 Post subject: New paint and pinstripes Updated PICS page 2 9/16/17
PostPosted: Fri Jul 01, 2016 11:17 am
Hey TR just joined a few weeks ago as I picked up my first ruckus. Wanted used since I was going to mod it to hell!
Found a 2013 with less than 2k miles on it and grabbed it. Plus it had some mods to start!
NEW PICS PAGE 2
Starting point May 2016:
Welded stretch kit
Lowered seat frame
Chopped turn signal ears front and rear
Tucked stock tail lamp
12" front wheel from Vento Scooter
Vento front forks
Vento stock Disc Brake front
12x7 ITP steel wheel with hub in rear
Polini variator with rollers
Pod filters
K&N intake
Briggs Exhaust
NCY Cdi
Jetted
December 2016- September 2017:
Wire Tuck harness front half
Tucked throttle/brake cables 85"/91"
Origin8 Handlebars
Hussefelt BMX stem
PWJDM stem shim kit
Front Frame cover (member shiba99!)
FLP Frame Splitter
Stainless Tank Cover
Mojo R6 LED tail light
Swapped to Black seat
Painted and pinstriped frame and plastics
 Post subject: Re: 1st time Ruck owner lets mod!
1st Pics:
Imageimage by Dante, on Flickr
ImageUntitled by Dante, on Flickr
Added New Dr. Pulley 5.5g Sliders:
PostPosted: Fri Jul 01, 2016 11:20 am
So first round of mods came in and I switched out the rollers for Dr. Pulley 5.5g sliders and added some PWJDM pegs.
I also realized the front forks were mounted backwards so I flipped them around and dipped the ugly mustard yellow front wheel Anthracite metallic.
PostPosted: Mon Nov 21, 2016 9:26 am
dipped the battery box a color shift:
PostPosted: Tue Nov 22, 2016 1:23 pm
I love the purp!
PostPosted: Mon Mar 06, 2017 2:30 pm
Been working on things on the get!
So far installed a new stem, bars and Password stem shim kit.
Extended all wires and picked up a front frame cover to do a wire tuck!
Also scored a yoshi TRC with brand new chimera header(need to have a hanger made)
PostPosted: Mon Mar 13, 2017 1:21 pm
Sweet.. welcome to the t/r club!
Ruck-U, Minnesota Chapter
HRGC Racing
Instagram: greyduckcustoms
Duckwing and keygaurd guy
PostPosted: Sun Jun 11, 2017 4:21 am
so some updates!
Painted the front frame gloss black, installed a frame cover from TR member shiba99! and painted the rear frame, seat frame, battery box, tank cover(color is a surprise!)
I chopped the springs a few coils in the front (running gy6 front end) to bring it down somewhat and look more level.
Since I am tucking the cables I need to order a new throttle and rear brake so I can hide them!
Just ordered a new battery from batterystuff(search on TR rocks!) and found a killer deal local on a battery tender junior so will go pick that up too!
Mine came with the red seat but I am trading a local for his black one as it will tie in my new color scheme better! I promise pics to come from my camera!!
look me up on IG @boostedfury since some teasers have been thrown there :)
PostPosted: Sun Jun 11, 2017 11:59 am
Good progress. Did you paint the front frame with it attached or did you take everything off?
PostPosted: Mon Jun 12, 2017 5:03 am
i separated the frame from back half and then primed it and painted it(just bagged and taped up the battery tray and ecu)! Its not perfect but will work until i tear down again for black powdercoat!
PostPosted: Mon Jun 12, 2017 5:05 am
small update! Finally made time to swap seats with my buddy! He's building a red and black themed ruck and wanted my red seat, and I wanted a black for a cleaner look!
Next need to decide on what tail light, probably a cheapie R6 since I need a tonnnn of other parts still.
PostPosted: Mon Jun 12, 2017 7:30 am
pix or it didn't happen!! :wasted:
PostPosted: Sat Jul 01, 2017 5:47 am
Hey guys need some help! When I turn the key to ON I pop the red 10amp fuse. I have searched to see if any wires are shorted and the only thing I have found is the resistor that connects to the ecu bracket has one wire cut.
Also tail light was disconnected when I tested.
Do you guys think it's the resistor causing it to pop?!
PostPosted: Wed Jul 12, 2017 10:19 am
More than likely something is grounding out. Trace your wiring and fix the resistor while you're at it. The wire simply being "cut" only impacts continuity in the circuit, it doesn't magically fry fuses.
Snow Speeder
Slave I
PostPosted: Fri Jul 14, 2017 12:20 pm
So found out bullet turn signal connectors won't fully seated, this happens when you rush things...rookie mistake.
Hooked up the tender junior and installed new battery all good.
Now electric start button seems dodgy so probably will throw a new push button start on.
My extended cables came in and started to run them through the frame.
Next up is drill some holes on inner frame so I can mount the harness and cables next to gas tank.
Pictures are coming!!
