Post new topic Reply to topic  [ 59 posts ]  Go to page Previous  1, 2, 3, 4
 Post subject: Re: bEE's Ruckus Build Thread
PostPosted: Fri Mar 13, 2015 10:58 pm
As Sith Slayer predicted, the air intake didn't work that well...so I bought a new rad hose and it works way better. I had problems at top end with it bogging down and stalling...its amazing the difference in just a hose makes!
My Ruckus Build
PostPosted: Sat Mar 14, 2015 5:30 pm
awesome work with that 12x8! can you post a pic of your clearance to the oil dipstick?
I'm running a 10x8 and need to figure out if i go 12x8 and 140 rear tire if i have clearance
My Build Thread
PostPosted: Sat Mar 14, 2015 9:10 pm
For sure! I wouldn't say there's a lot, I've seen less, but 12x8 with a 140 does fit... I did have to take my dipstick out to get the wheel on though.
My Ruckus Build
PostPosted: Sun Mar 15, 2015 8:54 pm
Picked up some stainless steel pipe yesterday, fiddled around with a dingleberry plate holder, and got a kickstand installed...all in all a productive weekend. The muffler is mounted now and it sounds awesome. Now if only it would stop raining :/
This was my first time welding stainless steel with stainless steel wire...you have to get the metal pretty hot to bond, and its so thin I ended up burning a hole in one of my welds, so I had to fix that...I'm contemplating headerwrap to hide the welds...
My Ruckus Build
PostPosted: Tue Mar 17, 2015 12:47 pm
Figured I'd post some glamour shots!
My Ruckus Build
PostPosted: Tue Mar 17, 2015 4:10 pm
im digging your build sir
Meepers wrote:
I called the house, he isn't home. I never wanted to hang out with a priest so bad!
my ride
viewtopic.php?f=94&t=57840
ride game
viewtopic.php?f=2&t=57150
PostPosted: Sat Apr 11, 2015 4:25 pm
Got my Yamaha R6 hugger yesterday. AKA my new rear fender :) I got it for $36 on Amazon, it didn't come with bushings, but I had no problem making my own with some aluminium pipe and some rubber grommets. I also made my own bracket that screws to the engine and the rad cover.
I had to reposition both my taillight assembly and my license plat, which really ticked me off, but there was just no way around it.
Love the fender! Not sold on the taillight...might revise yet..
My Ruckus Build
PostPosted: Fri Apr 17, 2015 9:24 pm
Picked up a Honda Grom front fender. Its a perfect fit. The pearl white with gold flake is eventually what I will paint the rest of my ruckus with!
My Ruckus Build
PostPosted: Sun Apr 26, 2015 2:10 pm
My Ruckus Build
PostPosted: Sun Apr 26, 2015 2:26 pm
those fenders look perfect for the build!
Also, you should GET a new brake cable! that looks like it could catch and then you would be having a bad day!
VW Drift Caddy SPEEDHUNTERS feature: Speedhunters-VW Caddy from Hell
2012 USDM Ruckus in Okinawa Japan
@Draklore on Instagram
Draklores Build Thread
PostPosted: Sun Apr 26, 2015 7:14 pm
Thanks! Actually I did put one on Thursday, longer brake and throttle...now they're hidden in the battery box and under the gas tank. I managed to find a long 95" but i could probably use another 4 or 5 inches...i guess I'll just have to lower my handlebars next!
My Ruckus Build
PostPosted: Sun May 03, 2015 10:53 pm
Longer break and throttle cables! Looks much cleaner now
I broke my right side mirror a while back, and my left side started breaking apart (some cheap $30 Amazon ones)...I spent about 5x as much as I ever thought I would on these Arrow ones, but man are they nice.
My Ruckus Build
PostPosted: Sun Jul 24, 2016 6:50 pm
I really like the electric start button in the battery box. What product is that?
PostPosted: Mon Aug 21, 2017 11:02 am
What extra hardware or brackets did you need to make the Grom fender fit on the Ruck?
