Post new topic Reply to topic  [ 90 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 Post subject: Re: Victoria's Spreecret
PostPosted: Fri Nov 18, 2016 5:56 pm
2nd Round Mock Up!
Now she sits right :banger: SO... The RS24 JUST rubs the tire, the stock shock BARELY misses. Going to space the wheel out just a hair and try my luck again with the Malossi.
I noticed a lot of different style shock relocator mounts and some i have seen use gussets, stiffeners, etc... Since I was smart and saved my template, I sent another one out to the burn table and figured i'd make it symmetrical and put one on the OTHER side. I will use this as my stiffener from lateral movement. I will use some all-thread (threaded rod for you ace hardware gurus) and nuts inside and out, to try and keep the load distributed amongst the 2 mounts. (Note: the image shows 2 long bolts, it's just what I had laying around to make sure the bolt holes line up :wink: )
BBK and a shît ton of other ancillary parts are getting ordered next week.
PostPosted: Wed Jan 04, 2017 6:11 pm
Decided on Satin Black for the Big Block
Rattle Can!
Dude Perfect!
PostPosted: Wed Jan 04, 2017 6:12 pm
Pray with Me...
https://www.youtube.com/watch?v=WhI_SDEvJ-4
Polini Corsa, Polini Belt, Polini Vari, Polini EVO Slow Jets (On Back Order), Trail Tech Vapor w/ Extension, Stage6 Pod, NCY Kicker, Anno'd Kicker Cover Bolts, Tadia Head Studs, Anno'd Oil Plug, Fuel Valve, STR8 Fan Scoop (On Back Order), STICKERS, wallet that needs refilled, and a Wife with A LOT of questions :liplock:
Just waiting on my slow jets & scoop that are on back order.
Once I get this engine assembled, its back up to the front to work on the vapor, handle bars, & controls. Then to figure out what I want to do for lighting.
YOU DA MAN G9!!!! :beers:
PostPosted: Thu Jan 05, 2017 1:54 pm
LUBED!
TORQUED!
DAT 72CC 2T BBK :banger: BRAAAP!!!
PostPosted: Sun Jan 08, 2017 11:47 pm
:shock: Thats the way to shop! :highfive: damn, nice order
my left nuts
jcrabb13 wrote:
i'm fairly certain that's a ball sack
PostPosted: Mon Jan 09, 2017 5:29 am
That thumb screw gear oil plug is where its at! SO CONVENIENT! :banger:
HOUSEKEEPING! WAS FREEZING YESTERDAY AT 55* HERE IN FL YESTERDAY SO I DECIDED TO CLEAN UP SHOP :mrgreen:
PostPosted: Tue Jan 10, 2017 4:47 pm
That's T-shirt & shorts weather! :mrgreen:
Red rOOckus
gy6 super stretch
gy6 off-roader project
Yamaha C3
PostPosted: Fri Jan 13, 2017 7:49 pm
Swung by The Ruck Shop today and picked up some goods :banger:
TRS Drum adapter for NCY/RRGS Forks
TRS Shorty 39" Front Brake Cable
TRS Front Stem/Vapor Mount (Not shown, they have a batch getting annodized and will ship it to me)
NCY Needle Bearing Quick Throttle Kit
NCY Ruckus Axle Bolt
NCY Front & Rear Brake Shoes
Password JDM Ruckus Gas Cap (TRS is discontinuing PWDJDM and hooked me up with this version 1 cap. It Fits the spree cap & has clearance with the seat down :mrgreen: )
FREE SWAG: TRS Hater Shirt, TRS Shades (YOU DA MAN RYAN!)
Just waiting on my NCY slammed forks and Drag Bars from SSS and this front will be almost done. Just need to get a light and a few more cosmetic things like wheel spools, KN brake cam, and fancy takagawa brake adjuster nuts.
Side note, the new 2017 Grom fender & mount kit for the Ruck they have is off the chain! (I WAS SOOO TEMPTED TO GET IT)
PostPosted: Sun Jan 15, 2017 6:27 pm
Got some goods in today from G9. Swear the parts were still cold from the Oregon air :eyeroll:
NCY Slammed Forks
NCY Drag Bars
So these "SLAMMED" legs compared to the stock ruck forks they arnt so "SLAMMED" IMO lol. I guess this is normal but i was expecting a 2" difference...
Brakes DONE!
TRS Drum adapter took some shaving to get it to fit properly. The tab that goes into the drum was slightly clocked wrong. Nothing a METABO cant fix.
Suprisingly the Ruck Fender fits & clears lol. I just stuck it on there for the hèll of it. Little high but i like it for now until i float it. Makes me think about getting that grom fender kit on there even more lol.
Few more cosmetic goods coming in from SSS. Have to return the NCY front axle bolt... Got the GY6 one and didn't notice.
Going to cut the NCY drag bars down about an inch on each side. Polish the Ruck controls and hopefully get to wiring soon...
PostPosted: Sun Jan 15, 2017 6:42 pm
Here's a shock comparison. I put comprisimo springs in the RRGS and they are 1" lower
viewtopic.php?f=4&t=95363
Build thread : viewtopic.php?f=93&t=95381
PostPosted: Sun Jan 15, 2017 9:20 pm
Yea so why do these NCY "slammed" legs claim to be 51mm lower (2") and they are not... Just confused and $250 moar broke for the same ride height....
PostPosted: Mon Jan 16, 2017 8:14 am
i picked up a set of older ncy legs for a buddies build and they were actually taller then the stock ones. ive since avoided them. They ride good i guess? i dunno, chop them down. :highfive:
build thread: viewtopic.php?f=93&t=85499
instagram: _mrfritz
PostPosted: Fri Jan 20, 2017 6:23 am
Started cleaning up my controls and got the left side done then the mail came!
KN Brake Arm, Takegawa Brake Nut, SSS Stiffy, & my TRS Vapor Mount finally came in! I guess you can use the KN brake arm on the rear too? Didn't know that so going to have to buy another set.
Slicker than owl snot :fresh:
Ground the round part some and got this thing to sit HèllaFlush! :clap:
Prep, Fit, Tacked
Got her Spoog'd up! :cylon
Got that weld repair sprayed on there :Ninja
PostPosted: Fri Jan 20, 2017 8:02 am
I like your XDS mat in the background :banger: :usa:
Build Thread: viewtopic.php?f=93&t=106626
PostPosted: Sat Jan 21, 2017 2:27 pm
Yea that wep is for my wife for the house for home invaders who want a face lift :wasted:
I used to carry it but now my full sized Government Sig Scorpion 1911 accompanies me to meets & greets :usa: (You can see it th The Ride Games lol!) viewtopic.php?f=2&t=57150&start=18585
COM TES ME BOI :afro:
