Post new topic Reply to topic  [ 48 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: ryanjblajda's build.
PostPosted: Sun May 22, 2016 7:17 am
Ryans GY6 Met Build
PostPosted: Fri Aug 19, 2016 9:43 am
so this thing hasnt been updated since fucking ever. if you actively want to follow this i would suggest going to instagram and following me there, but ill post some updates here for everyone. my insta handle is @ryanjblajda. who would have thunk it.
video of my new exhaust - https://www.instagram.com/p/BIh0iEYjHfd/
fuel pump came in a day early. woot.
stuff to drop off at powdercoat. my mount started to get some surface rust after welding. i will be keeping the kickstart and stock CVT cover because i am a worry wart and i dont want my case snapping, and i want to be able to kickstart it if i need to.
a back angle of my awesome fireball steadygarage exhaust.
a friend of mine donated his wheels from his donor because the rear wheel on mine was super fucked. if anyone wants a brand new 13" scooter tire with a cut in the sidewall for $15 let me know. i have no use for it now.
i actually love the 5 spoke front wheel more than the ones i had originally.
bought a trailtech vector (not a vapor like i was told unfortunately so i have to run a tto tach), bars, stem, tto tach, and some adelin knockoff controls for $60 from a friend of a friend.
here are a few views of my custom engine mount i designed based off the buggy depot gy6 mount. i used hardware from McMaster Carr to build engine hangers. i love rod ends/heim joints. they make me happy. they are rated to 6,323lbs static load per joint and there are 2 per side, so this mount isnt going anywhere.
getting my shock to sit square was a fucking pain. i had to modify the shock and modify my CVT case by grinding it down near the mounting point. being anal is a nightmare.
i have heard and seen shit on FB about cases snapping and such so i want everything to be as square and as braced as possible. ill need to add a bolt through the rear frame on my shock extension, but that will probably happen once my mount gets back from powdercoat so i can just bolt everything up at once.
Ryans GY6 Met Build
PostPosted: Fri Aug 19, 2016 2:27 pm
no updates at the moment, just waiting for my caliper bracket come back from the welder and i can start the re-assembly process. i still need to buy a few things but not a lot.
Turbo Air Filter
Engine Mount Bolts
Nordlocks for Engine Mount
Engine Hanger Bolts
Vector Magnet Bolt
Carbon Fan Scoop
Adjust Valves
thats what i have left on my list of things to buy/be done.
Ryans GY6 Met Build
PostPosted: Fri Aug 19, 2016 4:40 pm
Nice progress! :highfive: How's the angle of your motor? One of things I've notice on other Met Gy that the swingarm angles downward making it look like the motor is sagging.
METROD49 Build
viewtopic.php?f=95&t=95633
PostPosted: Fri Aug 19, 2016 6:35 pm
should be pretty good, with those hangers i can adjust head angle. but i made sure to make the head leveled when i drilled the holes for the the hangers.
Ryans GY6 Met Build
 Post subject: Re: Ryan's GY6 Met Build (GY6 Stuff Page 3)
PostPosted: Sat Aug 20, 2016 5:10 am
Looks good bro! Wish i had kept my Metro. There was a guy in O-town selling his GY6 assembly for $80 but i missed it. Couldn't get around to driving up there this week and he was moving is why he wanted nothing for it. So when does this Cocoa ride go down?
PostPosted: Sat Aug 20, 2016 6:36 am
Sept 10th
https://www.facebook.com/photo.php?fbid ... =3&theater
add yourself to Florida Ruckus Riders if you arent already and you will see it.
also thanks! i should be done soon. tired of looking at it sitting in my living room. :headbashing:
once i get my plastics painted this is what it should look like.
Ryans GY6 Met Build
PostPosted: Sat Aug 20, 2016 8:26 am
Your rendering makes a aftermarket fender look really good with a Met. Maybe something to consider myself. Like how it make the front end a little more agressive looking. Cant wait to see it bro:banger:
ryanjblajda wrote:
Sept 10th
METROD49 Build
PostPosted: Sat Aug 20, 2016 8:32 am
thanks man! its cool to see what it should look like.
Ryans GY6 Met Build
PostPosted: Sun Aug 28, 2016 11:19 am
got my parts back from powder. not all of them are picture but my mount and kickstart look awesome.
Ryans GY6 Met Build
PostPosted: Mon Sep 05, 2016 11:34 am
video of the engine running post valve adjustment / pre engine and gear oil change. this bike had like no oil in it previously and what was in it was black AF. gear oil looked fine, but i replaced that just to be safe.
i used 10w-40 and 80w-90 respectively.
https://www.instagram.com/p/BJ8O5jaDMhC ... yanjblajda
my exhuast sits too close to the shroud and is melting it...gotta buy a new one i guess. this shroud isnt the most common gy6 shroud.
the rolling/running chassis.
engine mount pics pre-engine installation
my muffler spring tabs
custom front end with Batman Texas Hooker bracket done by Xtreme Powdercoating.
Ryans GY6 Met Build
PostPosted: Sun Sep 11, 2016 7:58 pm
Looks pretty good bud! I'm really liking the progress. Keep it coming man! :banger:
Pyrogen wrote:
Anyone can swap a Ruck CVT on a met in a matter of an hour or less, But to truly make a Metruckus, one must go balls deep into the project and come out sticky and bleeding.
Daily Driven: 04 Honda Metro II A.K.A The Slowbro
PostPosted: Mon Sep 19, 2016 10:57 pm
thanks man! im in California for work until the end of September so progress will come to a standstill until I am back. hopefully it should be done fairly soon after i get back though.
Ryans GY6 Met Build
PostPosted: Mon Oct 31, 2016 3:50 pm
video of it running.
https://www.instagram.com/p/BMJ9cFgF5WN/
Ryans GY6 Met Build
PostPosted: Sat Nov 05, 2016 8:10 pm
Ryans GY6 Met Build
