Post new topic Reply to topic  [ 135 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9  Next
 Post subject: Re: Peacock88´s Norwegian fatty zoomer!!
PostPosted: Wed Apr 06, 2016 8:03 pm
Thanks guys!! Its starting to come together now. Finished lengthening the harness so I could mount up all the electric stuff.
Some stuff left to do though.
- Finishing the rear fender/bracket for it.
- Mounting up the front when I get my wheel back from the tire guy. I had to flip it around because the filler valve would hit the caliper.
- Paint the back of the battery box
- Paint the rear fender
- Mount and bleed brakes. That´s going to be fun for a first timer...
- Mount the floorboard when I get bolts
Made a template to cut my floorboard after.
Cutting out the hole for the cap on the tank
It came out nice. Put some rubber trim around the edges to set it off. Its 5mm 5 bars alu plate.
Wired up my shiny new Koso speedo!
Got my taillight to function correctly after several hours of trial and error. Now I have brake light on both levers so thats nice!
Wired up a plate light also
Did a super quick buff on the controls. Going to get new buttons since they are worn.
Could have done it better but I want to finish things now and get on with it.
My Builds:
https://goo.gl/j7UWiv
https://goo.gl/crJD5Y
Oslo Zoomer Garage Instagram:
https://goo.gl/1gkUxO
PostPosted: Thu Apr 07, 2016 4:58 am
Looking great! Really like that tank cover. Good work :banger:
Retired GET 49
New Build GET 66.6
Ruck n Rola wrote:
I give little to no fucks when I park my ruck.
chucktuna wrote:
Tell him to drop the butt hurt and log on again.
PostPosted: Thu Apr 07, 2016 11:27 am
Thanks!! Can´t wait to ride!
Ørjan.
My Builds:
PostPosted: Wed Apr 13, 2016 4:47 pm
Got my sticker on the headlight
Some pics of the rear fender. It´s a CBR600RR that I have modded a little bit. I have cut the sides and heated the sides up and bent them down to fit the 8" wheel. I made a bracket that attaches to the top mount of the exhaust.
I stiffened it up a bit with 2mm carbon plate since it only attaches at the back. I may make a mount on the side that attaches to the lower rear dampener mount.
Got some split braided sleeves to put over the harness where it shows.
Cables
Mounted up my custom floorboard with some flushmount bolts. Added a strip of rubber trim on the sides.
Got matching bolts for the frames. The old ones looked like shit
and the rear damper bolt
Will have a cover printed for the gas tank cap to stop some water getting in and under the floorboard on top of the tank.
Finally got my wheel to get it flipped so it should arrive soon so I can start with bleeding the brakes.
Ørjan.
My Builds:
PostPosted: Wed Apr 13, 2016 6:24 pm
Wow was jus thinking of making my own gas tank cover for my build
Looked around TR to see if I can get any input/inspiration and stumbled upon your AWESOME build :highfive:
Great lookin bike man ! :banger:
Now u inspired me to make an underseat cover along with the gas tank cover as well ! :wasted:
MY BUILD!
viewtopic.php?f=92&t=97801&p=1639984#p1639984
PostPosted: Thu Apr 14, 2016 6:34 am
Thanks! Nothing better than to inspire others to build!
Ørjan
My Builds:
PostPosted: Thu Apr 14, 2016 11:08 am
Like the custom diamond plate cover and the electronic gauge, good job!
My Old Scooter
Current Ride
Greeley Scooter and Bike-R.I.P.
PostPosted: Fri Apr 15, 2016 3:45 pm
Thanks!
Ørjan.
My Builds:
PostPosted: Fri Apr 15, 2016 3:58 pm
Finally had the time to do a respray on the back of the battery box and the seat frame.
Came out decent. I will probably do a polish when the bike is finished.
From the back
Mounted up the refurbished stock shortened blinkers. I made a bracket for them so they mount on the same bolt as the frame around the headlights. I know its not to everyones taste, but I think its the signature of the zoomer. If I get bored with them I can always remove them.
Also got this custom 32" brake line from Raymond at Apex brakes. Top quality. Swivel ends for as much adjustment as possible.
I also finished the rear fender. It looks a bit weird in the photos but I promise it don´t stick out as much as the pic shows.
Any tips for bleeding the brakes is appreciated!
Ørjan.
My Builds:
PostPosted: Fri Apr 15, 2016 4:08 pm
For bleeding brakes... Does your school have a hand held or shop-air powered vacuum tool?
If so....get a small piece of vacuum line, open the bleeder on the caliper and put the line on the nipple- the other end in a bottle of brake fluid- the end as deep as it will go so you don't accidentally get air in and have to start over.
Now open the bleeder screw on the master cylinder. Hook the vacuum tool to the nipple. Hold lever halfway in.... Start sucking. Keep an eye on the fluid level in the bottle...
Once you see just fluid and no air is coming out, close the caliper bleeder first, then the master.
Squeeze lever about 10 times fully, and you should have good brake feel on the lever.
Good luck!
PostPosted: Fri Apr 15, 2016 4:54 pm
I don´t think they have that.. Thanks for the tip though. I got another tip to fill from the bottom with a syringe. So maybe I will try that.
Ørjan.
My Builds:
PostPosted: Fri Apr 15, 2016 5:51 pm
Ørjan.
That also will work. Just remember to hold the lever halfway closed while doing so.
PostPosted: Fri Apr 15, 2016 6:51 pm
Wat r u using to space the cover from tank ?
A nut under the cover on the long Allen bolt to keep it seperated?
MY BUILD!
PostPosted: Fri Apr 15, 2016 7:23 pm
This is pretty tits love the homade shit
LiteW8 wrote:
PostPosted: Sat Apr 16, 2016 7:12 am
In the back I use a 70mm long bolt, and in the front a 35mm long bolt. Its held in place with a half nut like you see in the pic.
Thanks!!
Ørjan.
My Builds:
