Post new topic Reply to topic  [ 312 posts ]  Go to page 1, 2, 3, 4, 5 ... 21  Next
 Post subject: Mugen76's Lambo Ruckus - SCTV Magazine Feature - Page 20
PostPosted: Wed Aug 17, 2011 7:43 am
June 2013 Update
Bike is finished!! Big thanks goes to: Kevin @ Steady Garage for resurrecting this corkscrew header. i fell in love with marble madness several years back and he was kind enough to build another one but this time with the Steady Garage shorty muffler. Go check out their site for fantastic custom work. I'd also like to thank Dorbyworks for the rims, drowsports and scooter elements for the taida engine parts to build this 206cc that I handbuilt (A-case gy6 beast), rucksters customs for the foot pegs and ratkoubou parts, killerscooter steven for shipping out this beautiful handlebar, Evan at FLP for my rear disc hub setup, composimo for his billet mount, swaptchicago and standard functions for a slew of other parts that helped with the wiring and brake lines.
it's nothing original. you all have seen a similar header before. If you guys know my other Topsecret Gold bike, i followed a similar formula b/c it's something I really liked building and i wanted to do something similar. but this time, i wanted it to be much faster and a little more flashier. i chose to avoid electronic gauges on this bike b/c i wanted to keep it simple. all i wanted was a large displacement gy6 - just me, the bike... and the road. plain and simple.
enjoy the new look of the bike!
wallpaper size:http://farm8.staticflickr.com/7459/9315813877_0bc3943046_k.jpg
New mod list version 2:
Engine and performance:
206cc oil cooled gy6
A-case gy6
Taida 63mm high compression, forged piston
Taida large valve head 30.5/26.5 valves
Custom stage2 port and polish
Taida titanium retainers
Taida 14k valvesprings
Taida t300 (wpc treated)
Taida valve cover
Taida 8.2mm stroker crankshaft (wpc treated)
Taida high torque starter motor
20pin starter clutch
Dr pulley variator w/14gr
Dr pulley clutch w/Ncy ball bearing secondary ramp
1500 compression spring
Gates Kevlar belt
16/36 final drive gears
NCY oil cooler kit
Custom big bore flange, corkscrew exhaust by Kevin at Steady Garage
Motul 10w-40 double ester oil
Shoes, stoppers and suspension:
Dorbyworks polished DW7RS 12x4, 12x8
Maxxis 100/65 front
Heidenau 140/70 rear
RRGS lowdown front shocks
ATR powder coated rear shock
Composimo soft lowering springs
RRGS front axel
RRGS 260mm front rotor
RRGS 220mm rear rotor
RRGS PH80 caliper front and rear
Frando front brake line
Russel rear brake line
CNC billet master cylinder/levers
Motul 5.1 brake fluid
Body and accessories:
KillerScooter handlebar polished
Japanese Np-3 billet grips
Crg 2" bar end mirrors polished
Chrome dipped front frame
FLP front cover chrome dipped
Front wire tuck
rPro monster kicker pegs front and rear polished
rPro stiffler bar polished
Voodoo factory Lamborghini purple paint job.
Composimo billet gy6 mount
EDIT: Winter 2012/2013 Lambo Ruck project v2.0 - bike being repainted, new mount, new rims, building the motor to 206cc with a taida 63mm, taida 8.2, and fully ported Taida head. parts are slowly coming in and everything is starting on page9.
here's the new color. based off a lambo diablo purple:
Everything from here and below was Version 1
Lambo Gallardo Yellow v1.0 build:
The ride is basically finished...for now. (is it ever really finished!?) For a stock 150cc GY6 with a big carb, cam, ported head, cdi and full Dr. Pulley cvt kit, it ran like a beast. It consistently ran in the low 70's all day long with a topspeed of 73mph on flat. I took this bike on several long journeys one being a 200 mile round trip in one day. I went through two accidents with the bike, both being freak accidents. It served it's time. I built a second ruck so this one will be retired and rebuilt soon!
I appreciate your comments on this build.
Complete version 1 Parts List:
Engine & Performance
150cc GY6
CVK 30mm carb w/velocity stack
NCY electroplated valvesprings
Motorio Titanium retainers
NCY flat valves
A12 cam
DrPulley variator/weights
DrPulley Clutch
NCY Compression spring
Custom lightweight clutch bell
Gates kevlar belt
Short Axle
11-pole Stator/regulator
Ballistic 275cca lithium battery
Front frame tuck
NCY CDI
NCY heavy duty starter clutch
Taida starter motor
killerscooter mount
Wheels/Suspensions/Brakes:
Dorbyworks custom 12"x3" 8-hole front and rear rims
100/60 front tire
Pirelli SL26 rear tire
Dorbyworks custom rear hub
ATR rear shock
RRGS adjustable drag low front fork
RRGS v1 caliper
RRGS 220mm rotor
RRGS 12mm axle
RRGS spacers
RRGS axle pullers
Stainless steel braided line
NCY titanium rotor bolts
NCY rear brake pads
CRG billet brake levers/master cylinder
Body & Accessories:
rPro stem
Emgo drag bar
Kajima foam grips
NCY throttle
Gy6 controls
Daytona BSC mirrors
Kajima amber front turn signals
Gojin dress up bolt kit
MOJO License Plate Mount
Wrenchwerks gas cap
Dorbyworks foot rest
Daytona low kickstand
NCY v1 fuel tank cover
R6 taillight w/batman R6 mount
Rigid Industries Dually D2 35w LED Head Light https://rigidindustries.com/v/products/gallery/lightcomparison.html
FLP custom painted front frame cover
FLP custom painted splitter cover
shaved rear frame
shaved seat frame
Ruckur Bride wrapped seat w/custom memory foam
custom painted front frame w/wire tuck
Lamborghini Giallo Midas (yellow) paintjob
Latest pics: July 2012
topspeed run on 150cc w/upgraded 30mm carb/headwork/a12 cam.
Old pics:
Check out this commercial for http://www.equnit.com. They used mine and dcee1's ruckus' for the shoot.
old pics:
gy6 w/ killer scooter mount:
shaving the rear frame:
painted head
parts back from paint:
ATR v1 (for sale) RRGS 4 pot caliper/rotor
FLP mikuni mounted
11pole stator installed
Drag bar, CNC billet levers, kajima foam grips
mockup: sold the ATR v1 forks for RRGS.
TopSecret Gold 187cc Ruckus: http://totalruckus.com/phpBB3/viewtopic.php?f=94&t=64657
LamboRuck 232cc: http://totalruckus.com/phpBB3/viewtopic.php?f=94&t=60497
 Post subject: Re: mugen76's lambo yellow ruckus
PostPosted: Wed Aug 17, 2011 7:44 am
UPDATED: (Current as of: 12/18/11)
- low profile front kenda installed (100/60/12tire)
- Daytona bsc mirror
- Daytona kickstand
- BTX exhaust installed (for sale)
- performance cdi installed
- spoon brake reservoir wristband installed
- bride streamline seat installed
put the yoshimura back on for the winter to keep night rides a little quieter:
big thanks to all these friends and vendors for all the help and support: SwaptChicago, DorbyWorks, StandardFunctions, LoSGarage.
v2.0 build starting here: http://totalruckus.com/phpBB3/viewtopic.php?f=94&t=64657
PostPosted: Wed Aug 17, 2011 7:52 am
god i love that yellow :banger:
a clean scoot is a happy scoot!
Riva Ruck Build
My Rowdy Riva Build
PostPosted: Wed Aug 17, 2011 7:56 am
NICE
Looks fuckin balls bro :banger:
PostPosted: Wed Aug 17, 2011 8:21 am
nick ruck! :mrgreen:
Love the profile!
Project B.A.A.R. - Click it!
http://totalruckus.com/phpBB3/viewtopic.php?f=96&t=32267
PostPosted: Wed Aug 17, 2011 9:28 am
these pics kick some serious ass!
chitownruckus.com
swaptchicago.com - store OPEN!
instagram : swaptchicago
PostPosted: Wed Aug 17, 2011 9:42 am
thanks man... great job on the build. the new exhaust gasket worked and it's running like a champ. we'll see how long it lasts tho.
PostPosted: Wed Aug 17, 2011 9:45 am
Awesome looking ruck bro.
viewtopic.php?f=95&t=65664 Godzilla
viewtopic.php?f=95&t=76464 Russian Roulette
PostPosted: Wed Aug 17, 2011 10:09 am
Wow! I love almost everything about your bike! I love yellow. The mods work well together. The only thing I dont get is your pipe angle. It hurts my eyes. :wasted:
KCCO
Proj: °Cream Smoothy° (Compos!mo Build)
Click to follow me on Instagram
PostPosted: Wed Aug 17, 2011 11:07 am
yeah but now you can see the back wheel. :wink:
PostPosted: Wed Aug 17, 2011 11:10 am
Fair enough. I love this bike then!
KCCO
PostPosted: Wed Aug 17, 2011 1:45 pm
yellow model chick
yellow bottle sippin
yellow lamborghini
yellow honda ruckus
-14 Grom
-09 ruckus gy6 fatty
-09 ruckus gy6
JRxIERxKNxSG
PostPosted: Wed Aug 17, 2011 2:30 pm
looks great man, super clean!
My Scoot.
viewtopic.php?f=95&t=37866
PostPosted: Wed Aug 17, 2011 3:48 pm
ezekielwhore wrote:
yellow model chick
yellow lamborghini
yellow honda ruckus
LOL.awesome.
PostPosted: Wed Aug 17, 2011 7:57 pm
clean build man!!! every part off it is total sickness :banger:
you should get bar ends and put them on the open end of the seat frame :D
who stiched your seat they did a killer job!
MY RUCKUS BUILD, DISMANTLE AND BUILD AGAIN
viewtopic.php?t=48951
http://www.facebook.com/pages/FLP-engineering/150709785012184
http://www.facebook.com/FLP.MOD
