Post new topic Reply to topic  [ 266 posts ]  Go to page Previous  1 ... 11, 12, 13, 14, 15, 16, 17, 18  Next
 Post subject: Re: 2007 Checkered Met Transformation
PostPosted: Tue Dec 20, 2016 10:08 pm
Yea... It wasn't an easy decision. Hard to stay GET when the folks around you all are swapped and Groms.
FatKid87 wrote:
Toaneezy wrote:
Scoot mail is in! Decided to make the jump into the darkside :twisted:
Sad day
DarkSideMETrod Build
viewtopic.php?f=95&t=95633
PostPosted: Thu Dec 29, 2016 12:09 am
Getting some work done. Gonna stick with the stock CVT. Cut out the clutch area to allow more air to flow through. Still need to clean up the edges.
PostPosted: Thu Dec 29, 2016 12:14 am
Picked up a Dr. Pulley variator and Ban Jing clutch bell.
PostPosted: Fri Jan 06, 2017 10:37 pm
Toaneezy wrote:
The new front conversion fully setup. Was bitch trying to figure what direction I wanted to go with this. Really stoked how it came out tho
Really digging this build. I too am in the process of going GY6 so I'm gonna follow you closely haha.
Quick question.....what bracket are you using for that speedo cable?? Thanks.
My build
http://totalruckus.com/phpBB3/viewtopic.php?f=92&t=96096
PostPosted: Sat Jan 07, 2017 7:43 pm
Thanks bro. :highfive:
Are you talking about the bracket that is holding the sensor for the speedo cable? If so, it came with with my koso speedo. Probably can buy off of Ebay.
If you're talking about the cable guide that on Ebay. It's called "Front Cable Guide for Yamaha Honda Suzuki Kawasaki Ninja BWS Bracket -Silver". Here's the link http://www.ebay.com/sch/sis.html?_nkw=N ... 2749.l2658. It's really cheap and made of metal.
Maybe I see you on the islands. I frequent there often. Got some ohana off of the Pali hwy. :banger:
PostPosted: Sat Jan 14, 2017 8:50 pm
Had some time this week to finally get this motor mounted. The biggest hurdle was using my current stretch, centering the rear wheel, and avoid the head of the motor from sagging.
PostPosted: Sat Jan 14, 2017 8:53 pm
Did a lot of grinding and shaving to at least get the stretch to accept the motor, but after three days I got it mounted.
PostPosted: Sat Jan 14, 2017 8:56 pm
Sweet! :popcorn:
PostPosted: Sat Jan 14, 2017 9:01 pm
Ran into an issue of the lowdown NCY shock not aligning with the rear mount point due to the angle. Had to shave the inside of the shock to fix the issue. After a few adjustment to the height of the shock this was the result bottom is how I started off, top pic now with minimal head sag. Stoked how it came out. More than likely I'll have to cut into the bin to fit the carb.
PostPosted: Sat Jan 14, 2017 9:05 pm
Definitely looks better, don't see many gy6 mets that I can recall :banger:
PostPosted: Sat Jan 14, 2017 9:10 pm
Right on :highfive:
Yeah... I've seen a white Met on #themetlove IG that had a swap that was pretty rad, but still had the head of the motor drooping down. My mission was to minimize that. Next week I'm gonna tackle the wiring. :banger:
PostPosted: Fri Jan 20, 2017 5:46 pm
JDM goodies.
PostPosted: Fri Jan 20, 2017 5:50 pm
Wiring the OEM harness with the GY6 motor. OEM fuel pump and ECU is the only way to go :banger:
I love wiring said no one ever :headbashing:
PostPosted: Fri Jan 27, 2017 11:17 pm
Im glad you got to keeps the wheels :banger:
my left nuts
FatKid87 wrote:
No one wants to see your mascape except maybe ray
PostPosted: Fri Jan 27, 2017 11:33 pm
Sickness! :banger:
