Post new topic Reply to topic  [ 74 posts ]  Go to page 1, 2, 3, 4, 5  Next
 Post subject: GET-ting this MET build going
PostPosted: Sun Dec 13, 2015 7:58 pm
Been wanting to get my hands on a project for some time now.
So I bought an 09 Metropolitan from a guy on Craigslist.
Told me he got it from an auction that he won but never got around to fixing it.
 Post subject: Re: GET-ting this MET build going
PostPosted: Sun Dec 13, 2015 8:28 pm
Good taste in vehicles 8)
Junk Ruckus: viewtopic.php?f=94&t=66879
Ruck Fink Stickers: viewtopic.php?f=47&t=91889
PostPosted: Sun Dec 13, 2015 9:38 pm
Thought I'd try to get some use out of my new set of jack stands. Got them from Sears during Black Friday
Always gotta lay down some cardboard.
Now that the bike was elevated, I wanted to check the engine. See if anything got damaged when it got layed down. Noticed an excessive amount of gunk and oil built up around the exhaust and radiator.
I want to clean up that area as much as I can so that I can pin point the leak if there is one. I hope the block isn't cracked.
I need room to properly clean the area so off comes the exhaust.
When taking the exhaust off I noticed that the plastic housing holding the radiator to the bike was cracked and broken. It's held on by four 10mm or 8mm bolts and two of them weren't really doing anything so I ended up taking the whole piece off.
The day has come to an end. I'll leave her like this for now.
PostPosted: Mon Dec 14, 2015 7:14 pm
BACK TO WORK
So now that the exhaust and radiator are out of the way I can get a better look at what I'm working with. But there's still a few things still on the bike that I'd like to get off to fully do a good restoration/rebuild to this metropolitan.
So I did my first mod to the MET, removed that damn oem air box.
I'll buy filters for the carb soon.
Now with the air box out the way I can see how bad the carb needs a cleaning/rebuild.
Went ahead and scooped it out
Battery too, eh..why not. It needs to be charged or replaced anyway.
PostPosted: Mon Dec 14, 2015 8:56 pm
Since this 09 was missing pieces from it, I decided to search for another metropolitan on Craigslist to have a better view of what I needed and what went where just in case I forget something. Plus my girlfriend wanted one too so this was her Christmas gift from me.
2005
PostPosted: Mon Dec 14, 2015 9:06 pm
2005 and older mets are sloooooow. Nice start tho.
TT-350z wrote:
Build Thread
PostPosted: Tue Dec 15, 2015 10:18 am
:banger: :banger:
www.DROWsports.com
My 232cc GY6 Ruckus
PostPosted: Tue Dec 15, 2015 10:46 am
Good start. Hopefully only cosmetic issues.
METROD49 Build
viewtopic.php?f=95&t=95633
PostPosted: Tue Dec 15, 2015 9:04 pm
Before I began working on the MET again I decided to clean up the garage. Things were getting a bit messy and cluttered.
Now that everything's organized, I continued breaking down the bike.
Removed the forks
Left ones bent
Removed the plug and found water sealed inside
I had plans to lower the stock forks but it looks like these are toast.
Should I find other forks and go through with lowering stocks or should I go with aftermarket?
If I want to go with stock lowered forks, is there someone here on the forums who sell them? If not does anyone know of a site to get oem forks?
PostPosted: Thu Dec 17, 2015 4:37 pm
Forgot to mention I removed the gas tank before I cleaned the garage
After removing the front forks I tried removing the speedometer.
Took some effort since the brackets holding it to the handle bars were bent
Speedo housing was fucked, along with the cover
Now I needed to removed the handle bars.
Left controls removed
Right controls removed along with removing the blinkers
Bent to shit handle bars removed
Look at her, all naked..
Then this kinda happened
So as far as parts go, I'll need the following:
Forks
Handle bars
Speedometer
Front headlight
Plastic panels
Radiator with plastic housing
Rebuild carburetor
Change oil
Charge battery or new one
PostPosted: Sat Dec 19, 2015 12:13 am
If you want a stock speedo you can have mine for shipping cost. Its red. Good shape.
my left nuts
Jedi wrote:
pics of wife? :meh:
PostPosted: Mon Dec 21, 2015 10:28 am
I appreciate the offer but I'll be going with a trail tech vapor speedo
PostPosted: Mon Dec 21, 2015 11:59 am
Dude you got fucked.
At this point I would consider converting it to a ruck, met plastics are crazy expensive.
MY OLD 40K MILE RUCK
MY JANKY NEW BUILD
PostPosted: Mon Dec 21, 2015 12:47 pm
I second that, and metrucks are effin sweet.
this RUdiCKuloUS build
http://totalruckus.com/phpBB3/viewtopic.php?f=93&t=94739
PostPosted: Mon Dec 21, 2015 7:09 pm
I def did not say metruck lol
MY JANKY NEW BUILD
