm
masterchp2 wrote:
I'm doin' it.
i was going to do the mod untill i notice that the hole where the coolent tank cap used to be was way easier then making another hole on the panel. its big enough to fit a fat chain or whatever lock you use. i just decided to use that hole since i replaced my coolent tank with the kijima one, and the hole was already there. just my 2 cents, only problem is its not as cool as spoonkillers.
PostPosted: Sun Feb 08, 2009 7:41 am
The next thing ill do to my scoot! :snorkel:
You did WHAT?! With WHO?! For HOW MANY COOKIES?!
My ruck viewtopic.php?f=93&t=50889
PostPosted: Sun Sep 27, 2009 10:23 pm
After seeing this page, I made one with a 2" black PVC pipe adapter.
