Post new topic Reply to topic  [ 9 posts ]
 Post subject: rebuilt big bore ????
PostPosted: Sun Sep 04, 2011 7:13 am
ok so JC rebuilt TC old big bore motor for me and I can only seem to get it to run
after i jump the crap out of it and get it warm .And if im not near a pair of cables im stuck ....
is this normal? everything is new except for the carb. ...also when i do get it jumped it will race and the only thing that will slow the motor is the air/mix screw on the pc20. how can i get this thing to run on the first try..
viewtopic.php?f=94&t=40212&p=1024810#p1024810
 Post subject: Re: rebuilt big bore ????
PostPosted: Sun Sep 04, 2011 6:42 pm
No, problems don't seem to be a new thing with the GET big bore IMO.
PostPosted: Mon Sep 05, 2011 10:18 am
haha yeah but its all back together and powder coated looks good parked :)
adjusted the needle to the richest postion last night and seemed to respond to that a bit.
ive read so many problems with the pc20 carb!! anyone with pe20 on a get bigbore?? Noticed as soon as i got it halfway running right ,id hit the thottle and it would go racing woundering if thats a sign of a air leak.
anyways picked up a jump box today hope that helps for now ...
PostPosted: Tue Sep 06, 2011 8:51 am
ok so i added a aftermarket fuel pump in a pinch one night and i think its causing too much flow ...
gonna try and restrict the flow
TR's Mad Scientist!
TR's Mad Scientist!
PostPosted: Tue Sep 06, 2011 11:13 am
I got a PC20 and a bigbore. No, I did not have the same problems you are describing. I think you're on the right track with tuning the air/fuel mix.
You got 2 hours and a 6-pack?
Then take a seat, turn on some music, and learn about the Ruckus:
Humanimal
PostPosted: Tue Sep 06, 2011 12:32 pm
why don't you lower your idle on the carb?
tuners tune on las tunas
http://blog.kiwi2elite.com/
PostPosted: Tue Sep 06, 2011 6:41 pm
:D
PostPosted: Thu Sep 22, 2011 2:31 pm
new oem pump ordered .
motor takes 15mins to turn over and only fires up if i disconnect the fuel hose .
PostPosted: Fri Sep 23, 2011 3:03 pm
all fuel pumps are not created equal .
installed stock pump and started without jumpbox!
well see what happens when i get cold.
man i hope thats it
