Post new topic Reply to topic  [ 113 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8  Next
 Post subject: Re: Tyler VR's Honda Aero nb50 to nh125 Swap Project
PostPosted: Mon Feb 13, 2017 12:42 am
trueadrn wrote:
did you have a wiring diagram for both? outa curiosity did most of the wire colors match?
I downloaded free pdf honda manuals and printed the entire nh125 manual a couple years ago. Here's a link to the manuals, they even have a ruckus one: http://hondaspree.net/phpBB3/viewforum.php?f=11
Most the wires were the same colors, a few had to be figured out. Only popped a couple fuses testing things, once I had a grasp of what needed to be done the wiring went smoothly.
CH80 Spree
NH125 Spree
PostPosted: Mon Feb 13, 2017 8:36 pm
Had to get a longer rear brake cable, first one I ordered was longer than advertised. Second cable fit but metal collar at the end broke after pulling the hand lever couple of times. Hope this third cable is the winner...
CH80 Spree
NH125 Spree
PostPosted: Thu Feb 16, 2017 1:57 pm
Got the supplies to wire up some under glow lights.
CH80 Spree
NH125 Spree
PostPosted: Sun Feb 19, 2017 3:55 pm
I made my own harness for the lights, just need to stick it to the frame.
CH80 Spree
NH125 Spree
PostPosted: Sun Feb 19, 2017 3:57 pm
In the dark.. :mrgreen:
CH80 Spree
NH125 Spree
PostPosted: Sun Feb 19, 2017 6:17 pm
its going to look great with the white panels back on :banger:
PostPosted: Sun Feb 19, 2017 8:41 pm
I just wish the panels were in better condition. I need to fix a few cracks, otherwise the blue lights would shine through all the cracks. :lol: :P
CH80 Spree
NH125 Spree
PostPosted: Mon Feb 20, 2017 2:46 pm
I switched out exhaust from my spree nh125 to the aero, it scrapes the pavement when making sharp right hand turns because the spree sits a little lower. It shouldn't be a problem on the aero and the blue silencer even matches, I guess that means I'll have to make a new exhaust for the spree.
CH80 Spree
NH125 Spree
PostPosted: Fri Feb 24, 2017 3:16 pm
Had a little issue getting the exhaust flange sealed so I ordered a new gasket and this is what they sent me, less than half the thickness of a honda brand gasket. I sent this comparison pic and tried to explain it to the seller, all they said was "The gaskets seals on contact and does not have to compress like the OEM."
PSA: Do not buy gaskets from ebay seller: jaquishmotorsports , he list honda part numbers but sells aftermarket garbage gaskets.
CH80 Spree
NH125 Spree
PostPosted: Fri Feb 24, 2017 4:15 pm
:shock: yikes, those guys pray on the inexperienced
PostPosted: Sat Feb 25, 2017 7:33 pm
Upgrading to a metro front rim with a elite brake hub. The wheel uses a bigger 90/90 tire and the brake is also bigger.
CH80 Spree
NH125 Spree
PostPosted: Sat Feb 25, 2017 7:35 pm
Comparison:
CH80 Spree
NH125 Spree
PostPosted: Sat Feb 25, 2017 7:36 pm
Installed:
CH80 Spree
NH125 Spree
PostPosted: Tue Feb 28, 2017 1:20 pm
Purchased some tune up parts: belt, rollers, spark plug, brake pads and a spare variator that I cleaned the grease out.
CH80 Spree
NH125 Spree
PostPosted: Tue Feb 28, 2017 1:59 pm
Taking apart the drive face, It's over a 30 year old engine and this might be the first time it's been serviced. The belt was pretty cracked, pulleys a little grooved, clutch pads look a little low.
I've been thinking about upgrading the variator and clutch but nobody makes performance parts for the nh125. I've done thing in the past like lighter rollers, lightened the clutch bell, using jog clutch springs. But I would like to do more to improve performance. I've taken a few measurements with my dial caliper and I might take a gamble on running a performance variator and clutch off a different model engine...
CH80 Spree
NH125 Spree
Rucksters browsing this forum: NSA - Echelon and 3 guests
