Post new topic Reply to topic  [ 816 posts ]  Go to page Previous  1 ... 50, 51, 52, 53, 54, 55  Next
 Post subject: Re: Version2.0's---- The Darkness
PostPosted: Fri Mar 10, 2017 11:40 am
LOL, no kidding. My ruck is down for maintenance (oil, gear oil, coolant, weights, belt, filter) before I can ride again.
BR has a rear flat as well :headbashing:
I've been on the bus for a while *sigh*
• DevilRuck
• Big Ruck
® Ruckémon!
PostPosted: Fri Mar 10, 2017 12:11 pm
I'm hoping to get some stuff done this weekend... we'll see how that goes.
PostPosted: Fri Mar 10, 2017 12:56 pm
PostPosted: Sun Mar 12, 2017 1:45 pm
Hey, this thread has been too long with no pics!!!
Got a little further in my Veypor gauge install today...
I initially made this piece that would go between the handle bar clamp at the stem...
But it really wasn't rigid enough for my taste. So I cut a similar template out of some 1/16" sheet metal... Leaving the base longer so I could bend it to match the profile of the bar and stem combo.
Next I laid down the stem cap and figured out where to drill the bottom holes...
Next, I grabbed a big C clamp, a block of wood and a 21mm socket and started the bend. I figured that I could get a good start, and then make the rest of the bend when I tightened everything down.
This allowed me to see where to drill the top holes. Did that, and then just reefed on the bolts until the bend was complete, and everything was good.
I'll be doing it all over, because when I reefed the bolts, it sheared to bottom bolt holes out. It's still much more rigid than the fiberglass version, but I can't have those imperfections, even if no one can see them.
Plus the big hole for the wires in a little off. I drilled small holes all the way around, then used a carbide bit to finish it off, and I probably should have held the piece in a vise instead of holding it with my hands. Hahahaha.
Plus I'll need to paint it.
Next I need to work on installing the speed sensor and JB welding on the magnet and setting up the Vapor.
I am going to dedicate no less that one hour after work everyday trying to get this thing road worthy again. :banger:
PostPosted: Sun Mar 12, 2017 1:49 pm
I love the build!! :highfive:
Instagram:@mathieuroberge
#matRrucks
____________________
PostPosted: Tue Mar 14, 2017 1:24 pm
PostPosted: Tue Mar 14, 2017 8:23 pm
2007 Ruckus - SharpieRuck
PostPosted: Tue Mar 14, 2017 10:31 pm
:popcorn: im glad to hear this, how did today go?
my left nuts
FatKid87 wrote:
No one wants to see your mascape except maybe ray
PostPosted: Tue Mar 14, 2017 10:44 pm
:popcorn: :popcorn: :highfive:
PostPosted: Tue Mar 14, 2017 11:26 pm
y
Today totally sucked at work, heavy line work agin, plus- ended up staying 1/2 hr late helping customers.
Got home and collapsed on couch. Hope to work tomorrow.
PostPosted: Tue Mar 14, 2017 11:28 pm
Consult the oracle buddy.
PostPosted: Tue Mar 14, 2017 11:31 pm
:beers:
my left nuts
PostPosted: Tue Mar 14, 2017 11:34 pm
:beers:
UH HUH
PostPosted: Wed Mar 15, 2017 12:46 am
Oh yeah.
PostPosted: Sat Mar 25, 2017 12:13 pm
Yes!!!!!!! The sun is out!!!! I can finally paint!!!
Also working on a new Veypor mount today. I need to redo the whole template because the bars and stem I was using are not the same dimensions as the bars I have installed on the bike. :pissed: Oh well.
Gonna need To get as much done as I can this weekend because Spring Scoot is next weekend. Gotta be able to make that ride!
