Post new topic Reply to topic  [ 22 posts ]  Go to page 1, 2  Next
 Post subject: Orange 2011 new build
PostPosted: Tue May 31, 2016 5:31 am
Will I finally did it and bought a 2011 Ruckus. Finally found an orange one! So far I haven't done anything to it but I have ordered a bunch of parts.
 Post subject: Re: Orange 2011 new build
PostPosted: Tue May 31, 2016 5:46 am
[url=http://s77.photobucket.com/user/crazy56belair/media/Mobile%20Uploads/image_3.jpeg.ht[URL=http://s77.photobucket.com/user/crazy56belair/media/Mobile%20Uploads/image.jpeg.html]Image[/url]ml]Image[/URL]
PostPosted: Tue May 31, 2016 5:49 am
Well I did find one issue with the bike. Looks like the headlight frame is bent. I guess it was dropped at one point. I already ordered another one and I'll shave it when I get it! I also need some hardware for the battery box there is a screw missing from the bottom.
PostPosted: Tue May 31, 2016 7:28 am
Im not seeing the bend but I'll trust you.
Meet Black Letty
viewtopic.php?f=95&t=89224&start=0
PostPosted: Fri Jun 17, 2016 8:22 pm
That's what she said.....
PostPosted: Thu Jun 23, 2016 5:46 am
Its on the right side on the flat bracket the horn bolts to. But its been replaced now.
PostPosted: Thu Jun 23, 2016 6:26 am
Well I've been busy and out of the country but here is my progress. I've added a variator intake and exhaust. I also rejetted the carb and it seems to be running pretty good. Next up was cosmetics. New handle bars (carbon fiber) with a bike stem. Shaved turn signals front and back, r6 taillight, speedo mounted in the battery box, lower seat frame, pegs, fender delete, and a few other things.
[URL=http://s77.photobucket.com/user/crazy56belair/media/Mobile%20Uploads/image_7.jpeg.html]
Image[/URL]
[url=http://s77.photobucket.com/user/crazy56belair/media/Mobile%20Uploads/image_5.jpeg.html][img]
PostPosted: Thu Jun 23, 2016 8:09 am
Nice clean look. Good job.
Meet Black Letty
PostPosted: Fri Jun 24, 2016 11:33 am
Looking good man! What's next!
PostPosted: Fri Jun 24, 2016 6:09 pm
Yea dude, looks good. What you use for the "black eye"? Let me guess, pimp slap dat ho?
PostPosted: Mon Jun 27, 2016 10:36 am
LMAO Just some vinyl tint I had laying around.
PostPosted: Mon Jun 27, 2016 10:45 am
Put a NCY stretch on it. It looks like it has the normal lean to the wheel that is a problem with this kit but it's so small I can't really tell. Also I shortened the intake tube and went from a 85 to 82 main jet. It isn't running lean from the plug but the power at 7500rpm seems to have dropped a little bit. I ordered some 5.5 sliders since I'm running 5.9 right now.
PostPosted: Sat Jul 02, 2016 12:56 pm
Well here is a little update I added a Doppler shock, custom made license bracket and some biltwell grips! Oh and have a neon led kit and renegade stereo coming! The bracket I cut the sides of the original and bent it down. Then bought a Harley bracket off revzilla and trimmed the top, drilled and tapped it, and painted it black. The Doppler is so close to the tire I'm a bit worried. Also it seems my ncy stretch has a bit of a lean to it or its just me. It's not bad so I'm not going to mess with it right now. I also have Michelin bopper tires here just need the time to mount them.
PostPosted: Sun Jul 03, 2016 8:21 am
Got my bopper tires on today because my Doppler was rubbing the oem tires. Well it seems my back wheel is a bit bent. The gap goes from a quarter of an inch to an 1/8th of and inch. Anything I can do to straighten the wheel?
PostPosted: Fri Jul 22, 2016 11:34 am
Well a little update. I installed 5.5 gram sliders and it has killed my top end a bit. (not from running out of RPM but from not having any power at 7500 rpm and it not gaining any rpm.) I had 5.9 rollers in it before which I'm guessing being rollers not sliders made a difference.. So I ordered some 5.0 sliders. While I was at it I ordered a Kevlar premium gates belt and a polini blue clutch spring. This week I installed my feign blaster CDI. I have it by the gas tank but need to find a better mount. Also I installed a renegade motorcycle stereo with two speaker pods under my seat and the amp In the battery box. With a on off switch by the key. I also installed neon leds that I can go thru all the colors.
