Post new topic Reply to topic  [ 183 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 13  Next
 Post subject: Re: 50cc Ruckus getting fat and low
PostPosted: Mon Oct 10, 2011 7:57 pm
Got the fatty on, and need a mount that lines it up better though.... Moved the hub to the outside of the rim for better clearance and alignment.
Ruckupolitan Build
http://totalruckus.com/phpBB3/viewtopic.php?f=94&t=65880&p=1127911#p1127911
GY6 Ruckupolitan Build
http://totalruckus.com/phpBB3/viewtopic.php?f=94&t=69300
Ruckus Build --- Sold
viewtopic.php?f=94&t=61420
Last edited by lucasloveruckus on Mon Oct 10, 2011 8:10 pm, edited 1 time in total.
PostPosted: Mon Oct 10, 2011 7:59 pm
looks good but its still a little off ,but over all i like that wheel
project *Empty Pockets*
PostPosted: Mon Oct 10, 2011 8:01 pm
yeah it was way worse before (like 2 inches to the right) messing with the hub and spacing, just need a mount that will fix it from someone :D
Ruckupolitan Build
 Post subject: 50cc Ruckus getting fat and low
PostPosted: Mon Oct 10, 2011 8:11 pm
What size wheel u got on that bad boy
My build thread: viewtopic.php?f=92&t=60201&start=0
PostPosted: Mon Oct 10, 2011 8:12 pm
squeezed a 12x7 on there :D
Ruckupolitan Build
PostPosted: Mon Oct 10, 2011 8:19 pm
Dammmmmmmmm will it be safe to ride with an incorrect offset on your mount? Haha
PostPosted: Mon Oct 10, 2011 8:30 pm
Should be fine, Ive considered doing it with mine.. This is how all those Jap bikes get away with going 12x7, they run the wheel on the inside of the hub
Btw lucas, looks good so far but needs moar low :wink:
OFFICIAL PC Crazzies Street Team Member
Elite SR50 slammed with GET Powurr <CLICKY
That new new '13 Metropolitan <CLICKY
PostPosted: Mon Oct 10, 2011 8:35 pm
Sweet !
Edit: I was talking about the wheel not being centered, I just now realized the hub haha
PostPosted: Mon Oct 10, 2011 9:13 pm
thanks man! haha i have to get my engine tucked up higher with a different mount and then i can drop it more :) my header gets way to close to the ground when i go any lower!
and im thinking the sameeee thing!! haha :highfive:
Ruckupolitan Build
PostPosted: Mon Oct 10, 2011 9:16 pm
and moving my hub to the other side of the rim actually brought my rim really close to my swingarm and it will make it way stronger because it will create less leverage on my axle! :mrgreen:
Ruckupolitan Build
PostPosted: Mon Oct 10, 2011 9:19 pm
If you or someone you know can weld check out BrandonRyan's Lego Mount, they less than 100$ and come with everything you need to stretch and offset the engine, it just comes in pre-cut pieces so all you do is weld it together! Im using one on Met
PostPosted: Mon Oct 10, 2011 10:33 pm
thanks man! I messaged him about it.
and btw your slammed met is one of the best ones i have ever seen! :banger:
Ruckupolitan Build
PostPosted: Mon Oct 10, 2011 11:14 pm
We will both be rocking the br mount in ks lol but u got the 12 and speed womp womp gotta let me keep up
PostPosted: Mon Oct 10, 2011 11:20 pm
haha is yours riding yet? if so lets cruise before it gets cold! haha
Ruckupolitan Build
PostPosted: Mon Oct 10, 2011 11:54 pm
Almost I need to hit up auto zone to get longer fuel line
