Post new topic Reply to topic  [ 118 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
 Post subject: Re: ANGRY WAFFLE! 4-Valve Build (by Happypancake!)
PostPosted: Thu Aug 31, 2017 11:48 am
I'm using the stock 4-valve cam (2 lobe).
Did you find a larger 4 valve piston ?
My other scoot. Big bore runs this cam
https://mnnthbx.com/product/dcr-ruckus-cam-honda-get/
PostPosted: Thu Aug 31, 2017 8:32 pm
- Radiator / hoses on. Needed to put in new rivets to hold case together
- Alternative location for coil
- Spark plugs are different (left - 4V, right - 2V)
- Thermostats are different (Top - 4V, Btm - 2V) : Will need to make a connector on one side / ground is the other
- Swingarm on
- I need to find where I left the brake parts.
- BTW: No Pair valve on the head. Zoomer is on the case.
PostPosted: Fri Sep 01, 2017 3:30 am
i still' havent find the wiseco piston (tried contacting chanito but got no luck), i have started searching a compatible 4 valve piston from a bike engine because there must be something that would fit, i really like the GET technology, so i'd like to get the best engine i can
My Zoomer
PostPosted: Fri Sep 01, 2017 3:42 am
Racefarm has the 2V
http://www.racefarm.net/product/bbb-bolo-big-bore.
Not sure but I thought about trying this for the 4V. Might need to sleeve the crankcase though.
http://www.jiangwayne.com/scooter/p_i.php?i=34
PostPosted: Fri Sep 01, 2017 11:23 am
The break in oil I use.
PostPosted: Fri Sep 01, 2017 12:04 pm
- Need to save a bit for an exhaust. Yoshi is great but might try A Hot lap
PostPosted: Fri Sep 01, 2017 12:46 pm
So cool. :banger: :highfive: :popcorn:
fuck.
PostPosted: Fri Sep 01, 2017 3:55 pm
super nice! :highfive:
'83 Aero 80
'84 Aero 125
'02 Met Emo
'08 Met Ginger
'09 Met Goth
'06 Elite 80
'87 Elite 150
'89 Elite 250
'03 Met "Emo" GY6 Build
'08 Met "Ginger" 50cc Build
'09 Met "Goth" Build
PostPosted: Sat Sep 02, 2017 7:00 pm
I'm interested to see how the carb setup works.
TT-350z wrote:
Build Thread
PostPosted: Sat Sep 02, 2017 9:13 pm
Carb set up was before I switched to a PC10. Long runner worked well.
I'll try this first for the initial runs.
PostPosted: Sat Sep 02, 2017 9:48 pm
Nom nom nom. :popcorn:
PostPosted: Sun Sep 03, 2017 10:26 am
Pc10? You mean pc20 right?
Build Thread
PostPosted: Sun Sep 03, 2017 11:34 am
Nope. PC10C. 22mm. XR80 carb. I run one on my BB.
PostPosted: Sun Sep 03, 2017 11:24 pm
Science.
fuck.
PostPosted: Tue Sep 05, 2017 3:24 pm
Some go fast parts came today from The Ruck Shop (TRS). Those guys are great to work with!
