Post new topic Reply to topic  [ 47 posts ]  Go to page 1, 2, 3, 4  Next
The way it should be Shop mechanic
 Post subject: Met Life Updated Pics Page 3
PostPosted: Sun Feb 08, 2015 9:58 am
Was looking for a met for awhile and ending up finding one for sale in Maine mostly already done up. The seller happened to be Mr Stiffy His Build Thread Pic from the CL add
MOD LIST:
Lowered Front Forks
OEM ghost met plastics
E3 Spark Plug
Hi temp coil
Ruck Swingarm
Polini Vari
OEM bando belt
Dr.Pulley 4.5g
Met Gears
Stock clutch
Posh cdi
Ronk stack intake
Yosh exhaust
Wideband tuned carb 72/75 idle 12.5 WOT 12.8
SL26 F: 90/90-10 Kenda R: 120/70-12
Top Speed: 51.6 flats @ 9200rpm
Trail tech tto
Got it home and started to take her apart
Shes a hardtail with lowered stock forks. pic for reference. Currently working on adding rear suspension hard tail was too hard
Ordered a set of new plastics from Honda and holy shit are they expensive!!
Wheels are still purple waiting on new sl26's and need to drop wheels off at powdercoat. In the mean time I added a 5000k HID. Video Link below:
HID's running
Wired directly to battery. No relay. No flickering
Still need to install stock met turn signals, taillight, daytona shock and find and exhaust. More to come :banger:
Met Build
 Post subject: Re: Met Life
PostPosted: Tue Feb 10, 2015 10:46 pm
Just saw this. I dropped the same $ on the plastics, same color. Lookin good. :highfive:
My Met Build
Cracka Jacked viewtopic.php?f=92&t=50500
"Never run out of real estate, traction and ideas at the same time." - Mario Andretti
PostPosted: Wed Feb 11, 2015 10:25 am
thanks man :highfive: your build was def my inspiration. beautiful met :banger:
Met Build
PostPosted: Fri Mar 20, 2015 10:12 am
Wheels are done
Suspension finished for now
Plastics are almost finished
Met Build
PostPosted: Fri Mar 20, 2015 10:32 am
Not much of a fan of the Met's, but that one cleaned up nice 8)
PostPosted: Fri Mar 20, 2015 10:57 am
Thanks man appreciate it! Purple wasn't doing it for me
Met Build
PostPosted: Fri Mar 20, 2015 11:04 am
what do plan to do with the old plastics ? i might be interested in a few pieces.
http://www.steadygarage.com/2013/06/03/ ... aust-work/
My MET build viewtopic.php?f=96&t=88138
PostPosted: Fri Mar 20, 2015 3:24 pm
Looking good! All white is my fav! :banger:
Instagram: Zschrubb
Ruck build/Scooter pic thread
DIY - $48 fatty, stretch, chin bone, exhaust, slammed front forks, lowered seat:
viewtopic.php?f=96&t=45778
PostPosted: Fri Mar 20, 2015 4:16 pm
Great work! I have been thinking of doing my wheels black. Yours turned out great.
My Met Build
PostPosted: Fri Mar 20, 2015 7:22 pm
Thanks man! Your met came out amazing!
Met Build
PostPosted: Fri Mar 20, 2015 7:24 pm
Thanks dude! Wet black is the powder color btw is your atr the lowdown?
Met Build
PostPosted: Fri Mar 27, 2015 10:30 am
Finally got the chance to work on the met.
Oem turn signals and speedo cover installed. Painted wet black to match rims
Quick hook up of Radiantz tail light
Radiantz
Threw the stock exhaust back on for now. Radiantz tail light installed dont mind the sticker goo or the at home drug test kit :lol:
Installed carbon black RonkStack but forgot to take pic
Met Build
PostPosted: Fri Mar 27, 2015 10:58 am
Looking good man :highfive: what led relay are you using for your turns signals? i used this ep36 led relay and it solved my problems 3 prong system. those radiantz strips are awesome i have an 11" or so and i put it on my grab bar. why didn't you keep the exhaust that was on it when you got it?
PostPosted: Fri Mar 27, 2015 11:02 am
thanks homie :highfive: i'm not sure on the relay. When I bought the met it had a turtlehead on it that worked perfectly. I'll have to check and let you know
Met Build
PostPosted: Mon Mar 30, 2015 2:38 pm
Ultra seller decided to keep exhaust. Currently looking at drd and hmf
Met Build
Rucksters browsing this forum: No rucksters and 5 guests
