Post new topic Reply to topic  [ 277 posts ]  Go to page Previous  1 ... 14, 15, 16, 17, 18, 19  Next
 Post subject: Re: Happypancake! Met Build - Big Bore - Shorty Fatty
PostPosted: Sun Jun 25, 2017 2:49 pm
Happypancake! wrote:
Coincidence? I found the crack after I found the bell.
no!
PostPosted: Wed Jun 28, 2017 12:57 pm
Should be back in business soon
PostPosted: Wed Jun 28, 2017 1:55 pm
Remember how much bubblewrap I used on the other? And it broke anyway, damn gremlins. This one looks much nicer
King Ghidorah
ultramagnus wrote:
PostPosted: Wed Jun 28, 2017 2:45 pm
Yeah. If you don't tighten bolts evenly on cast stuff it tends to crack.
PostPosted: Fri Jun 30, 2017 7:08 pm
Back together, tuned and ready to roll.
PostPosted: Fri Jun 30, 2017 7:31 pm
sure looks clean. need to get some road dust on that.
PostPosted: Sat Jul 01, 2017 6:56 am
Some Goodies from Japan.
95mm drive face with nipple shaved. Looks like the venom i bought a while back.
My modded face nipple height @ 8.54 mm. 95 mm faced height 7.17 mm.
372 g bell (stock is 478 g). Bad news is it has that rough lining on it. I'll need to sand off as it will destroy clutch pads.
Both came with nice spacers and stickers!
Last edited by Happypancake! on Thu Jul 13, 2017 6:17 pm, edited 4 times in total.
PostPosted: Sat Jul 01, 2017 7:15 am
I'm glad the quest for speed is still with you. one of the few to still be trying new things.
HUGE pat on the back. Motivates me.
PostPosted: Sat Jul 01, 2017 7:38 am
Thanks Jedi. FB doesn't really lend to following builds.
I think a Metruck will be a new build soon.
PostPosted: Sat Jul 01, 2017 12:18 pm
Were you able to buy the drive face separately? I searched all over and couldn't find one. WeBike used to list one, but I couldn't get any specs from them, and last time I checked they had removed it. Would be interested to know where you got yours!?
my damaged buildthread
PostPosted: Sat Jul 01, 2017 1:14 pm
Tuned. Still may a bit lean at WOT. :D. 55 is my nemesis w/ this fat ass rear wheel.
PostPosted: Sun Jul 02, 2017 10:04 am
55 is moving on the GET love it I need to get to work on mine!
PostPosted: Sun Jul 02, 2017 11:08 am
Used 80 grit flapper wheel on a Dremel to GET the coating off.
Still only a slim line on variation.
Last edited by Happypancake! on Thu Jul 13, 2017 6:20 pm, edited 2 times in total.
PostPosted: Sun Jul 02, 2017 12:18 pm
Curious how you might run with the fins shaved off the drive face for lower rotational mass.
I was pleasantly surprised when I added that to my mix.
PostPosted: Sun Jul 02, 2017 12:53 pm
I have one with the fins shaved but not the nipple.
You have to use a ratchet strap to hold it when taking in on/off.
