Post new topic Reply to topic  [ 135 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9  Next
 Post subject: Re: Tyler VR's Honda Aero nb50 to nh125 Swap Project
PostPosted: Tue Feb 28, 2017 5:06 pm
first time? wow. what model is similar??
PostPosted: Wed Mar 01, 2017 2:22 pm
My plan is to use performance drive face parts from a GY6 150cc on my nh125, apparently it's been done on elite ch125 and ch150. From the measurements I took compared to dimensions listed online I found the GY6 variator and clutch bell size is close in size, but the splines are different on both the crank/trans drive shafts.
CH80 Spree
NH125 Spree
PostPosted: Thu Mar 02, 2017 3:12 pm
New tires arrived on my doorstep, 90/90 for the front metro rim and 10-3.5 for the nh125 rear rim.
CH80 Spree
NH125 Spree
PostPosted: Fri Mar 03, 2017 6:04 am
Matching FTW!
less than 30 days to Spring Scoot!
PostPosted: Fri Mar 03, 2017 2:03 pm
Here's my homemade air filler rig to pop the tire bead on the rim. Just a chromy valve stem cap I tapped a fitting into with a switch, that way I can fill without a valve stem core. I had this spare nh125 rim that I hammered out a dent on the lip, sandblasted and primed.
CH80 Spree
NH125 Spree
PostPosted: Sun Mar 05, 2017 8:16 pm
Did a little painting.
CH80 Spree
NH125 Spree
PostPosted: Sat Mar 11, 2017 7:37 pm
Got a set of aftermarket shocks, needed to bump the rear up a little for clearance and they should improve my ride quality.
CH80 Spree
NH125 Spree
PostPosted: Mon Mar 13, 2017 2:20 pm
Installed the new shocks, had to space out the top mount otherwise the spring would have touched the tire.
CH80 Spree
NH125 Spree
PostPosted: Mon Mar 13, 2017 2:27 pm
Rides pretty good. Need to redo the center stand though.
CH80 Spree
NH125 Spree
PostPosted: Tue Mar 14, 2017 1:04 pm
:shock: :popcorn:
PostPosted: Thu Mar 16, 2017 1:14 pm
My speedo topped out somewhere between 40-45 mph but I knew I was going faster. Figured out it has a stop on the speedo needle, so cut that off.
CH80 Spree
NH125 Spree
PostPosted: Thu Mar 16, 2017 5:57 pm
:banger: whats left??
PostPosted: Fri Mar 17, 2017 1:15 pm
Plenty of work left to do, I have a couple things planned. I need to do more test runs before I put the body plastics on. But the plastics also need some repair, lots of cracks.
CH80 Spree
NH125 Spree
PostPosted: Fri Mar 17, 2017 3:23 pm
You going to spring scoot?
PostPosted: Sat Mar 18, 2017 1:20 am
I want to go, I still have a couple weekends to make sure my scooter is road ready. But the weather might be a deciding factor, I'm not running an air box so if it's rainy my filter would get wet.
CH80 Spree
NH125 Spree
