Post new topic Reply to topic  [ 72 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: MetZoomer build "Charcoal"
PostPosted: Wed Dec 21, 2016 12:09 pm
PostPosted: Wed Dec 21, 2016 1:17 pm
Great looking wheels!!! :banger:
2003 Ruckus- Black and Chrome
viewtopic.php?f=92&t=86370
Girl Friends 2003 Ruck
viewtopic.php?f=92&t=89000
PostPosted: Wed Dec 21, 2016 8:52 pm
:popcorn: :popcorn:
LiteW8 wrote:
PostPosted: Thu Jan 19, 2017 11:46 am
I can finally start putting this thing together.
Started with mounting the stretch kit. Bought it used from BJørn (Sylthod)
Got the frames back from powdercoating. Black on black. Matches well with the dorf and the seat cover.
Installed this radiatorcover from MM. I´m probably going to put som mesh sheet behind since the radiator isn´t very nice to look at.
Mocked up the wheels.
Then I started looking at where all the electronics go. Got this bottom mount plate laser cut. It´s just attached for mockup
Probably going to make a cover that mates up with the floorboard to cover up this hole.
All the cables has to be cut and shortened. Going to be a big job.
Waaaay too long.
I´m attaching all the electronics using the old brackets that hold them inside the batterybox. I just make new mounts with these plates that I´m cutting to length and bending. They will be bolted to the bottom mount plate.
Lastly I got this bar that is meant for mounting headlights on bikes. I use it for the speedo
What do you guys think?
Ørjan.
My fatty zoomer build:
http://totalruckus.com/phpBB3/viewtopic.php?f=95&t=97044
PostPosted: Thu Jan 19, 2017 12:02 pm
Nice progress!
PostPosted: Thu Jan 19, 2017 12:56 pm
Amazing brother, I am liking that electronic setup! The bike is outstanding so far. Wait until you see my springtime look lol
Is the case that holds the electronics going to be waterproofed?
Redrucka69 2009 Build
Instagram
Facebook
PostPosted: Thu Jan 19, 2017 2:05 pm
Awesome! Looking forward to see how this turns out! :popcorn:
Fatty Build "Gustav"
http://totalruckus.com/phpBB3/viewtopic.php?f=94&t=106754
PostPosted: Thu Jan 19, 2017 2:36 pm
Thanks guys!!
Well its not going to be totally waterproof, it will be made so that water wont run straight down onto everything. It will be somewhat open under and on the sides to keep everything ventilated. The stock batterybox is quite open to the weather so the stuff inside will tolerate some moisture. I haven´t made a design for the cover going over everything. I just have to get everything in its place first, then I will design a cover. I don´t think its going to be a big issue.
Ørjan.
PostPosted: Thu Jan 19, 2017 4:12 pm
Those wheels and exhaust are SEX!
I love the mounting spot for the ecm...funny because I'm doing a wire tuck on mine and lengthening the wires and now you are shortening yours not fun haha!
PostPosted: Thu Jan 19, 2017 6:50 pm
love it!
48hours of Ruckus Winner
PostPosted: Thu Jan 19, 2017 8:05 pm
Looks nice!! That electronic setup seems big and bulky but looks clean af! Defentily better than what mine will look like!
FatKid's Toys:
Ruckus
MetRuck
Lil Girls Wagon
PostPosted: Thu Jan 19, 2017 8:22 pm
Wow!!
Looks great!! Wheels are awesome.
Really like your idea with the electronics. Got any plans for the empty space under the BB?
PostPosted: Fri Jan 20, 2017 3:35 pm
Yeah it looks a bit bulky now. It´s as small as it can be and the outside dimensions is smaller than the batterybox. I will make a good looking enclosure for it when everything is in its place. I´m now locating where all the wires go before I cut up the harness and shorten it.
Here is some pics from today when I made the brackets holding everything. I used this point welder to attach some plates to the original ecu bracket. I did the same with the other brackets.
and here it is.
As you can see the harness will go between the battery case and the ecu.
Andy643 wrote:
Wow!!
Well I´m making a Metzoomer so the batterybox will be removed and the Metropolitan plastic will be there. Not much room left there. So that´s why I´m moving the electronics.
Ørjan
PostPosted: Fri Jan 20, 2017 4:03 pm
Jedi wrote:
love it!
Thanks man!!
Haha yes, I had to lengthen on my other zoomer. So this is something else, a lot more wire work has to be done! I will have to extend some wires that will go up to the handlebar and switches and stuff.
Ørjan.
PostPosted: Fri Jan 20, 2017 7:17 pm
and here it is.
Ørjan
Looks clean bro!! Great idea with the ECU!! i was just going to bolt mine to the underside of my floor boards but this makes me want to up my game!!
FatKid's Toys:
Ruckus
MetRuck
Lil Girls Wagon
