Post new topic Reply to topic  [ 23 posts ]  Go to page 1, 2  Next
 Post subject: Pandatrooper's "Speeder Bike" GY6 / swing arm / now lowered!
PostPosted: Fri Mar 08, 2013 11:15 pm
Posting a few of the latest pics here. Build thread below. :)
2003 Ruckus
Chassis
NCY frame brace
Painted front frame (Por15)
FLP front frame cover
Custom rear sets for pegs
Basic Bikes silencer pegs
Dorf seat frame
Custom Ruckr seat cover
Motor
Composimo non fatty motor mount
GY6 long case
DanMAX harness
Mikuni fuel pump
NGK Iridium plug
High performance Coil
11 pole stator and flywheel upgrade
Stage 6 air filter
Front facing carb
Composimo angled clocking flange
Composimo intake manifold riser
Custom overhead header
Yoshimura carbon mini TRC exhaust
Gold fan scoop
Composimo bolt on headlight lowering brackets
Ballistic Evo 2 8 cell battery
Aftermarket H4 bulbs
Mini indicators
Championship white painted battery box
Controls
JiangWayne gold motoX bars
PasswordJDM stem
G2 billet quick throttle
Vapor gauge
CRG style brake levers
Suspension / brakes
RRGS low down fronts gold on black
NCY brake rotor
NCY caliper / bracket
Custom AMT machine shop right side swing arm
80" rear brake cable
Standard Functions rear brake drum pads
Composimo rear shock mount
Scooterworks low down rear shock
Wheels
NCY 10" front
Kenda K329 120/90/10 Tire
10x5 mini fatty ITP rim (3+2)
ATR universal hub
Custom hub centric spacer
Kenda K329 140/90/10 Tire
Stared gutting it immediately
Removed flat bars and stem
Disassembled front end, the brakes and shocks fell out in chunks!
Gas tank
A new tank was ordered to replace the old one.
This was how far it got in a day
I gutted the front frame, and wire wheeled it to clean it up. It was all rusted / oxidized.
Cleaning up the underside
After that, I prepped the frame and then painted it with Por15 paint, awesome stuff!
After the paint dried, I installed a front cover from Composimo
Had a seat frame and battery box painted Champ white to match my car (pic at the end when completed) :)
More to come!
Pandatrooper's GY6 / mini-fatty "Imperial Speeder Bike"
viewtopic.php?f=95&t=79672
Last edited by pandatrooper on Tue Aug 27, 2013 11:14 pm, edited 6 times in total.
 Post subject: Re: Pandatrooper's "Imperial Speeder Bike"
PostPosted: Sat Mar 09, 2013 4:56 am
Good start. Excited to see another panda out there.
Pauls Panda-monium <-- my retired build
MYSD Black nd Plum <-- side project
OC reppin
250 bangin :flip:
PostPosted: Sat Mar 09, 2013 9:43 am
Thanks! More pandas is always a good thing. :)
PostPosted: Sat Mar 09, 2013 9:50 am
Painted the headlight frame and bracket
Cleaned and polished the gas tank cover
While the tear down was happening, I was stockpiling parts for the last 2 years.
NCY front end / brake kit
Composimo GY6 standard mount (non fatty)
Dan Max harness
Rear brake, 11 pole stator and flywheel
GY6 parts
Smaller than stock signals
Some ebay bar end mirrors
Some old BMX flatland bars I had powdercoated
Also powdercoated a 10x5 (3+2) rear rim for a mini-fatty and the front rim
Reupholstered the seat, kind of old school style
Some CNC levers purchased on TR
PostPosted: Sat Mar 09, 2013 10:01 am
Youll like those mirrors...I have a set, good stuff.
5prock3t'5 09 RED Ruckus
PostPosted: Sat Mar 09, 2013 10:06 am
Good progress, interested to see the results, panadas are awesome!
where did you get the smaller than stock blinkers and/or what brand are they? thanks!
HRCA
GET POWA!!!
Proud Member of Team Floorboard!
kookookeedoo wrote:
Man, I miss the good old days when the noobs popped up and just wanted to know how to go 50... :headbashing:
PostPosted: Sat Mar 09, 2013 3:26 pm
They are called "Emgo mini turn signals". I just got them from a local motorcycle shop, but you can find them online too.
 Post subject: Re: Pandatrooper's GY6 / mini-fatty "Imperial Speeder Bike"
PostPosted: Sat Mar 09, 2013 3:36 pm
Cleaned up the controls with some metal polish
I designed some rear set peg mounts that set the rear pegs slightly down and further back than the rear frame holes. I also had some of my old BMX pegs in the basement, made a now defunct company called Basic Bikes, and they were called "Silencers". Thought they might look cool on the Ruck!
My friend Adam fabricated these for me.
Painted the rear sets with Por15 and mounted them in between the front and rear frame. Rock solid
This was a slightly older photo, but I got my GY6 and Adam also did a custom exhaust for my Yoshimura TRC exhaust. I have changed the mount since, but this gives a good idea of where it would go.
PostPosted: Sat Mar 09, 2013 3:44 pm
Installed the stock headlights. Using Composimo headlight lowering brackets. Bulbs were changed for aftermarket super white H4 bulbs.
Mocked up levers
Mocked up front end
Just before the swap, seat and seat frame installed, bars bolted on using a Password JDM stem. And a strange car in the background. :)
Aftermarket ATR rear shock mocked up on the old GET motor
A custom rear right side swing arm was fabricated for the GY6 swap with a bearing mount, and swingarm mounts to the motor. The wheel is held on with a hub centric spacer over the long axle, and bolts directly to the ATR hub. Rock solid!
Baller time GY6 with swingarm, custom hub and Yosh carbon TRC. Yes, it does sound awesome. :)
Next set of progress pics: swap completed and wired up!
PostPosted: Sat Mar 09, 2013 5:13 pm
I have a baby due any day, so my friend Adam did the rest of the swap for me so I can ride it after baby arrives.
Motor swapped, harness installed.
Front end / controls, small Ballistic battery
Ordered a kickstand and a filter for the GY6. Starts and runs fine, serious growl to it with the exhaust. Just needs a filter (obviously my GET filter doesn't fit)
Gas tank painted, MET fuel sender installed (was going to get an Acewell gauge, but every time I want to order one from Standard Functions they are always sold out!). A local member had a Vapor gauge so I bought that instead.
Rear end with Kenda 329 tires Kenda K329 tire rear 140/90/10 slightly stretched, front is 120/90/10.
The rear brake light is the stock one mounted for now, until I find a lower profile LED one I like.
*Note on the Composimo GY6 mount. I thought it would fit in the stock location with the mini fatty, but it is offset. If I used a stock GY6 rear wheel it would be OK, but the mini fatty was off by an inch or so, so the mount was modified and moved to the left of the frame to center up the rear wheel. Just a note to those trying to run a 3+2 mini fatty with an ATR hub on GY6.
Ruck in current state. Only a few things left before it's street ready!
PostPosted: Sat Mar 09, 2013 5:42 pm
i want that swing arm, very nice
my ruck.... viewtopic.php?f=94&t=85528
PostPosted: Sat Mar 09, 2013 5:57 pm
cool swingarm. :popcorn:
-14 Grom
-09 ruckus gy6 fatty
-09 ruckus gy6
JRxIERxKNxSG
PostPosted: Sun Mar 10, 2013 11:28 am
It is hunanimous! swingarm is tits! :banger:
thanks for the info on the blinkers!
HRCA
GET POWA!!!
PostPosted: Mon Mar 25, 2013 9:41 pm
"Full armed and operational..." :)
Swap completed, runs awesome! Some pics as she stands right now. Some fixes and mods to come:
- adjust suspension, might stretch it slightly with Composimo medium link
- lower the front fender (or swap it)
- install PasswordJDM drag brace
- adjust stock tail light for now (new tail light ordered)
- install Dingleberry plate mount
- G2 billet throttle
- find a rear fender that fits
- new kick starter on the way
- new plug and coil / oil change
PostPosted: Tue Mar 26, 2013 8:49 pm
yo, T . if you decide to stretch it more you will need to get the longer throttle and brake cables. also as a side note i had a customers ruck come back as it decided not to fire the spark plug anymore and it was a faulty cdi unit , the same one you are running so just a heads up that your cdi may or may not crap out.
Adam
