Post new topic Reply to topic  [ 177 posts ]  Go to page 1, 2, 3, 4, 5 ... 12  Next
 Post subject: trueadrn's Ecto-3 (renamed)
PostPosted: Wed Feb 19, 2014 10:27 pm
When I got her ---2013 Ruckus---
then 3/29/2014
6/21/2014
7/1/2014
10/5/2014
Next up
plastidip mad eyes \/
put reflectors on front forks
maybe relocate PVC
find smaller coolant tank Bought
install headlight switch for lows (looking for switch that a. looks good and b. can handle da paowa)
install usb charger (will get to it eventually, don't have anything to connect to it at the moment.)
install alarm (for the moment, just won't leave its side) will involve getting a smaller battery to make room for it in BB.
Future plans 2015
1. vent and reinstall CVT cover (want kickstart back) plus it looks cleaner
2. lightened flywheel ***5g Dr. Pulley Sliders **** Waiting to see returns from CDI
3. contra spring blue Polini Bought
4. shaved hook???
5. aux driving light Bought
tune- tune- tune
installed Polini 17.5 carb ***** Done
switch out air filter hanging out on left side ***** Done
Front disc brakes (went with NCY wheels) ***** Done
install carbon Driven 1 1/8"bars with Yoshi triple clamp ***** Done
Install carbon Yoshi exhaust ** rejet ***** Done
put in 1000 miles ***** Done
put center stand back on ***** Done too hard to perform maintenance w/out
paint clutch bell ***** Done
paint vented CVT cover ***** Done
Kitaco CDI ***with 4.5g Dr. Pulley Sliders ***** Done
vent CVT***** Done
remove center stand ***** Done
mount rear Bopper ***** Done
paint rear fender bracket ***** Done
find a better bag ***** Found
paint one headlight yellow ***** Done
lower front fender ***** Done
make bracket for rear fender ***** Done
fuel gauge Stage 6 ***** Done
lower front turn signals and remove bunny ears ***** Done
front clear turn lenses ***** Done
modex plug for horn ***** Done
rear shock -Doppler ***** Done
air box delete ***** Done
front forks -rrgs ***** Done
dorf MNNTHBX ***** Done
red rad hoses MNNTHBX ***** Done
windscreen Kajima ***** Done
find a place for GPS MNNTHBX adapter ***** Done
Trail Tech Tach ***** Done
Battery Tender ***** Done
jock strap MNNTHBX ***** Done
put in 100 miles ***** Done
variator Polini ***** Done
Gates Kevlar belt ***** Done
weights 5.5 - 5 - 4.5 (dial in) Dr. Pulley ***** In process
Dyna beads? -- not sure if I need 'em *** I'ma hold off for now rims are pretty true
 Post subject: Re: trueadrn's 88th white and red build
PostPosted: Wed Feb 19, 2014 10:39 pm
picked up a Dorf and Jock from MNNTHBX and a lowered stock tail light bracket from ebay.
Dorf and the bracket where simple enough but the Jock Strap took some work.
what I did was install the Jock without the floorboard measured down from the bottom of the BB.
Then installed the floorboard and drilled a hole an 8th of an inch lower.
with a sharpie i drew the basic shape making sure to center it and keeping my lines straight up and down.
Then made my ruff cut with a Dremel Multi-Max (seen below) then cleaned it up with a utility knife.
after a lot of test fits and fine tuning with a very sharp razor blade.
So far I love it. The only snag is the fuel door. But I think i'm just going to get rid of the hinge and that should
take care of that, if its even an issue. Haven't had to get gas yet - love that!
current
For sale but I'm not shipping. If you're in the PDX area and want some new parts shoot me a PM.
I'm in Hillsboro and will meet within reason.
$15.00 right controls w/out switches
$15.00 TrailTech TTO
$15.00 > $10.00 Stock rearview mirrors.
$20.00 MNNTHBX skid plate
$20.00 MNNTHBX drum adapter
$30.00 Stock speedo w/ cable (limp mod LED wire cut)
$50.00 Boss made Nike swoosh GET rad cover
$20.00 Boss made blank GET rad cover (i'll throw in some mesh pictured)
W/ other purchase $5.00 in black. MNNTHBX billet bar ends new
Free Drow plate frame with purchase
Free Garmin x 1" ball RAM mount adapter with purchase
$20.00 stock front wheel with Bopper mounted ***** SOLD
$40.00 stock front forks ***** SOLD
$40.00 stock carb ***** SOLD
$20.00 in white. Lower tail-light bracket ***** I ended up using it :lol:
$25.00 in red. Password JDM axle pullers ***** Traded
$25.00 > $20.00 120/70 - 10 white wall Shinko SR723 ***** SOLD
$30.00 in black. Password JDM kick starter arm ***** SOLD
$20.00 Dr. Pulley 5.5 Sliders ***** SOLD
$250.00 Killer Scooter Beefy Bars in black New ***** SOLD
$10.00 in black. WPS folding pegs 12MM ***** SOLD
$15.00 in red. Large Password JDM washer set ***** SOLD
$15.00 in red. Smaller Password JDM washer set ***** SOLD
$30.00 in red. Password JDM calf cutters ***** I ended up using them :lol:
$10.00 in black. Foam grips***** Given away
 Post subject: trueadrn's 88th white and red build
PostPosted: Thu Feb 20, 2014 10:30 am
Looking really good! :)
You should totally powder the jock white!
Skickas från min iPhone via Tapatalk
My Honda Zoomer PGM-FI GET 50
BUILD THREAD: viewtopic.php?f=95&t=84197
PostPosted: Sat Feb 22, 2014 8:35 am
I wanna see that chin bone in person
ЯnRbuild thread <----click it
PostPosted: Mon Feb 24, 2014 4:20 pm
My GET is still to slow to go very far with my fat ass. I'm waiting on some sunny days to start tuning- hoping to make it to the next meet. Looking forward to seeing all the local Rucks.
I'll try to knock out the install of the tach and front forks this weekend.
PostPosted: Mon Feb 24, 2014 4:36 pm
Hahaha we all have winter weight.
PostPosted: Sat Mar 01, 2014 9:24 pm
HA I wish I could say its winter weight... more like 6 winters worth. :lol:
I'm an idiot... tach not set up correctly- fixed the problem
Got the mount for the GPS on and took off the parts that are getting powder coated.
It feels like one step forward three steps back :meh:
No sun in the forecast so i'll focus on figuring out my idle issues.
PostPosted: Mon Mar 03, 2014 9:40 pm
Same here. Very cool piece.
My Ruck: viewtopic.php?f=96&t=52960
She's like a rat rod dude! Ugly, but hot as fuck!
PostPosted: Mon Mar 03, 2014 9:52 pm
Love the way you did that Jock strap.
As for the RPM gauge, I have been having a very hard time getting mine to not fluctuate so much.
I found that if I just take the end of the wire and zip tie it to the plastic shielding of the spark plug wire, (no wrapping it) I get about a 30-40 RPM fluctuation. Try that and see if it helps.
I was told not to expect perfection with these tachs, I have also noticed that there are delays in the readings.
This really bugs me so sometime in the future I am going to get a tach that is more precise.
2005 Ruckus
Build thread: viewtopic.php?f=92&t=86004&p=1469843#p1469843
If you are new to the Ruckus, please start here: viewtopic.php?f=11&t=87409
PostPosted: Tue Mar 04, 2014 12:04 pm
I wish i could blame the gauge. :oops: its my ruck that has a jumpy idle. I'm thinking it just sat too long at the dealership and/or it just hasn't had time to settle in (only 10 miles on it). Either way, I'm not doing any performance mods till I figure it out and get some miles in it.
PostPosted: Sat Mar 08, 2014 5:30 pm
man... you're just breaking it in! lol! go ride that sucker! you can always wash it off later! weather here has been shitty for riding lately for sure, if you don't have the right gear.
PostPosted: Sat Mar 08, 2014 9:39 pm
Loved the sunshine on Friday :banger: But yea I need some gear to go out in the rain. Its surprisingly cold.
Finally installed the RRGS forks and now I need to lower the front fender. HA :lol: 1 step forward 2 steps back.
I think i'll use a longer bolt and spacer to lower it.
Don't want to buy a new one and don't want to be without one -so it will have to do for now.
It took me a few hours but most of that time was spent making my jack stand.
I used a Harbor Freight furniture dolly and some wood and it worked like a charm.
I installed the Kijima windscreen and rear view mirrors from Webike. Love'em.
Still waiting on 2 boxes. One from Battlescooter and the other from MX Perf.
Jock is off getting powder coated. Should get it back on Tuesday.
PostPosted: Sun Mar 09, 2014 4:59 pm
had some fun today before the downpour. Loving the new set up.
