Post new topic Reply to topic  [ 357 posts ]  Go to page Previous  1 ... 19, 20, 21, 22, 23, 24  Next
 Post subject: Re: 5prock3t's modified stock(reGET)
PostPosted: Fri May 10, 2013 8:47 am
You going to modify that Yellow spring? :wasted:
Let us know how it works out.
08 Metro- 64/58 club :banger:
viewtopic.php?f=92&t=63326
09 Metruck- SOLD
viewtopic.php?f=92&t=79193
ConElite for Mod 2016!!!!
PostPosted: Fri May 10, 2013 8:55 am
No need, it fits...thanks for stopping by, have a great weekend. :highfive:
5prock3t'5 09 RED Ruckus
PostPosted: Fri May 10, 2013 9:02 am
Your welcome buddy :highfive:
09 Metruck- SOLD
PostPosted: Mon Jun 03, 2013 7:36 am
After leaning out my 38/80 jetting via the iac down to almost nothing I rejetted to 35/80...this drove well but the throttle was a lil too flimsy feeling and I upped it to an 82, and that better.
But my concern is the iac and its adjustment...its only 2 turns out :shock:
I tweeked it til it did the 100 rpm drop and then back 3/4 of a turn...right at 2 1/4 out...this seems as though it would be rather lean on take off?
Should I fatten it up till the rpms hang a bit and then lean it out til it slowly drops? Or just rock what I got???
Of course, intake and hmf exhaust...if you haven't been following previously. :wink:
Thanks!
PostPosted: Mon Jun 03, 2013 8:31 pm
I'm still using the throttle-blip method, I get it as good as I can with the tach, and then blip and adjust, repeat, repeat. I like to get it so it drops smoothly back to idle without hanging up, but doesn't drop below idle speed. I just went thru that process today, as a matter of fact.
In case you forgot: viewtopic.php?f=11&t=73539
my damaged buildthread
PostPosted: Fri Aug 09, 2013 1:44 pm
New personal best for me (53mph)on the way home from work.
I think its gotta lil bit more left in it w a lil more tuning...no cdi involved, stock rev limit.
Edit/ hope the pic shows...its not showing on my phone after several attempts to preview.
(fixed it via my laptop)
ALSO...BIGBIGBIG THANKS to OF55 for helping me get here!!!
PostPosted: Fri Aug 09, 2013 1:56 pm
:meh: Not sure what I did, but you're very welcome!
Pic no worky for me (iPhone)
Congrats on the speed though! :highfive:
-Ruckus
-Big Ruckus
-Grom
PostPosted: Fri Aug 09, 2013 2:02 pm
You know...they say the memory is the first thing to go :ucrazy:
...but I get it :wink:
Your posts and good conversation...among other thing...youre my Ruck hero! :highfive:
And although it pains me to admit...Ive used a couple of Con's tips(intake runner length, jetting and am trying a Gates for the first time)...all of this(with the aid of OF55) has got me running a mix of 6.15gram weights. Im just shy of the rev limiter now.(wish I could get a combo of 6.1g without shaving weights)
PostPosted: Fri Aug 09, 2013 2:47 pm
What app are you useing for Speed it looks great
Thanks Honda GET going
My 2005 :LR:
Total Ruckus Super Scooter Search Of Massive Results
PostPosted: Fri Aug 09, 2013 2:52 pm
Ulyses...seems the one most everybody is using for droid
PostPosted: Tue Aug 13, 2013 7:18 pm
Meh...switched back to 6g weights for the time being.
I figure I'd rather do a fast 50-51 regularly than try and wring out a slower 53.
I'd rather be on top of the limiter than just shy of it much of the time.
I need to shave weights or get a cdi and I'm not likely to do either soon...meh.
...I'm good w 51 for now.
FWIW...its taken me a year to get my 50 back. With the busted collar bone, 140 rear tire, intake and exhaust tuning, killing a motor and then starting over w another intake and exhaust.
I've earned this 53...snd what's more I've got a gps now so its a more reslistic 50+
PostPosted: Wed Aug 14, 2013 6:21 am
:wasted:
Your welcome.
09 Metruck- SOLD
PostPosted: Wed Aug 14, 2013 7:51 pm
Why dont you use met weights?
PostPosted: Thu Aug 15, 2013 3:14 am
For the same reason I don't use sliders.
But since you asked...are met weights either 6.1 or 6.05 grams?
