Post new topic Reply to topic  [ 61 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: BWS 100
PostPosted: Thu Aug 22, 2013 9:47 pm
Well it's a month since my last update :mrgreen: , finally put 100/80 10 continental tire in the front cause the 120/90 10 pirelli was hiting with the fender :headbashing:
My top speed, don't know how accurate it is the gps since my phone was on the bag of my jeans :meh: , i'm going to shop a handlebar phone holder to see if it is more accurate
Also ordered a douglas 12x7 going to make this fatty :D , hope to install it this weekend
my bws 100 viewtopic.php?f=92&t=79514
PostPosted: Thu Aug 22, 2013 9:54 pm
Almost forget it, wanted to share this image that i took yesterday, i was on my way to eat some tacos and saw this man carrying a fridge on a 125cc bike :ucrazy:
PostPosted: Sun Aug 25, 2013 5:57 pm
Tearing it apart to put the fatty
With the new douglas 12x7 installed :banger:
 Post subject: Re: BWS 100 with fatty installed pg3
PostPosted: Mon Aug 26, 2013 4:48 pm
Poon parts arrived today :banana :banana_det_down: :banana :banana_det_down: :banger: :highfive:
 Post subject: Re: BWS 100 new pics
PostPosted: Mon Dec 02, 2013 5:16 pm
hi :highfive: it´s been a while since the last update, finally i installed what i ordered from poon and other stuff from psw jdm, 200mm disk brake, ti rotor bolts, rrgs caliper, psw jdm poon washers, psw jdm pegs and cf air scoop, and a luggage hook, also i made a mount for the pegs.
with my bro´s em1
with her sister :lol:
and me :highfive:
PostPosted: Tue Dec 03, 2013 6:11 am
Well done dude that thing is badass :banger:
-Ruckus
-Big Ruckus
-Grom
 Post subject: Re: Re: BWS 100
PostPosted: Tue Dec 03, 2013 7:11 am
francisco wrote:
Is that just the camera angle, or is something wrong here?
It looks like the rear is leaning over badly... :/
Sent from my HTC One using Tapatalk
PostPosted: Tue Dec 03, 2013 10:44 pm
Thanks :highfive:
PostPosted: Tue Dec 03, 2013 10:54 pm
It's the camber kit :lol: ........ yeah you are right it's leaning, but just a little, if you pull up the right side of the scooter the lean disappears :meh: i can't find the solution for that leaning yet :headbashing:
PostPosted: Tue Jan 14, 2014 6:07 am
:popcorn: in for more.
No Name Ruck
"Metrocity"
Third-Time-2t-charm
TR's High Five Guy
PostPosted: Mon Jan 27, 2014 4:17 pm
Want this scoot sooooooo bad! Awsome!
viewtopic.php?f=95&t=57591
"First Timer"
viewtopic.php?f=95&t=64048
"Fairly 48"
viewtopic.php?f=95&t=78643
Metruckus
 Post subject: Re: BWS 100 new killer bars and stage6 speedo
PostPosted: Wed Mar 19, 2014 2:06 pm
First thanks to jay@drowsports for the great customer service :highfive:
Well just a little update, bought the killer scooters dog bones clip ons and white stage6 digital speedo from drowsports, i'm really happy with the quality of both products. :banger:
PostPosted: Mon Mar 24, 2014 8:02 am
them bars :wasted: :wasted: :wasted:
2003 GET-Retired
2005 GY6-Sold
*****2-strokes Vanilla Shake in the making(S-Motion Garge/SparkleMotion)****
PostPosted: Mon Mar 24, 2014 8:14 am
Looks tits!
MiniMotorMonster 4T
MiniMotorMonster 2T
A Day in the Desert Ride
PostPosted: Mon Mar 24, 2014 9:02 am
whats happening is your stretch is twisting slightly
I got an easy fix for the wheel tilt
for my met stretch and my zuma 125 stretch I make small turnbuckles for each side of the stretch
I try to get the turnbuckle as close to the engine bolt as I can since thats where it can twist easier
I bet you could get away with one on the side you need it as they are expensive to make depending on the heim joint size can range from $12-20 each not to mention the left hand nuts and tap
so what you have is 2 heim joints on a threaded rod
one heim is left hand thread, one is right hand thread
connect one to the stretch and one to the frame
if your doing only one side put it on the side that needs to go up
then just twist it and it evenly expands to push the stretch and frame apart to level the wheel
of course depending on where your frame and stretch are your rod may need to be really long
or short and hopefully a straight shot up
and you can use an existing bolt on the stretch to mount the rod if you replace the bolt with something longer as the heim joints can be around 1/2 wide
or make your own hole in the stretch and you a bolt
as yours looks to be pretty thin wont be too hard to put a small hole in it
you can also do just a solid piece of metal too
but you will need it cut exactly
so prepare to make 4-5 if your measurements arent right
since the height could change depending if the suspension settles when your installing it
I just like using the heim joints because its really easily adjustable to a point
just like when I changed the wheel to a fatty I had lean when I didnt before with the stock wheel
but all I did was adjust the rod a little on one side and that fixed it
