Post new topic Reply to topic  [ 278 posts ]  Go to page Previous  1 ... 15, 16, 17, 18, 19  Next
48hours of Ruckus Winner
 Post subject: Re: FatKids beater (noobness at its finest)
PostPosted: Mon Aug 01, 2016 8:48 am
Yea that's what I was gonna do get a patch on the inside... Guess I'll take it over to the tire place and see if they will help me out... Stupid roofers should have to pay for these
FatKid's Toys:
Ruckus
MetRuck
Lil Girls Wagon
PostPosted: Mon Aug 22, 2016 11:16 pm
Turned out they just put a plug in it and charged me double what I could of done myself... Oh well now I know... And so do y'all for anyone wanting to know..
FatKid's Toys:
Ruckus
MetRuck
Lil Girls Wagon
PostPosted: Fri Nov 25, 2016 10:42 am
FatKid87 wrote:
Sooo was bored the other day and wanted to, just for poops and giggles, was gonna see if the ruck would run. It wouldn't even start when it died so I didn't have high hopes but, it fired up after a few kicks and ran for a while so I took it down the street to see if it would stay on and sure enough it did!
So I am guessing it went into save the engine mode and shut off? No clue what happend????
But sense there was coolant all over the muffler I went a head and filled it up and noticed that I was missing some (what I thought were) screws so I went to my parts motor and went to jack the screws and got meet with some unknown bolt/screw it might even be a rivit or a combination of them all I don't know so which one of you can tell me what these are?
Right now I just put the screws that were holding my cover on into that space and it seemed to work alright but I know almost everything rattles off these bad boys so if I could find the proper or maybe just use a zip tie to keep the top of the rad on we will see how these work tomorrow.
The pieces you have circled in red are permanent rivets. 4 bolts on radiator cover are all that is required to remove it. There are 2 tubes with o rings that basically seal radiator to the block. Maybe one of the orings are leaking, but that would be fairly uncommon. Need to determine where it is leaking from.
My Met Build
My Met Build
PostPosted: Fri Nov 25, 2016 2:36 pm
there were indeed and missing from my radiator? so i am assuming somehow they rattled off? I don't knw?
But while i am here i might as well update a little....
Just rolled over 17k on the Odometer about to swap out my seat frames and put on the one i got from MNNTHBX but i am kinda saving it for the project... but since its coming along so slow i wanna put my new seat on! to rep all my patches! looks like my battery box just box the last tab... so gonna need to find a replacement front. next on the list is a new battery, tune up, and then keep on beating it!
FatKid's Toys:
Ruckus
MetRuck
Lil Girls Wagon
PostPosted: Sat Nov 26, 2016 9:34 am
So you need a battery, or battery box, or both?
My Met Build
PostPosted: Sat Nov 26, 2016 9:43 am
:caroling:
King Ghidorah
ultramagnus wrote:
PostPosted: Sat Nov 26, 2016 2:47 pm
:caroling:
:D hmmmm are you asking for a particular reason racerx?!
FatKid's Toys:
Ruckus
MetRuck
Lil Girls Wagon
PostPosted: Sat Nov 26, 2016 3:20 pm
:popcorn: :lol:
fuck.
PostPosted: Sat Nov 26, 2016 11:48 pm
I know someone that has an unused battery box, but wasn't sure from the post if you needed the battery or box or both?????? :popcorn: :XD :XD
My Met Build
PostPosted: Sun Nov 27, 2016 12:18 am
:highfive: mindgames :choppin:
King Ghidorah
PostPosted: Sat Dec 03, 2016 10:50 am
i need both :banger: . been about 2 years since i replaced my battery and i think it is dead.... and all the tabs broke off my box
FatKid's Toys:
Ruckus
MetRuck
Lil Girls Wagon
PostPosted: Sat Dec 03, 2016 10:52 am
yall think i should put the DORF on the RUCK with the patch seat? or save it for my METRUCK? I keep going back and forth...
FatKid's Toys:
Ruckus
MetRuck
Lil Girls Wagon
PostPosted: Sat Dec 03, 2016 12:51 pm
Choices choices :popcorn:
fuck.
PostPosted: Thu Jan 19, 2017 6:32 pm
found some new wheels for the ruck when the time comes for new shoes....
http://www.sip-scootershop.com/EN/Produ ... aQodygEC0A
it will match the CR-V!
FatKid's Toys:
Ruckus
MetRuck
Lil Girls Wagon
