Post new topic Reply to topic  [ 68 posts ]  Go to page 1, 2, 3, 4, 5  Next
 Post subject: ruckstaposition: project metrocity
PostPosted: Sun Oct 20, 2013 4:04 pm
The megamind inspired metropolitan named "metrocity" has begun. Kind of. I bought the bike and have started procuring parts.
now TR I need your help.
are we doing a fatty metro, just a stretched met, metruckus, or going for the gold with a metruckazumas?
I've never seen a metruckus with a Yamaha 2t so that gets my vote.
anyway here's my canvas. 2004 met for $300.
No Name Ruck
"Metrocity"
Third-Time-2t-charm
 Post subject: Re: ruckstaposition: project metrocity
PostPosted: Sun Oct 20, 2013 4:45 pm
Either a fatty met or metzuma. Metrucks are nice but easy compared to anything with the met rear frame. Nice find Im subd.
If you do decide to make a fatty you should patent the mount and sell me one haha
Some time she goes some time she doesn't. Fuckin way she goes...
OZ 00MS
viewtopic.php?f=94&t=85475&p=1463161#p1463161
Forrest Spirit 70cc Zuma powered Express
MollyWife's Met
PostPosted: Tue Oct 22, 2013 10:02 pm
if I make it fatty, I'll likely use one of the two Lego mounts I've been sitting on. :highfive:
No Name Ruck
"Metrocity"
Third-Time-2t-charm
PostPosted: Tue Oct 29, 2013 7:06 am
well I decided to go with an air ride met. to start with anyway. i had this set of work wheels laying around for a while and wanted to see them get used so that's what she'll wear to start out with. this is the progress so far. password stretch w/ mike155cc kit, composimo eye 2 eye and cvt cover, lowered front forks which will have disc conversion, and the same air setup everyone is going with. keep in mind, everything is only mocked up and I also don't have all the parts for the air shock yet.
No Name Ruck
"Metrocity"
Third-Time-2t-charm
PostPosted: Tue Oct 29, 2013 7:23 am
Is the cyl going the hit the plastic? looks good for a mock up I like the wheels.
OZ 00MS
MollyWife's Met
PostPosted: Fri Nov 15, 2013 1:58 pm
thanks man. it is going to hit, so I'll need to reangle the engine. I got all the parts for the airride. I decided to run a small tank to help air up quicker. I'm also using a pressure switch to run the compressor. it's set to turn the compressor on at 100 psi and off at 150, hopefully that's plenty of pressure, but I haven't tried it yet. I'm also going to use a digital meter to monitor the pressure in the system. the meter has two readouts on it. one will be for pressure in the tank, o make sure I'm not exceding my high and low limits, and the other will be for the shock itself, so I know where my comfy ride is.
here's a picture of what will be going under the seat.
couple other pieces.
No Name Ruck
"Metrocity"
Third-Time-2t-charm
PostPosted: Fri Nov 15, 2013 2:05 pm
so this is how the attic is lookin.
No Name Ruck
"Metrocity"
Third-Time-2t-charm
PostPosted: Sat Nov 16, 2013 6:06 am
Looking good what kind of wheels are those?
OZ 00MS
MollyWife's Met
PostPosted: Sat Nov 16, 2013 9:11 pm
work wheels. the back has an unknown hub on it and the front has an integrated hub and disk. it's kind of weird. never seen another one like it. I ordered a Texas Hooker to weld onto the lowered stock shock up front, and I'm gonna try to make a custom caliper adapter to run a z125 caliper on it. I held it all up there tonight and it looked doable.
No Name Ruck
"Metrocity"
Third-Time-2t-charm
PostPosted: Sun Nov 24, 2013 9:28 am
here are the stuffs that will be going into the custom dashboard. tact, pressure gauge, stereo controller.
projector headlight.
and I melted the headlight trying to get it apart. anyone know what temp I should have had the oven set to?
and if theboss can make it this way, I'll have a radiator cover with this design.
No Name Ruck
"Metrocity"
Third-Time-2t-charm
PostPosted: Sun Nov 24, 2013 9:34 am
That projector is sick. Where did you get it?
OZ 00MS
MollyWife's Met
PostPosted: Sun Nov 24, 2013 9:39 am
eBay. $45. can't be beat for that price. ballast sold seperately.
No Name Ruck
"Metrocity"
Third-Time-2t-charm
PostPosted: Sun Nov 24, 2013 9:40 am
Hell no good deal met lights are easy and cheap im sure you will find a replacement in no tinme.
OZ 00MS
MollyWife's Met
PostPosted: Sun Nov 24, 2013 10:23 am
Ruckstaposition wrote:
lexan as the material and a laser engraver can probably do something close to this
PostPosted: Sun Nov 24, 2013 10:34 am
Last time I tried bake the light at 325 at 8 mins. I do have 2 metro lights selling for $40 shipped if u need a new one
2003 GET-Retired
2005 GY6-Sold
*****2-strokes Vanilla Shake in the making(S-Motion Garge/SparkleMotion)****
