Post new topic Reply to topic  [ 86 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 Post subject: Re: Htown Ruck turbo gy6 build
PostPosted: Tue Jun 28, 2011 9:19 pm
:clap: :bugeye: :bow: :drool NIIICEEE!
One little fear I foe you can't fool Jah no
PostPosted: Wed Jun 29, 2011 10:54 am
Awesome work!
Darkrom's Carbon Fiber Addiction Buildhttp://totalruckus.com/phpBB3/viewtopic.php?f=92&t=58594&p=1031881#p1031881
Buggy Depot will sue you if you don't like their products/service which are made by 10 year old asian boys in sweatshops.
PostPosted: Fri Jul 01, 2011 2:47 pm
Damn thats sick! :banger:
mmiscooterpunk wrote:
it still doesnt matter where you get your parts a scooter is still a scooter you cant sugar coat a piece of shit and thats what you guys are doing to a damn scooter
My Scoots
PostPosted: Fri Jul 01, 2011 2:59 pm
:banger: soo awesome!
PostPosted: Sat Jul 02, 2011 7:46 pm
Megatron
JETFIRE
A Good Quick job won't be Cheap.
A Cheap Good job won't be Quick.
A Quick Cheap job won't be Good.
PostPosted: Sun Jul 17, 2011 1:08 pm
needs moar psi
Back in Black....well mostly black, some blue, and red underneath. STOLEN =(
BUY MY STUFF IN MY FOR SALE THREAD!
PostPosted: Sun Jul 17, 2011 2:20 pm
Goodluck.. With the bike.. An tuneing. Enjoy.. Siccck! :banger:
gy6 ruck build comeing sooon. Miss my GET Ruckk!!!
PostPosted: Mon Jul 18, 2011 4:49 am
:meh: .....j/k This is awesome. Looking forward to seeing the end result.
250cc Ruckus build: viewtopic.php?f=96&t=33740
250cc Metro build: viewtopic.php?f=96&t=80363
PostPosted: Tue Aug 16, 2011 5:04 am
Any new updates?
PostPosted: Tue Aug 16, 2011 6:38 am
look tight
PostPosted: Tue Sep 06, 2011 9:00 pm
I am wanting to turbocharge my gy6. I happened across a sweet deal on a K03 turbo, so even though it will hardly get spooled by a 150cc I will throw it on and see what it can do. I have another challenge though. The K03 turbo is oil fed and cooled by antifreeze. Got any ideas?
PostPosted: Tue Sep 06, 2011 11:40 pm
anxious for updatessssss
:headbashing:
PostPosted: Wed Sep 07, 2011 8:23 am
Ditch the K03 turbo, it's made for 4 banger motors in the 1.5-2.0l range... Thats 10x bigger than your 150cc (.15L). My 150cc BARELY spools the RHB31, and its way smaller than a K03. As for the cooling by antifreeze, its generally accepted that any turbo can be run on oil cooling/lubrication only, regardless of wether it has engine coolant ports or not. So if you pick a turbo with oil and antifreeze ports, just block off the antifreeze port and run it on oil only.
:headbashing:
Sorry man, its still running fine but i'm busy doing a GY6 swap on my brothers ruck. I think I'm running out of injector in the upper RPM's, although I can't get my wideband to operate properly to confirm this.
My turbo GY6 build
PostPosted: Wed Sep 07, 2011 12:37 pm
:headbashing:
sorry to slow ya down... :( but your also working on something else lol ;)
My Build.
viewtopic.php?f=92&t=60955
PostPosted: Mon Sep 12, 2011 6:56 am
I got the LC1 wideband O2 sensor wired up along with a gauge, My A/F ratios were all over the place but it seems to be running rich at wide open throttle which is a good thing.
While I had my laptop out I took the time to reprogram the LC1 itself, I changed analog output 1 to read 1.1 volts as 19.99-1 a/f and .100 volts as 10.00 a/f and then wired analog 1 to the MBE fuel injection ECU. Now the ECU is getting its o2 sensor reading from a accurate wide-band o2 sensor, which is simulated as a narrowband.
Another trick when using a narrowband o2 sensor, they are extremely accurate and FAST to measure a/f ratios, in a single cylinder engine this can be a problem. The o2 sensor was measuring individual exhaust pulses and the gauge was flip flopping from rich to lean, which made getting a good reading impossible. In the programing mode you can adjust how many readings per second the sensor will take, I adjusted mine to take a reading every 1/6th of a second. Actually what is happening is the sensor continously reads the A/F ratio, but it averages the readings and then sends a signal every 1/6th of a second. Regardless, if your o2 reading isn't smooth look into reprograming your sensor.
With all this done I roughed in the tune, fixed a small oil leak from the turbo oil supply line, and took it for another ride. With the A/F ratios in the 11.5-12.0 range the turbo spools up much quicker an the scooter is pretty peppy. I'm still holding off to make sure everything is tuned properly before spending much time at WOT and any top speed attempts.
I should have some more pictures and videos soon.
My turbo GY6 build
