Post new topic Reply to topic  [ 74 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: GET-ting this MET build going
PostPosted: Wed Feb 24, 2016 5:05 pm
SMALL UPDATE
My bike needs a few more parts to reassemble. In the meantime, I was able to
swap out my girls frame and motor
Also bought a stock seat from a local and lowered it
New paint, stretch mount, and other goodies are in the future but she runs :banger:
PostPosted: Sat Apr 02, 2016 1:17 pm
PostPosted: Sat Apr 30, 2016 3:32 pm
UPDATE
I've done a lot to the bike and haven't keep you guys updated.
After getting the ruckus rear frame I bought a 9 inch stretch kit from RUCKS-R-US
Everything bolted up
Metropolitan throttle cable is too short so I'll be using one from a ruckus
Tore the bike down then got the front and rear frame ready for paint which includes cleaning, sanding, more cleaning, then primer
Painted, the color is a dark blue/purple
PostPosted: Sat Apr 30, 2016 3:37 pm
Finished reassembly by night then took it to the nearest gas station for photos
PostPosted: Sat Apr 30, 2016 3:46 pm
PostPosted: Thu May 05, 2016 5:19 pm
INFO ON THIS VIDEO
I really dislike the bulkiness and weight of the stock exhausts for these bikes so I ended up
chopping it off at the header.
I then grabbed some bent metropolitan handle bars and cut one handle side off. The inner diameter of the bar is a tiny bit bigger than the outer diameter of the exhaust so it slid right on the header.
Finally I used one of those metal circle clamps that get tight
using a flat head to secure it. The video is what it'll sound like completed :banger:
PostPosted: Thu May 05, 2016 5:53 pm
Going full circle with this metropolitan and ditching the ruckus rear end
Decided on sticking with the original metropolitan frame and plastic
DISASSEMBLY
Removed seat and frame
Unplugged rear harness connections to slide the rear apart then removed the rear ruckus frame
Took any remaining metropolitan plastic off
As well as the entire wire harness
Reinstalled the metropolitan frame w/ a password jdm engine extension
I'll need to make a shock extension so that's next
PostPosted: Fri May 06, 2016 5:17 pm
MADE THE SHOCK EXTENSION
PostPosted: Mon May 16, 2016 4:29 pm
So...turns out the shock extension I machined is too short as well as not angled enough
This is an issue because the shock is too much at an angle and isn't really doing its job
This is how the bike sat. When applied pressure, the motor hits the floor and the rear frame hits the rear tire :headbashing:
Made another extension, this time longer and with a notch cut out for more angle
OLD
NEW
OLD
NEW
OLD
NEW
How she sits now; less of an angle on the shock; not hitting the motor or rear frame
PostPosted: Sat May 21, 2016 2:22 pm
Tried installing a ruckus front wheel but it was way off centered and unsafe.
I'll be going a different route.
PostPosted: Sat May 21, 2016 2:49 pm
That's awesome! :banger:
King Ghidorah
JamesDean wrote:
PostPosted: Sat May 21, 2016 2:53 pm
8)
PostPosted: Sat May 21, 2016 6:18 pm
That's so off centred though.
PostPosted: Sat May 21, 2016 6:32 pm
Yeah it is, I might just scrap the whole idea.
At least it's possible.
Maybe others might not care as much
PostPosted: Sat May 21, 2016 6:35 pm
Even though the wheel doesn't rub, the tire might.
(and yeah, not centered: handling will be squirrely)
