Post new topic Reply to topic  [ 31 posts ]  Go to page 1, 2, 3  Next
 Post subject: My ruckus progress!!!
PostPosted: Sun May 22, 2011 8:01 pm
So i found a 03 ruckus for a very good price... However it has been abused :( It hasn't been ridden in like 2-3 years and was left in a shed in some small town...
I brought this out of whim and have been working on it with my dad alot... It is our weekend project. Some classic father and son bonding time :banger: .
Here when i picked it up... as you can see the photo editing made it better then it really is... it was covered in dirt.. missing parts... had a broken blinker... missing battery cover...
Here is what i picked it up in... guy couldn't believe i stuffed it in there lol.
Here it is when we started to tear it apart to show it alot of TLC!!!!
advice from old man... " Dont do it on my cement!!!"
This is the tank after... It was horrible before... covered in dirt and had rust around it... we cleaned the crap out of it!!!
viewtopic.php?f=94&t=57508
by build!
 Post subject: Re: My ruckus progress!!!
PostPosted: Sun May 22, 2011 8:09 pm
As many of you are aware I've been snatching parts up from the forums left and right!!!! New ecu.. pump.. stator... battery box cover... exhaust...variators...extension kit..carbs...bars and stem and other misc parts...
When i first brought it the ecu was shot or so i think it is... since i plugged in a new ecu (08 ecu) i got it to turn over and produce spark... replaced all the fuse and relays...
dissassemble the swing arm... and gear box... cleaned everything... you wouldn't believe the crap that came out of that thing... the gear oil was black.. white and had water in it... So i cleaned the gears and replaced all the seals... Gears checked out good just the fluid was looking pretty bad...
Took the engine apart and plugged up all holes and put some engine degreaser on it and got it all shiny and cleaned up... major tlc with a tiny bristle brush....
All the rust on the frame was sanded off and new wire looms were placed in.
Finally got it to start!!! the ghetto way... i had to gravity feed the fuel into the carb... engine still runs strong and like a champ! However i'm still have a problem with the fuel pump which i'm hoping the stator will fix.
I'm planning to paint it flourescent green.. and wrinkle black on the front frame.
more pics soon on the updated progress...
by build!
PostPosted: Sun Sep 18, 2011 7:08 pm
updates!
So i brought another ruckus with a 2t swap... tore it down since the engine had a bad piston from not being tuned to well.
http://a7.sphotos.ak.fbcdn.net/hphotos- ... 7388_n.jpg
started to tear the frames apart to get it powdercoated!
started to assemble the kawasaki green one.
also redid the wiring harness and cleaned it up a good bit to tie up the lose ends.
Started to assemble the other one and using the spare stock engine instead since i'll be building the 2t properly now with all the goodies.
by build!
PostPosted: Sun Sep 18, 2011 7:13 pm
started to assemble the 2t frame with stock motor since i'll be building the 2t engine properly with some good stuff!!!
painted the battery box with some tamiya kawasaki green paint... shits is expensive as hell and 2 bottle was barely enough.
started to do the LED turn signals and r6 tail lights with custom plugs (pci express plugs :banger: ) and custom mounts
Brought another new battery box for the other ruck... kind hate having to cut and paint it since its so new!!!!
All the inspiration and advice came from the forums! great place for info and tips!
by build!
PostPosted: Sun Sep 18, 2011 7:16 pm
keep up the great work! and keep posting pics. :banger:
[/quote]mad hate, its a fucking scooter, sorry its not to your standards brah[/quote]
PostPosted: Sun Sep 18, 2011 7:24 pm
Im feeling that color.... Looking Ruckin sick
viewtopic.php?f=95&t=65664 Godzilla
viewtopic.php?f=95&t=76464 Russian Roulette
PostPosted: Sun Sep 18, 2011 7:42 pm
nice progress! i like where this is going...
viewtopic.php?f=93&t=61225
^ Lady Trouble ^
http://www.scgcreations.com/
PostPosted: Mon Sep 19, 2011 9:25 pm
hold up, this isnt a build thread. its a Builds thread. thats rad.
heres Dirt McGirt a ground up resto Zuma
http://www.zumaforums.net/phpBB3/viewto ... =50&t=9837
and heres my Italjet Dragster
http://www.zumaforums.net/phpBB3/viewtopic.php?f=50&t=19364
Rebels Till Death
WallRockKids
DeadBeats
PostPosted: Wed Nov 09, 2011 8:07 pm
Some updates on the budget 2-Smoke!!! and a special vid!!!
BigBore in!!!
head off!!
Money shot!!!
Ready to go!!! A Legit Yamaha 2 Stroke!!!!
assembled!!!
now the first startup!!!!!
<object width="224" height="400" ><param name="allowfullscreen" value="true" /><param name="movie" value="http://www.facebook.com/v/10100327915177269" /><embed src="http://www.facebook.com/v/10100327915177269" type="application/x-shockwave-flash" allowfullscreen="true" width="224" height="400"></embed></object>
I modified my ATR extension to fit the 2-stroke.. Fits pretty good and everyting lines up right in the middle after adding some washers...
by build!
PostPosted: Wed Nov 09, 2011 8:49 pm
How are you liken those cylinders?
PostPosted: Sun Nov 13, 2011 9:34 pm
its pretty good i haven't had any problems.... yet... lol
by build!
PostPosted: Mon Nov 14, 2011 9:11 am
Heck yeah, more and more 2strokers! Frame colors are cool.
build thread:
http://totalruckus.com/phpBB3/viewtopic.php?f=94&t=77405
Affiliated with Ruck1Built
PostPosted: Wed Jan 11, 2012 12:03 am
“I know that you believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant.”
250cc swap
http://totalruckus.com/phpBB3/viewtopic.php?f=8&t=66315&start=0
PostPosted: Fri Mar 16, 2012 3:56 pm
updates!!! just picked up another ruckus and another zuma!!! for a third ruck... this hobby is getting expensive!!!
parts of ruck #3...
zuma 2t..
athena 70cc
dellorto black 19mm
malossi delta clutch
malossi multi vari
home made harness
fairly orange BB
fairly ornage frame
bmw bar and stem
custom mount
pics soon!!!!
haven't decided on exhaust yet...
zuma front end also!!!
by build!
PostPosted: Sun Mar 25, 2012 8:35 pm
here are some pics as well as a couple of updates!
seems like a new box comes everyday!!!
oh so shiny!!!
nothing like the feeling of a made from scratch harness...on to of a freshly powdercoated frame! :wasted:
Tapping the vacuum fitting it is a 10-32 vacuum fitting you can get at a hobby store if you guys are wondering...
almost done!!!
had to tear open the brand new dellorto 19mm black edition carb i brought from drowsports supposedly for a 2t... however it came with a 4t atomizer... failed on their part...
hopefully they will do me right and give me the proper parts so i can get this thing on the road!!!
almost!!!
my hardwood garage floor...
Image 8)
me getting caught riding dirty with both of my ruckus...
or not!!! turns out he was a cool guy!
by build!
