Post new topic Reply to topic  [ 148 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10  Next
 Post subject: Re: Tyler VR's Honda Aero nb50 to nh125 Swap Project
PostPosted: Sun Mar 19, 2017 8:35 pm
The weather was good enough to ride so I did some experimentation running a 150cc gy6 variator on my nh125.
Comparing parts, ended up using the nh125 ramp plate and boss on the gy6 pulley to make it work. It rides pretty nice, helped acceleration and top speed. I'm using the 13g weights it came with but need to order some different weight rollers.
CH80 Spree
NH125 Spree
PostPosted: Mon Mar 20, 2017 12:26 pm
Also trying out a 150cc GY6 2k performance clutch, My nh125 takes off quick now. 8)
CH80 Spree
NH125 Spree
PostPosted: Mon Mar 20, 2017 2:25 pm
PostPosted: Thu Mar 23, 2017 1:33 pm
Checking back on the variator, I made some sharpie marks on the pulleys and they got rubbed completely off on the outer pulley. But there's still marks on the gy6 variator because it's wider than the stock nh125 outer pulley. The gy6 outer pulley has different spline than a nh125 so I can't use that.
CH80 Spree
NH125 Spree
PostPosted: Thu Mar 23, 2017 1:39 pm
I figured out the elite ch125 and ch150 have the same spline size as the nh125 but the pulley diameter is wider.
Here's a comparison:
stock nh125 on the left, stock ch125 pulley in the middle, aftermarket ch125/ch150 pulley on the right.
CH80 Spree
NH125 Spree
PostPosted: Fri Mar 24, 2017 12:38 pm
I wanted to upgrade the contra spring on my clutch but of course they no one makes one for the nh125. I figured out a dio spring is the same diameter so I'm going to try this 2k one out. Once I put it together I can feel a difference how much harder it is to spread the clutch pulley with my hands.
CH80 Spree
NH125 Spree
PostPosted: Sat Mar 25, 2017 1:24 pm
Testing this stereo system before I install it. Just a mini amp with radio tuner or sd/usb/mp3 and 2in marine speakers.
CH80 Spree
NH125 Spree
PostPosted: Sun Mar 26, 2017 12:17 pm
Stereo installed, sounds good.
CH80 Spree
NH125 Spree
PostPosted: Sun Mar 26, 2017 6:22 pm
rub it in! Now your just looking for things to do.
Hows it running? Any issues?
PostPosted: Sun Mar 26, 2017 10:04 pm
I've only put on about 50 miles since the swap, wish I could ride more but the weather sucks. Only had one issue my very first test ride with an air leak on the carb, also had to adjust the needle clip. But overall its a good runner, more comfortable to ride than my spree.
CH80 Spree
NH125 Spree
PostPosted: Tue Mar 28, 2017 1:49 pm
Doing some repair work on the body plastics. This aero was laid down at some point before I purchased it, lots of cracks and a couple of screw mounts busted off on the shield. Just used some jb weld putty along the cracks on the backside of the panels, it works. 8)
CH80 Spree
NH125 Spree
PostPosted: Thu Apr 06, 2017 2:14 pm
I bought another parts aero 125 for $100, it's pretty hacked up and has a funny exhaust. I messed around with it enough to hear it fire up 2 seconds, had to jump the ignition switch and put power straight from the battery to the starter. I all ready pulled the engine off, it will be a spare or maybe for another swap someday.
CH80 Spree
NH125 Spree
PostPosted: Sun Apr 09, 2017 1:18 pm
There was white decals on the sides of the floorboard, peeled it all off and painted it. Not my best work but had trouble with the paint sticking so next time I'll have to do something different.
CH80 Spree
NH125 Spree
PostPosted: Sun Apr 09, 2017 8:14 pm
The under glow led lights with the body panels on.
CH80 Spree
NH125 Spree
PostPosted: Mon Apr 10, 2017 4:34 am
:highfive: :highfive:
