 Post subject: 09 Met Goth build
PostPosted: Fri Sep 01, 2017 4:20 pm
Got a deal on this 09 Met yesterday,
I'm going along the line of my Red met build on this one keeping the stock motor..
Parts I ordered already,
Ruck swing arm & cover
Ruck rear wheel
Strip LEd tail
led headlight
new floor & seat
basket, phone mount, visor
Ruck F&R Brake lines
Polini Vari 75mj
'83 Aero 80
'84 Aero 125
'02 Met 178
'08 Met Red
'09 Met Goth
'06 Elite 80
'85 Elite 125
'87 Elite 150
'89 Elite 250
Met 1 2008 Red 50cc Build
Met 2 180cc Build
Met 3 2009 Goth Build
48hours of Ruckus Winner
 Post subject: Re: 09 Met Goth build
PostPosted: Fri Sep 01, 2017 5:56 pm
new floor? why not just paint that one?
FatKid's Toys:
Ruckus
MetRuck
Lil Girls Wagon
PostPosted: Fri Sep 01, 2017 7:08 pm
you should have gotten tires!!!
PostPosted: Fri Sep 01, 2017 7:11 pm
Front and rear wheels should match!
PostPosted: Fri Sep 01, 2017 7:40 pm
You're right I didn't see that!
Ahh I didn't think of that either :? i'll probably get some dio wheels
I guess I got a little anxious, started ordering stuff,
I should take my time... do it right.. plus its still too hot here to be working on anything outside..
I should really go with a real exhaust this time.. (Yoshi)
'83 Aero 80
'84 Aero 125
'02 Met 178
'08 Met Red
'09 Met Goth
'06 Elite 80
'85 Elite 125
'87 Elite 150
'89 Elite 250
Met 2 180cc Build
PostPosted: Sun Sep 10, 2017 6:07 pm
Headlight visor installed
New floor & seat
Basket without drilling in legshield
LeD tail light and Headlight
'83 Aero 80
'84 Aero 125
'02 Met 178
'08 Met Red
'09 Met Goth
'06 Elite 80
'85 Elite 125
'87 Elite 150
'89 Elite 250
Met 2 180cc Build
PostPosted: Sun Sep 10, 2017 6:29 pm
Good to see some other builds going on! :popcorn:
PostPosted: Sun Sep 10, 2017 6:39 pm
I'm in PC waiting hell!
PostPosted: Thu Sep 14, 2017 4:14 pm
I need advice on some Front forks, wheels, Intake and Exhaust. Simple setups, would like to try a front disk brake and a Dio wheel?.. I need a 2-3 inch drop I'm guessing in the front.
Is the Yoshi exh the best? and worth it?
'83 Aero 80
'84 Aero 125
'02 Met 178
'08 Met Red
'09 Met Goth
'06 Elite 80
'85 Elite 125
'87 Elite 150
'89 Elite 250
Met 2 180cc Build
PostPosted: Thu Sep 14, 2017 4:49 pm
I have the rrgs w/ compisimo springs. dropped it nicely. Yoshi :banger:
I have a front/rear full dio wheel set I may not use. Also have the front disc / rear drum dio live brake set.
PostPosted: Sat Sep 16, 2017 11:26 am
I think I will go that route, :banger:
I was reading over at Drow sports that the RRGS Ruckus Low Down Front Forks V2 has a 3 inch drop, I think that would be sufficient.
Does the RRGS come with those springs, or do I have to install them?, do they make a full kit with brake lever, disk etc, So they only thing else I would need is a Dio wheel/tire & where's a good place to buy..
'83 Aero 80
'84 Aero 125
'02 Met 178
'08 Met Red
'09 Met Goth
'06 Elite 80
'85 Elite 125
'87 Elite 150
'89 Elite 250
Met 2 180cc Build
PostPosted: Sat Sep 16, 2017 12:22 pm
Old post of mine. There is a chrome extension out there called "Photobucket embed fix" your need to install to view.
Left to right: stock, stock w mnnthbx springs, mike155cc, mike155cc w mnnthbx, rrgs 293mm
If Compismo Spring are installed it will drop theme further.
Here's stock vs RRGS w/ compismo springs.
PostPosted: Thu Sep 21, 2017 6:36 pm
Ok,
I so ordered from TRS & everything will be here tomorrow
The RRGS low down drag
TVR AIR INTAKE SYSTEM with jets & shim
REED PAR BLOCK OFF
TTOtach
Ruck front and rear brake cables from Partzilla
BR exhaust for now (until I get a Yoshi)
I just need to swap my met gears in the ruck swingarm and build the semi hardtail.
What are you using for sealing up the gearcase, Permatex optimum Black?
I'm going to tackle this by myself I guess, unless someone wants to help me. :meh:
'83 Aero 80
'84 Aero 125
'02 Met 178
'08 Met Red
'09 Met Goth
'06 Elite 80
'85 Elite 125
'87 Elite 150
'89 Elite 250
Met 2 180cc Build
PostPosted: Thu Sep 21, 2017 6:55 pm
You'll need this also to run the rrgs with the stock brake set up.
http://www.shop.theruckshop.com/TRS-RRG ... RUMADP.htm
I use Hondabond for sealant.
What do you need help with?
PostPosted: Thu Sep 21, 2017 10:56 pm
ahhh I didn't know about that drum adaptor. but I see how that would make sense now... Ill order tomorrow.. thank you!
hondabond ok, never heard of it. I guess I could give it a try.
As for help, I can do it myself, I'm sure of it.. I guess what I'm meaning is that I did have help last time. Can be a little tricky hanging it all back up, I'm still having trouble installing the Google chrome Bucket fix so I can reference any questions. I definitely want to center up the rear wheel this time. I forgot how to swap the met gears. I'm just getting ahead of myself, talking out loud... I should wait a couple of days anyhow, it still pretty hot here. I have some big contracts next week don't think I will have the time, so that's got me somewhat frazzled, and My only helper moved to PA...
'83 Aero 80
'84 Aero 125
'02 Met 178
'08 Met Red
'09 Met Goth
'06 Elite 80
'85 Elite 125
'87 Elite 150
'89 Elite 250
Met 2 180cc Build
