Post new topic Reply to topic  [ 157 posts ]  Go to page Previous  1 ... 7, 8, 9, 10, 11  Next
 Post subject: Re: Metro Build On The Cheap FATTY INSTALLED Pg 8
PostPosted: Wed Apr 02, 2014 10:25 pm
hopefully im done now
got in the neon green powder today and went crazy painting bolts and nuts
whats cool is the led lights I have on the bike the purple color I can select is close to black light color
so the green glows
its not glow in the dark, just glows under the purple color light
PostPosted: Thu Apr 03, 2014 11:09 am
PostPosted: Fri Apr 04, 2014 1:47 pm
Looks great. What you did to the CVT casing is pretty slick looking. :highfive:
In fo' mo'. :popcorn: :popcorn:
something something DAARKSIDE. something something COMPLETE
http://totalruckus.com/phpBB3/viewtopic.php?f=93&t=70621
* * * CHICAGO SPEED CAMERA -MAP * * *
http://abclocal.go.com/wls/feature?section=news/local&id=9203444
PostPosted: Fri Apr 04, 2014 6:32 pm
thanks
cvt was easy
just cut a big hole and die grind out clean
and the slots was just a drill and dremmel
was thinking sandblasting piece of lexan gluing behind the slots
and add led strips inside the cvt somewhere
will make a nice even window of color shining out
of course you can go crazy making nice lines all over
but I figured my luck I would break a piece so I stopped
PostPosted: Thu Apr 10, 2014 2:59 pm
new carb
works really well
PostPosted: Thu Apr 10, 2014 4:36 pm
How much of a difference is the new carb? I've read if your light like me that it wouldn't really make a difference
Also your met is looking damn good.
Serenity 09 Met
2006 Legacy
PostPosted: Thu Apr 10, 2014 4:42 pm
I have never read that being light on a 50cc scooter is anything bad
its always better to be light
im not light, and the carb has much more power
especially on the hills
but I have to keep in mind im still using stock exhaust so cant expect wonders to happen
im going to try zuma clutch springs next but so far its a good mod that shows performance unlike so many others out there that dont really do much
PostPosted: Thu Apr 10, 2014 4:57 pm
Wasn't really like a bad thing more of a not worth the money cause I wouldn't see any difference. But I guess the only real way to find out is to GET one. With your stretch you are able to run the cable with out having to cut the seat bucket?
Serenity 09 Met
2006 Legacy
PostPosted: Thu Apr 10, 2014 5:02 pm
yeah no cutting
the throttle line clears the seat storage by at least an inch maybe
actually looking at the picture its pretty close
I think I need to check how it is when I sit on the bike
but I had no problems with it
and long enough too
no binding and I ran it pretty wild
wasnt trying to get the most out of it
but I did have to install new fuel line, even with the stretch I was using the stock line but it was really tight
this carb the line is on the other side so I had purchased some clear blue last week for this install
this was the cheapest clear/colored line I could find and came in 2 days with amazon prime too
http://www.amazon.com/gp/product/B002ZTGLFC/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
perfect size 3/16
and have a couple feet left over
I
PostPosted: Thu Apr 10, 2014 5:10 pm
When I first started looking into this carb I saw the under seat storage bin cut for the line and I don't want to do that. Probably going to look into this after I finish my mini fatty and stuff up... I need another job just for my met lol
Serenity 09 Met
2006 Legacy
PostPosted: Thu Apr 10, 2014 5:26 pm
what you saw may have been shorter stretches like the atr 5 inch
and maybe pasword jdm 6 inch cant say for sure
or no stretch at all
like you can see mine barely clears but I have a 7 inch stretch
PostPosted: Thu Apr 10, 2014 10:21 pm
I watched the suspension move
its strange it looks like the carb moves down when I sit on the bike
which is good no chance of it ever hitting
maybe the carb is after the pivot point of the engine so it does move down
I thought it would move up
had let it sit for a couple of hours
might of been like 70f outside
started and idles pretty rough for a few min
tried the choke but couldnt get any better, idling
wish it had an enricher instead of the choke
those always seem to force them to idle faster to warm up faster then a choke blocking off the air
rode just fine no missing or whatever
guess im just used to the auto choke kicking on when it needed it
still can reach the choke lever easily
real test tomorrow when its been sitting over night
PostPosted: Fri Apr 11, 2014 5:21 pm
morning start bike takes a while to get started
even fiddling with the choke
luckily I can work the lever no body panels were in the way
once it gets running its super low idle around 1100 rpm
takes a good 5 min until idle goes faster
you could just hold the throttle a little higher by hand to speed up the warmup
but I wanted to see if it would run that low, it does
after 5 min warmup its fine
maybe next time I will start it and ride, see how it acts if it dies on the road
PostPosted: Sat Apr 12, 2014 2:28 pm
yeah new carb sucks when cold
I let it run long enough to gear up and drove off
any stop it would die
took a while maybe 1/2 mile until it was warm enough
so just have to let it idle for 5 min before riding when its cold
put on new kickstand today
like how its tucked up higher then my old one
PostPosted: Sat Apr 26, 2014 1:07 pm
added a rear fender using the brandonryan mount
