Post new topic Reply to topic  [ 80 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 Post subject: Re: MetZoomer build "Charcoal"
PostPosted: Sat Jan 21, 2017 9:12 am
Do it the right way first!! :D
Ørjan.
My Builds:
https://goo.gl/j7UWiv
https://goo.gl/crJD5Y
Oslo Zoomer Garage Instagram:
https://goo.gl/1gkUxO
PostPosted: Mon Jan 23, 2017 7:32 am
Started to cut up the harness but first i marked all the cables with a labelmaker.
Messy at first
Cut everything to the right lengt, then started to solder everything back together.
All the cable that was removed
Still looks messy now, but its manageable and the right lengt so I don´t have a lot of spare cable cluttering up the look.
All the connectors that go to all the stuff on the handlebar, blinkers and stuff is channeled in the middle to the front. I will make new cables going from the front down to the connectors, but that won´t happen until the handlebar and everything is ready.
Everything is taped up now and ready for sleeving. I have black split braided sleeving from techflex.
Ørjan.
My Builds:
PostPosted: Mon Jan 23, 2017 8:25 am
Starting to look perfect!
Can You please make soms detailled pictures of the sleeving process?
I really know nothing about that.
Click This For My Ride !
rrpotd
:vondutch: :wavehello
P-Dub wrote:
.......daaaayaaaaaammmm.....
PostPosted: Mon Jan 23, 2017 12:07 pm
You better keep your head straight there ;) :highfive:
Fatty Build "Gustav"
http://totalruckus.com/phpBB3/viewtopic.php?f=94&t=106754
PostPosted: Mon Jan 23, 2017 4:51 pm
Its just sleeving that is cut along the whole length, so you can put it on after the wires are done.
Got the tires mounted today!! Looks great!
Ørjan.
My Builds:
PostPosted: Fri Jan 27, 2017 10:57 am
My O'MET2 Rox :banger:
#METROX2
PostPosted: Fri Jan 27, 2017 11:38 am
Small overview of what it looks like now.
What do you think so far?
Ørjan.
My Builds:
PostPosted: Fri Jan 27, 2017 12:13 pm
Looks great! But that stock rear shock needs something prettier.
PostPosted: Fri Jan 27, 2017 2:43 pm
Yeah its just for mockup now.
Ørjan.
My Builds:
PostPosted: Tue Feb 07, 2017 4:23 am
Awesome work sir!
PostPosted: Thu Feb 16, 2017 11:55 am
KtownMatt wrote:
Awesome work sir!
Thanks man!!
Ørjan.
My Builds:
PostPosted: Thu Feb 16, 2017 5:28 pm
Looks sweet! I wish I could have done that with my harness for my Met-ruck but I didn't get a long enough stretch :/
GET-Express-SR
Marks-Met
PostPosted: Fri Feb 17, 2017 7:54 am
Did you use the met harness? this is the Zoomer harness.
Ørjan.
My Builds:
PostPosted: Fri Feb 17, 2017 3:57 pm
love it.
PostPosted: Tue Mar 14, 2017 11:59 am
It has been a while since last update. Have been busy studying and doing other stuff. Like painting Sylthod´s bike and exhibiting our bikes at Norways bigges motorcycle trade fair.
Got this 2015 wider front fender that works with the Zoomer triple tree. It actually fits like a glove. I will have to make 2 brackets for attaching it, but not a big problem.
Upside down tracker bars. I changed later to a similar but shorter version. Which I also cut down the length on. It looks so wide in the pic.
Bar end mirror mod to fit on the stock controls.
Found a spot for the motion alarm
Made a template for some setbacks to hold pegs. They are going to be plasma cut in 5mm stainless.
Wrapped the headlight with some Lamin-x to make it darker. It was a pain to do since its so convex.
Removing scratches from the Met plastics. Its quite easy actually.
Made a support for the rear of the floorboard and underside plastics. Since I don´t use all the Met plastics it hangs a bit at end. So I was a bit inspired by how racing cars fasten their body panels for easy removal.
Started to complete the electronics box. Started to make the angle bracing.
Then I mocked everything up. The long bolts will not stay. Its just to mock up and see that everything comes together. You can see on the top that I have used pop nuts so that the top cover can be removed easily to get to the electronics.
Last pic from the exhibition.
Ørjan.
My Builds:
