Post new topic Reply to topic  [ 46 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: Rowed-Express-SR
PostPosted: Fri Feb 12, 2016 4:39 pm
Ive been a member here for a while now and I've probably spend a couple hundred hours just reading peoples builds. In the past couple of months I started posting on peoples builds and asking questions and now its final time that I start my own build... Its something that hasn't been done yet... I don't think but its something that I wanted to do for a while.
** The back story. After probably 6 months of dating this girl my buddy crashed my SV650 while my girlfriend and I were watching... It was pretty bad and the outcome was that I wasn't allowed to have a big bike again... Anyways I picked up my first scooter which was a honda spree. A couple weeks later I picked up a 1982 Honda Express SR for the lady. Over the last year and a half I have probably gone through 15-20 2 stroke scooters buying and selling. This past October I picked up my first metropolitan and loved the thing. I am done with 2 Strokes!! Anyways I ended up getting another Met for the lady. a 2009 with 1,200 miles however she still wont let me get rid of her Express SR. The thing is a piece... I would have to kick it 30-40 times to start it. I cleaned the carb and then it had other issues... I'm at the point where I want her to have the luxury of having a 4 stroke so i bought a GET...
Here is how the bike sat this morning....
Notice all the boxes in the background.. motors for this one and another build I will be starting soon....
I dropped the motor out of it...
I think that I will try and get the ECU and all the electronics in this area
Trying to decided where we want the engine... Probably going to get engine mounts welded this weekend...
I am struggling with how to mock up a motor mount any advice would be helpful! Or anything to be cautious of. I am a little bit worried with wiring any advice would be awesome! Thanks in advance.
GET-Express-SR
Marks-Met
 Post subject: Re: Rowed-Express-SR
PostPosted: Fri Feb 12, 2016 6:13 pm
That looks awesome! And in great shape too :banger:
my left nuts
Jedi wrote:
pics of wife? :meh:
PostPosted: Sat Feb 13, 2016 6:37 am
I am thinking this is my idea for the engine mount. Any input would be helpful!
Not sure where to put the shock mount either. Any advice? I thought about putting it back to where the engine was bolting on but not sure if that's a good idea.
GET-Express-SR
Marks-Met
PostPosted: Sat Feb 13, 2016 10:21 am
It looks like we are both at the same spot with our express, and I am the last person that should give any kind of mechanical advice. But, I just posted a pic of the mount Im working on in my loose nut thread.maybe we can help each other out? Take a look.
:beers:
my left nuts
Jedi wrote:
pics of wife? :meh:
PostPosted: Mon Feb 15, 2016 3:00 pm
That thing is sweet looking! :banger:
PostPosted: Mon Feb 15, 2016 5:23 pm
PostPosted: Mon Feb 15, 2016 10:31 pm
Maybe take some pics with the side fairings and floorboard thing off? Better view of your frame? :meh:
my left nuts
Jedi wrote:
pics of wife? :meh:
PostPosted: Tue Feb 16, 2016 12:15 pm
loving this build! my first scoot was an express sr :banger:
Met Build
PostPosted: Wed Feb 17, 2016 4:29 am
So just got my bike back from my welder guy! I am pretty excited1 The only thing that I really don't like is the fact that all I had sitting around was a POS Chinese shock. When my guy did the set up to make it not bottom out he had to put an extension in place...
Because of the shock being crap the tail-end sticks up a ton! I looked around my old stuff and found another shock that I just started messing with...
I Love the new height at which it sits except the issue now is that it bottoms out with like 30 pounds on it.... I need advice! What rear shock still has a narrower look/old school look and is really heavy duty and wont give much? I have no idea what to put on!
One of my buddies has a FOX snowmobile shock on his and it looks sweet but it doesn't fit the build I am going for!
GET-Express-SR
Marks-Met
PostPosted: Wed Feb 17, 2016 9:44 am
Look at the kitaco. Its even blue.
http://www.jiangwayne.com/scooter/p_i.php?i=427
my left nuts
Jedi wrote:
pics of wife? :meh:
PostPosted: Wed Feb 17, 2016 10:11 am
I've looked at it. Seems a little short and I don't know how firm it would be... The blacks hock is 340 so I am guessing I'll Need something close to that. And I don't want hardly any give...
GET-Express-SR
Marks-Met
PostPosted: Wed Feb 17, 2016 12:10 pm
Hardtail?
Click This For My Ride !
rrpotd
:vondutch: :wavehello
P-Dub wrote:
.......daaaayaaaaaammmm.....
PostPosted: Wed Feb 17, 2016 6:29 pm
be careful running a shock at that angle
if its a thin shock you can bend the shaft
even think of doing a center shock?
pretty easy to make a mount for that engine and then you can use a stiffer ruckus or grom shock
I think those may use the 1000lb spring rate
where a typical aftermarket ruck shock uses 500lb spring rate
I may be off on the rates you would need to look that up
if you look up my sig line I used a ruckus engine and made basically a center shock mount
but my mount holds up my seat
so copy that mount but add a shock tab to it then do a shock tab to your frame somewhere
or just weld a shock tab in the same location they made your lower mount
but weld it onto the tube so it looks cleaner
PostPosted: Wed Feb 17, 2016 11:01 pm
the shock needs to be more vertical
PostPosted: Thu Feb 18, 2016 10:17 am
I think I am a little bit confused by this... If you could expand or draw what you mean that would be awesome!
I am so lost at what I should do for a rear shock!
GET-Express-SR
Marks-Met
Rucksters browsing this forum: Tanuki and 2 guests
