Post new topic Reply to topic  [ 61 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: BWS 100 new killer bars and stage6 speedo
PostPosted: Mon Mar 24, 2014 9:24 am
Looks good man
WHO DAT?
viewtopic.php?f=96&t=89131
 Post subject: Re: Re: BWS 100
PostPosted: Mon Mar 24, 2014 7:50 pm
[quote="Mike155cc"]whats happening is your stretch is twisting slightly
I got an easy fix for the wheel tilt
for my met stretch and my zuma 125 stretch I make small turnbuckles for each side of the stretch
I try to get the turnbuckle as close to the engine bolt as I can since thats where it can twist easier
I bet you could get away with one on the side you need it as they are expensive to make depending on the heim joint size can range from $12-20 each not to mention the left hand nuts and tap
so what you have is 2 heim joints on a threaded rod
one heim is left hand thread, one is right hand thread
connect one to the stretch and one to the frame
if your doing only one side put it on the side that needs to go up
then just twist it and it evenly expands to push the stretch and frame apart to level the wheel
of course depending on where your frame and stretch are your rod may need to be really long
or short and hopefully a straight shot up
and you can use an existing bolt on the stretch to mount the rod if you replace the bolt with something longer as the heim joints can be around 1/2 wide
or make your own hole in the stretch and you a bolt
as yours looks to be pretty thin wont be too hard to put a small hole in it
you can also do just a solid piece of metal too
but you will need it cut exactly
so prepare to make 4-5 if your measurements arent right
since the height could change depending if the suspension settles when your installing it
I just like using the heim joints because its really easily adjustable to a point
just like when I changed the wheel to a fatty I had lean when I didnt before with the stock wheel
but all I did was adjust the rod a little on one side and that fixed it
thanks for the advice Mike :highfive: i´m going to try.
my bws 100 viewtopic.php?f=92&t=79514
 Post subject: Re: BWS 100 new seat cover and cvt paint
PostPosted: Thu Oct 02, 2014 6:57 am
Hello TR members, it's a looooooong time since my last update, haven't done so much to my bws just new seat cover and cvt paint with psw Jdm washers.
Cvt before
After paint removal
Painted and installed
Material for the seat
Seat done
And seat installed
And some rolling shots
Hope you like it :highfive:
PostPosted: Thu Oct 02, 2014 8:17 am
Looks good!
You need some red up front though... Maybe the caliper painted red? That would tie it all in!
PostPosted: Thu Oct 02, 2014 11:10 am
Still need to fix that engine angle
One good bump bye bye case
PostPosted: Thu Oct 02, 2014 11:38 am
You probably have the sickest scoot in all of DF.
GET:
viewtopic.php?f=94&t=42190
GA:
viewtopic.php?f=94&t=89905
PostPosted: Thu Oct 02, 2014 12:07 pm
There is enough room between the engine case and the ground, streets here in MĂ©xico city have a lot of potholes and haven't had any problems. :highfive:
PostPosted: Thu Oct 02, 2014 12:20 pm
I think so too. :highfive:
Most of the modified scooters here look like this :oops: :headbashing:
 Post subject: Re: BWS 100 back to mini fatty
PostPosted: Thu Aug 13, 2015 5:46 pm
hello just updating my build, i had solved the Wheel lean problem with adjustable turnbuckles but was a pita, was having lots of vibrations and due to that my gas tank cracked and was leaking gasoline :headbashing: , tired of the vibrations and Wheel leaning decided to go back to mini fatty and also put a matching front Wheel 8) , it handles and runs better without the stretch :banger:
PostPosted: Thu Aug 13, 2015 6:13 pm
Looks awesome
2003 GET-Retired
2005 GY6-Sold
*****2-strokes Vanilla Shake in the making(S-Motion Garge/SparkleMotion)****
PostPosted: Fri Aug 14, 2015 8:24 am
lol Yup, lots of the modified cars in Mexico look like that too. :ucrazy:
GET:
GA:
PostPosted: Sun May 08, 2016 7:47 pm
Did you have to get new brake and throttle cables?
 Post subject: Bye BWS 100 :-( welcome zoomer x :-D
PostPosted: Sun Nov 06, 2016 9:18 pm
Hi it's been a loooong time since my last update, sold my bws 100 :( a little bit more than a year ago and stayed away from scooters that time, but last week went to the Honda dealer and bought this little beauty a 2016 Honda Zoomer X :banger:
Btw sorry for the crappy phone pic. :meh:
 Post subject: Re: Bye BWS 100 :-( welcome zoomer x :-D
PostPosted: Mon Jan 23, 2017 7:01 pm
Hi :highfive: , just updating my build, put a hurricane handlebar with foam grips, MGP exhaust with a custom made header, a 2400lm LED light and deleted the rear fender, also have an hurricane stretch kit but haven't installed yet.
Here are some pics :banger:
PostPosted: Mon Jan 23, 2017 10:29 pm
Are the wheels on a zoomer-x 12"s? Wonder if they fit the regular ruckus...
