| Author |
Message |
heyjim89
 Posts: 132 Location: Charleston, SC Gender:
Post subject: Re: Chucksters! Downtown Charleston/Surrounding Area, SC Meetup Posted: Tue Mar 20, 2012 7:01 am |
Capt. Will wrote: heyjim89 wrote: Thanks, ride this weekend. tbd Definitely riding this weekend. The wife is going out of town with her sisters so I'm good all weekend long. We should do something awesome. Ride game. Also I have a bunch of jc racing jets too
_________________ My White '05 Ruckus Build
| Top |
Capt. Will
     Posts: 1392 Location: Chuck-Town, SC Gender:
Post subject: Re: Chucksters! Downtown Charleston/Surrounding Area, SC Meetup Posted: Tue Mar 20, 2012 7:59 am |
heyjim89 wrote: Capt. Will wrote: heyjim89 wrote: Thanks, ride this weekend. tbd Definitely riding this weekend. The wife is going out of town with her sisters so I'm good all weekend long. We should do something awesome. Ride game. Also I have a bunch of jc racing jets too For the stock carb?
_________________ MY RIDE Charleston SC Thread
CarolinaCon 08,09,10,11,12
| Top |
Capt. Will
Post subject: Re: Chucksters! Downtown Charleston/Surrounding Area, SC Meetup Posted: Thu Mar 22, 2012 6:40 pm |
Good PC20 Carb info http://totalruckus.com/phpBB3/viewtopic.php?f=11&t=20401midn12ght wrote: found this symptoms chart in my carb troubleshooting research...just thought i'd add it here as well.(some may not apply)
Carburetor Jetting Tricks
Bike Won't Start After a Crash
Pilot too lean Idle set too high Improper starting procedure Bike wants hot-start button (KTMs and 400Fs)
Bike Runs-On or Won't Idle Down When Throttle is Chopped
Idle set too high Air leak in intake or engine Pilot too rich (when bike is hot)
Bike Wont Start When Cold Temp Outside
Pilot jet too lean Air filter over-oiled Motor oil too thick for temperature
Bike Sputters / Wont Clean Out at High RPM
Main jet too rich Air filter over-oiled Spark plug has debris on electrode
Bike Coughs & Stalls in Slow Turns
Pilot jet too lean Idle set too low Valves set too tight Decompressor is set too tight, so turning the bars engages release slightly
Bike Hesitates or Bogs Over Deep Whoops or G-Outs
Float level too low Carb vent tubes blocked Main jet splash shield not installed Float level too high, gas is trapped in vent tunes (install T-vents)
Bike Starts But Wont Take Throttle Without Sputtering
Pilot jet too rich Water in fuel Debris in main jet
Bike Suddenly Starts Sputtering / Gas Flows from Vent Tubes
Stuck float check valve Debris in gas or carb
Bike Runs Hot / Feels Slow & Flat on Straights
Main jet too lean Fuel octane too low, causing detonation
Bike Coughs & Stalls When Throttle is Whacked Open
Needle too lean Slide cutaway too lean Pumper circuit blocked or too lean
| Top |
