Post new topic Reply to topic  [ 148 posts ]  Go to page 1, 2, 3, 4, 5 ... 10  Next
 Post subject: Tyler VR's Honda Aero nb50 to nh125 Swap Project
PostPosted: Sun Oct 09, 2016 9:34 pm
Hello again! This thread will be all about my newest project, a 1987 Honda Aero 50. The plan is to swap an aero 125 engine onto the 50 frame and do some refurbishing along the way.
I was lucky enough to find this aero 50 for only $60, craigslist find. It runs but is making internal noises, maybe a crank bearing. The previous owner over sprayed it with stain while spraying his fence, torn seat and cracked plastics. But for being 30 years old and nearly complete I can't complain much.
CH80 Spree
NH125 Spree
 Post subject: Re: Tyler VR's Honda Aero nb50 to nh125 Swap Project
PostPosted: Sun Oct 09, 2016 9:38 pm
Here's the donor power plant prior to disassembly, a 1984 Honda Aero 125 I picked up for $100.
CH80 Spree
NH125 Spree
PostPosted: Mon Oct 10, 2016 8:22 am
looking forward to this one :popcorn:
PostPosted: Wed Oct 12, 2016 2:30 pm
More pics of the aero, I rubbed off the stain will alcohol.
CH80 Spree
NH125 Spree
PostPosted: Wed Oct 12, 2016 2:34 pm
Cracked plastics need repair, looks like it was laid down on this side.
CH80 Spree
NH125 Spree
PostPosted: Wed Oct 12, 2016 3:12 pm
too bad it was laid down but looks like it ended up in the right home
PostPosted: Sat Oct 15, 2016 6:46 pm
I'll do my best to repair all the plastics, maybe someday I'll find replacements in matching white. :meh:
CH80 Spree
NH125 Spree
PostPosted: Sat Oct 15, 2016 9:33 pm
Pulled the 50 off the aero
CH80 Spree
NH125 Spree
PostPosted: Sat Oct 15, 2016 9:44 pm
First test fit of the nh125, swap looks doable.
CH80 Spree
NH125 Spree
PostPosted: Tue Oct 18, 2016 11:50 am
Comparing motor mounts.
CH80 Spree
NH125 Spree
PostPosted: Tue Oct 18, 2016 2:04 pm
always wonder about this stage of the swap. What are your main goals? bring it in to eliminate
the space or are you thinking about how to make use of the empty space (gas tank expansion).
How important is the rear shock mount? Just wondering- thank you for bringing us along for the ride.
Love watching you work thru it.
PostPosted: Wed Oct 19, 2016 1:37 pm
trueadrn wrote:
always wonder about this stage of the swap. What are your main goals? bring it in eliminate the space or are you thinking about how to make use of the empty space (gas tank expansion). How important is the rear shock mount? Just wondering- thank you for bringing us along for the ride. Love watching you work thru it.
I've been thinking a lot about how I want to do this swap and concluded that I'm not going to do anything too crazy. The motor mock up pic above isn't the angle I want this engine mounted, I was using the stock 50 mount. I'm leaning towards using the parts of nh125 mount, I'll have to cut down a bit.
The shock mounts look like they will land a few inches behind the stock mount, I'll have to plan doing some re-enforcement in that area to strengthen it up.
CH80 Spree
NH125 Spree
PostPosted: Fri Oct 21, 2016 6:34 pm
Cleaned up the dirty engine with my favorite Degreaser.
CH80 Spree
NH125 Spree
PostPosted: Fri Oct 21, 2016 7:47 pm
PURPLE POWER :banger:
PostPosted: Thu Oct 27, 2016 1:25 pm
Started on the motor mount. I cut the nh125 mount down to match length of the stock 50 mount where it bolts to the frame, removed all the brackets. Made my own pieces between the tubes, this should allow me to align the engine.
CH80 Spree
NH125 Spree
Rucksters browsing this forum: fiftytwelve, Skynet Google Overlord[Bot] and 2 guests
