Post new topic Reply to topic  [ 34 posts ]  Go to page 1, 2, 3  Next
 Post subject: DjTomy Met build
PostPosted: Fri Aug 15, 2014 8:17 pm
Rescued this '08 met in 2011 from a outside parking lot, after the previous owner sticker bomed it
cleaned her up a bit
Got some lowered front shocks from Mike555 carb shimmed and 40 SJ with a Uni filter & mikes Shortened Exhaust
New Belt gates SN vari with 5.5 Dr pully Sliders
TTO Tach & squeezed on a 100/90 rear tire 47mph @ 8130 Rpm
How she sits Today 2017
Still Tuning... Stay TUNED :popcorn:
'83 Aero 80
'84 Aero 125
'02 Met 178
'08 Met 50
'06 Elite 80
'85 Elite 125
'87 Elite 150
'89 Elite 250
"08 50cc Met Build
Metro 180cc Build
 Post subject: Re: DjTomy Met build
PostPosted: Sat Aug 16, 2014 11:13 am
It looks so much better without all those stupid stickers. Did you change the mirror as well?
My Ride: viewtopic.php?f=94&t=91816
PostPosted: Sun Aug 17, 2014 12:57 pm
Oh yeah I did think there kymco mirrors, trying to stay on a budget build.
The Goal is a steady top speed, hopefully around 52-53mph since there is one stretch of road by me for about a mile that is 55mph. then speed limits drop from there 45 35 etc..
****Update*** Shaved the drive face just a hair, Definitely feel a difference in take off.
I think I'm maxed out on my vari, don't understand why im only hitting 45mph and not even close to my rev limiter of 8800rpm
Maybe running to lean?
'83 Aero 80
'84 Aero 125
'02 Met 178
'08 Met 50
'06 Elite 80
'85 Elite 125
'87 Elite 150
'89 Elite 250
"08 50cc Met Build
Metro 180cc Build
PostPosted: Sun Aug 17, 2014 5:45 pm
Have you tried the CR9EH9?
I usually use these pics for plugs, but there's probably better ones out there meant for plug chopping.
PostPosted: Sun Aug 17, 2014 5:59 pm
Haven't tried the 9's still using the CR8EH9's,
I'll give it a shot
What about carbs should I upgrade to a pc20? just seems like Im out of power... my RPMs are low (8230) my mph is 45..
Racerx
PC20 was good improvement, PE20 is better IMO
'83 Aero 80
'84 Aero 125
'02 Met 178
'08 Met 50
'06 Elite 80
'85 Elite 125
'87 Elite 150
'89 Elite 250
"08 50cc Met Build
Metro 180cc Build
PostPosted: Sun Aug 17, 2014 11:09 pm
djtomy wrote:
I'm maxed out on my vari don't understand why im only hitting 45mph and not even close to my rev limiter of 8800rpm
45mph w/ no rev limiter? Are you gauging that by speedo or GPS?
What do you mean by "maxed out on my vari"? Have you marked it and the belt is at maximum travel? What variator?
My Met Build
PostPosted: Mon Aug 18, 2014 12:56 am
I like learning :popcorn:
I wish they made the rucks in as many color.variations as they do the metro. That red is downright sexy! Way better than that sticker abuse
PostPosted: Mon Aug 18, 2014 11:14 am
yes GPS (Iphone) Stock ECU (8800rpm rev limiter) that rear tire has to change the gearing 100/90/10 hit 47 with a tailwind @8130 rpm The factory speedo it right on that too.
Scooer Ninja Vari, I sharpied the vari, The belt went to the top.
Racerx Which vari should I run?
'83 Aero 80
'84 Aero 125
'02 Met 178
'08 Met 50
'06 Elite 80
'85 Elite 125
'87 Elite 150
'89 Elite 250
"08 50cc Met Build
Metro 180cc Build
PostPosted: Mon Aug 18, 2014 11:19 am
Thanks!! is wasn't my first choice it grew on me, it is a sick color.. I just play it up and wear all red when I ride.. I think I would go all white next time, or that Grey goth color in "09
'83 Aero 80
'84 Aero 125
'02 Met 178
'08 Met 50
'06 Elite 80
'85 Elite 125
'87 Elite 150
'89 Elite 250
"08 50cc Met Build
Metro 180cc Build
PostPosted: Mon Aug 18, 2014 12:24 pm
Didn't you say you were hitting 47 mph @ 8130rpms? Then you were at 45 mph @ 8230? What changed? That is awfully low rpms for that speed IMO.
PostPosted: Mon Aug 18, 2014 1:29 pm
I f** up
7920 45 mph
8130 47 mph
I think I should shave my drive face nipple, Maybe that would help
'83 Aero 80
'84 Aero 125
'02 Met 178
'08 Met 50
'06 Elite 80
'85 Elite 125
'87 Elite 150
'89 Elite 250
"08 50cc Met Build
Metro 180cc Build
PostPosted: Tue Aug 19, 2014 9:57 am
For some time I'm at 9000 rpms at like 10-30 mph. I bet you be banging off the limiter at mid 60's.
What's your location?
PostPosted: Tue Aug 19, 2014 1:50 pm
That would be cool in the 60's..
I think my motor needs to make more power, or maybe I'm too lean... IDK
probably should do a Pe /Pc 20 carb and a real exhaust
looking for A RUCK SWING ARM
Destin, Florida
'83 Aero 80
'84 Aero 125
'02 Met 178
'08 Met 50
'06 Elite 80
'85 Elite 125
'87 Elite 150
'89 Elite 250
"08 50cc Met Build
Metro 180cc Build
PostPosted: Fri Aug 22, 2014 8:10 am
Which main jet is in the carb now? 72?
PostPosted: Wed Oct 01, 2014 2:23 pm
75 mj
'83 Aero 80
'84 Aero 125
'02 Met 178
'08 Met 50
'06 Elite 80
'85 Elite 125
'87 Elite 150
'89 Elite 250
"08 50cc Met Build
Metro 180cc Build
