Post new topic Reply to topic  [ 1043 posts ]  Go to page Previous  1 ... 65, 66, 67, 68, 69, 70  Next
 Post subject: Re: Rhonda the Ruckus (First Ever Build of Anything)
PostPosted: Fri Oct 07, 2016 7:20 am
NVM rhonda is not running fierce. these fuckin valves man. I'm replacing my engine this time. hopefully this weekend.
Is it easy enough to swap just the motor and not the swing arm? That's my plan./
Build Thread: Rhonda the Honda
PostPosted: Fri Oct 07, 2016 1:31 pm
Lets see some pics, man.
my left nuts
Jedi wrote:
pics of wife? :meh:
PostPosted: Sat Oct 08, 2016 9:13 pm
It's at a friends storage locker. Changed the engine out today. Most went smooth, started right up... but then after a trying to fix an idle issue it didn't start again
Started and was revving way too high. Seemed like the butterfly in carb was lagging. Hit throttle and let go and it would climb after releasing.
Think I flooded it, trying again tomorrow. Probably will clean the carb just cause. Carb and exhaust are mine so I know they were fine before..
Also paid way too much for a motor just so I could definitely have it done this weekend. So much for that.
PostPosted: Sat Oct 08, 2016 11:42 pm
I had a similar issue with my nuts once, it was the intake coupler being loose. Im sure you'll GET her going tomorrow, GOOD LUCK BUDDY!
my left nuts
Jedi wrote:
pics of wife? :meh:
PostPosted: Sun Oct 09, 2016 11:27 am
What was it doing!? That very well could be it. The screw was stripped and couldn't get it to tighten well.
PostPosted: Sun Oct 09, 2016 3:20 pm
Kind of ghost throttling at idle, suddenly revving up.
Hope you figured it out!
my left nuts
Jedi wrote:
pics of wife? :meh:
PostPosted: Tue Oct 11, 2016 7:22 am
So I replaced carb boot, worked. Idle's great, takes off like a bat outta hell... then goes into limp mode.
Overheating somehow. Tried burping the radiator with no luck. tried changing the thermostat, no luck. tried pinching the hoses from radiator, no luck.
Gave up. Back at it again tonight I guess.
PostPosted: Tue Oct 11, 2016 10:57 pm
How was the oil change? Anything funny in there? :popcorn:
my left nuts
Jedi wrote:
pics of wife? :meh:
PostPosted: Tue Oct 11, 2016 11:24 pm
No milkshake!
:snorkel: :popcorn:
PostPosted: Wed Oct 12, 2016 6:44 am
Didn't get to it. Rhonda is in a storage locker away from home and the dudes are not available all the time so basically i can go work when they are there.
I'm dying without her. lol Plan is oil check/change, coolant flush, water pump swap. In that order, trying after each time.
PostPosted: Wed Oct 12, 2016 3:01 pm
Hope you get it figured out. I've only had overheating issues one time, and it turned out to be a stuck thermostat, but you've already changed that. And you've burped it. Maybe check the temp sensor wire for a good connection. :meh:
my damaged buildthread
PostPosted: Fri Oct 14, 2016 12:22 pm
Another weekend approaches, GET to it!
And If you want to sell the flywheel off the bad motor send me a pm please.
my left nuts
Jedi wrote:
pics of wife? :meh:
PostPosted: Thu Oct 20, 2016 6:57 am
If I can figure out how to get it off. sure haha
PostPosted: Thu Oct 20, 2016 9:34 am
I can send you my puller, then you send it back with flywheel. Sent you a pm.
my left nuts
Jedi wrote:
pics of wife? :meh:
PostPosted: Thu Oct 20, 2016 9:42 am
Bike looks great, I hope you can iron out the issues soon.
How do you know when a bike is in limp mode and how do you burp the radiator? Two things I've been wondering for a while.
Rucksters browsing this forum: Tanuki and 2 guests
