Post new topic Reply to topic  [ 220 posts ]  Go to page Previous  1 ... 11, 12, 13, 14, 15
 Post subject: Re: Happypancake! Met Build - Big Bore - Shorty Fatty
PostPosted: Tue Jan 31, 2017 9:00 am
Happypancake! wrote:
Picked up a 4 valve Zoomer head, cam and piston. I'll do some comparison measurements this weekend. It will need the fuel injector hole plugged and re-fit the thermostat for it to work.
Anyone have a Zoomer Service manual. I want to check the cam lobes.
https://www.dropbox.com/s/1941en4a4lokcsi/Zoomer%20Manual.pdf?dl=0
You think a performance camshaft could work with that 4 valve head...?
My Fatty Custom Chick
PostPosted: Fri Feb 03, 2017 8:34 pm
Honed cylinder while waiting for parts
Build thread : viewtopic.php?f=93&t=95381
PostPosted: Sat Feb 11, 2017 7:49 pm
Still playing around with the zoomer 4 valve head and use w/o the EFI. Turns out the zoomer piston is 37.975mm vs Ruck @ 37.777. Zoomer cylinder ID @ 38mm vs ruck @ 37.800mm. So a zoomer 4 valve piston wont fit in a ruck crankcase. Do I bore the ruck cylinder to fit the 4 valve piston or just run the 2 valve piston with the 4 valve head?
PostPosted: Sat Feb 11, 2017 9:46 pm
bore ! :banger:
PostPosted: Mon Feb 13, 2017 8:56 pm
I have a cylinder (whole motor and swingarm) you're welcome to for a spare, just pick it up. The crank has bad threads where the variator would bolt on. If you feel obligated bring beer.
LR
PostPosted: Sat Feb 18, 2017 4:39 pm
Finally had a few minutes to put it back together.
PostPosted: Sat Feb 18, 2017 6:43 pm
I think you would need to run the four valve head with the piston. Reason being, valve clearance. Don't want piston to kiss valves the first time you try and turn it over. Bike looks sic, by the way.
TT-350z wrote:
Build Thread
PostPosted: Sat Feb 18, 2017 6:46 pm
thx 89. I measured the clearance and it's a no go. Sending it off to US Chrome.
PostPosted: Wed Feb 22, 2017 1:27 pm
Digging the new paint. Look mean :banger:
METROD49 Build
viewtopic.php?f=95&t=95633
PostPosted: Wed Feb 22, 2017 1:36 pm
X2 that looks awesome :banger: :highfive:
