Post new topic Reply to topic  [ 1043 posts ]  Go to page Previous  1 ... 66, 67, 68, 69, 70  Next
 Post subject: Re: Rhonda the Ruckus (First Ever Build of Anything)
PostPosted: Thu Oct 20, 2016 11:51 am
When I burped mine, I took the tad cap off, l
Start the bike, let it GET warm and rev it up a few times. If there are bubbles in the system they will bubble up and out....
fuck.
PostPosted: Sat Oct 22, 2016 5:16 pm
JRolla wrote:
Bike looks great, I hope you can iron out the issues soon.
How do you know when a bike is in limp mode and how do you burp the radiator? Two things I've been wondering for a while.
Limp mode is like seven mph Max and caps revs at like four thousand rpm or something.
Mine ended up being the ecu somehow? Swapped ecu and it seems fine. Rehooked up old, over heating again. Think maybe it's just a matter of resetting the old? Not sure. Either way I'm up and running for now as of tonight.
Build Thread: Rhonda the Honda
PostPosted: Sat Oct 22, 2016 11:37 pm
Put that old potentially shitty ecu in a bag, take BIG bonghit , blow the hit into the bag wait 27hrs and continue?
GREAT SCOOT!
fuck.
PostPosted: Tue Nov 01, 2016 6:24 am
Carb return spring... not doing it's job.
Luckily I have about 8 other carbs if necessary... Just not polished like me carb is now.
PostPosted: Tue Nov 01, 2016 9:26 am
Check the slide for scratches could be getting caught on a bur from when the carb was polished it's not a strong spring
My ruck "build"
The Asphalt Slayer
T.sracing wrote:
PostPosted: Tue Nov 01, 2016 9:28 am
My ruck "build"
The Asphalt Slayer
PostPosted: Wed Nov 02, 2016 6:45 am
I need to inspect it much closer. It's been the same carb for... a year now? and never had issues until recent.
PostPosted: Wed Nov 02, 2016 3:10 pm
Seeing these two guys back! :banger: :highfive:
King Ghidorah
ultramagnus wrote:
PostPosted: Thu Nov 03, 2016 12:28 pm
mannnn every day it's something. Right now, it acts like the blue starter relay isn't fully plugged in....
BUT the kicker... i turn the key and the lights go on? but nothing else does. No clicking, no electric start, nothing. Just lights.
STRANGE.
PostPosted: Thu Nov 03, 2016 1:19 pm
Yeah :banger: and link is a FL boy now!!
Mike I hope you GET it figured out :popcorn:
fuck.
PostPosted: Thu Nov 03, 2016 1:38 pm
I still haven't even started it since the move probably runs like poop probably spend a month just getting it tuned to fl
My ruck "build"
The Asphalt Slayer
PostPosted: Fri Nov 11, 2016 12:26 pm
My trailtech light stopped lighting up. The speedo works, however, the light does not come on... Maybe the battery for the trail tech specifically?
OR it may all be related to the fact that sometimes i turn the key and just the lights come on? ...ugh i donno but IDC it's running well and it starts most times electric and all the time kick.
PostPosted: Fri Nov 11, 2016 4:15 pm
Same thing happened to mine. I blew the .500 amp fuse. there was a short in the fuse holder... after i switched the fuse i used more electrical tape on the fuse holder and fixed it.
PostPosted: Tue Nov 15, 2016 8:02 am
This must be what's going on. Seems to make sense. I donno, I just haven't even looked at it yet because it kick starts fine/electric starts most of the time... and I have a puppy lol.
I've stopped caring as long as things are MOSTLY working :lol:
PostPosted: Tue Nov 15, 2016 8:10 am
