Post new topic Reply to topic  [ 148 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10  Next
 Post subject: Re: Tyler VR's Honda Aero nb50 to nh125 Swap Project
PostPosted: Tue Apr 11, 2017 12:42 pm
I started to work on a intake manifold adapter plate to run a dio ct intake and larger carb. Got the holes drilled and countersink on the adapter, need to tap threads and angle the port hole.
CH80 Spree
NH125 Spree
PostPosted: Sat Apr 15, 2017 12:08 pm
Here's my big carb and manifold setup. I decided to go with a 28mm oko, someone else online claimed 70 mph with this setup on they're nh125.
CH80 Spree
NH125 Spree
PostPosted: Mon Apr 17, 2017 1:38 pm
Installed the intake and carb, need to spend time re jetting and tuning but it runs.
CH80 Spree
NH125 Spree
PostPosted: Tue Apr 18, 2017 6:48 pm
Red rOOckus
gy6 super stretch
gy6 off-roader project
Yamaha C3
PostPosted: Thu Apr 20, 2017 12:05 pm
The side panel didn't really fit well after the intake and carb upgrade. I was planning on bulging the panel out with a heat gun but there was already a crack so it wasn't doable. I just cut it out around the carb and put some edge trim on, at least I can reach the choke easily.
CH80 Spree
NH125 Spree
PostPosted: Thu Apr 20, 2017 12:17 pm
Looks better cut out anyway!
PostPosted: Thu Apr 20, 2017 4:00 pm
what about the other side???
PostPosted: Fri Apr 21, 2017 1:05 am
The other side panel has the storage trunk that I cut the back side out and sunk it in, but then my new shocks had to be spaced out so I ended up just cutting square out for clearance. Also trimmed the bottom edge of the panel because the exhaust header was touching it.
CH80 Spree
NH125 Spree
PostPosted: Fri Apr 21, 2017 1:19 am
I'm using the storage area for a spare battery for my stereo system.
CH80 Spree
NH125 Spree
PostPosted: Sat Apr 22, 2017 12:32 pm
Trying out 2 different type of air filters, not sure which is best but I've always used foam filters in the past..
CH80 Spree
NH125 Spree
PostPosted: Sat Apr 22, 2017 9:09 pm
CH80 Spree
NH125 Spree
PostPosted: Sun Apr 23, 2017 3:10 pm
:highfive: that was fun. Great color combo- you just don't see it out enough.
Cant wait for more sun! Hope to get to see it in person sometime :banger:
PostPosted: Tue Apr 25, 2017 12:53 pm
Thanks man, it has been fun building this scooter. I still have a couple things planned but it's ready to ride, just need some good weather. 8)
CH80 Spree
NH125 Spree
PostPosted: Tue Apr 25, 2017 1:20 pm
It has came along way since I bought it last fall when it looked like this:
CH80 Spree
NH125 Spree
PostPosted: Tue Apr 25, 2017 2:35 pm
awesome job. i've enjoyed following along with this build. looks great.
Red rOOckus
gy6 super stretch
Yamaha C3
