Post new topic Reply to topic  [ 343 posts ]  Go to page Previous  1 ... 17, 18, 19, 20, 21, 22, 23  Next
 Post subject: Re: Tanuki's balls
PostPosted: Thu Jul 28, 2016 11:44 am
let sam breathe!
I don't know what that means.
PostPosted: Fri Jul 29, 2016 10:58 am
Jedi wrote:
let sam breathe!
Today's :popcorn: , you were right, let Sam breathe!! :monkeydance :banana
fuck.
PostPosted: Fri Jul 29, 2016 4:26 pm
One eyed monster finally arrived
King Ghidorah
JamesDean wrote:
PostPosted: Fri Jul 29, 2016 7:58 pm
Header pipe starts same as met, bigger then ruck
1st obstacle, dip stick needs be decapitated.
2nd obstacle, worfab rad scoop. Can i make spacers and use longer bolts for the hanger? Or do i have to remove scoop? :headbashing:
King Ghidorah
PostPosted: Fri Jul 29, 2016 9:18 pm
Nicely put a triangular dent in the center of the scoop?
:popcorn: ω
fuck.
PostPosted: Tue Aug 02, 2016 10:36 am
Hows a mutha tune with his tachs all fukd? Couple days ago I tuned the idle and both tach were working. Yesterday I was going to start mj tuning but now the tachs are all screwd up. Going to look at those resistors and stuff i had read about. Did the chalk line measurement for tire size and that checks out with gps. So far my new set up is vapor, jc20 at 38,82(to start at)and the quiet hotlap pipe.
King Ghidorah
PostPosted: Tue Aug 02, 2016 11:34 am
That pipe is so sex! :highfive:
fuck.
PostPosted: Wed Aug 03, 2016 7:49 pm
That IS nice! Haven't seen it before -- is it actually quiet[ish]??
(and if so -- where'dja get it? :mrgreen: )
PostPosted: Wed Aug 03, 2016 11:16 pm
P-Doob, its quiet. It reminded me how loud my cvt is. But with is version you cant remove the silencer. I got it from minimoto. :canuck:
http://www.minimotolab.com/product/hotl ... t-exhaust/
King Ghidorah
PostPosted: Wed Aug 03, 2016 11:44 pm
And don't ask for a sticker! :canuck: too tight
fuck.
PostPosted: Sat Aug 06, 2016 12:59 pm
Sam my lathe won't grip something that small so I went old school and used a grinder, a caliper and patience. 90% of the spacer is exactly to specs but 2 tiny spots dipped a tad thinner. It should work perfectly still. I'll have these back in the mail by Monday. I used the one you started with as it had plenty left before hitting the size you specified so returning the other one unmodified. BTW the drow spacer is 5mm thick and I'm quite sure that was the same thickness as the spacer I made and lost.
the Ruckix
the Ruckus
60/49 club member
PostPosted: Sat Aug 06, 2016 2:27 pm
fuck.
PostPosted: Sat Aug 06, 2016 3:46 pm
Thanks for fixing that, i just have the hardest time squaring shit up.
King Ghidorah
PostPosted: Sat Aug 06, 2016 4:08 pm
No problem. Got years of experience making brushes fit starters and such. Hope that works for you.
the Ruckix
the Ruckus
60/49 club member
PostPosted: Sun Aug 07, 2016 11:52 pm
Worked on making a Mr.Stiffy mini duckbill. Not sure how im going to mount it.
King Ghidorah
Rucksters browsing this forum: No rucksters and 10 guests
