 Post subject: New Coil Over Shock.
PostPosted: Wed Jun 21, 2017 1:05 pm
I have a like new coil over shock. It's basically a off brand atr I've been told. It's around 11" in length non extended. Only been used for mock up. No scratches or dings. Like new. It was 1/4 inch to long for my set up and I went another route. Comes with the wrenches. Asking what I paid 105 shipped. Thanks. Hit me up if you have any questions.
Thanks
Bryson.
Build- viewtopic.php?f=94&t=83349
WFO till you see god
Pin it and Pray!
 Post subject: Re: New Coil Over Shock.
PostPosted: Wed Jun 21, 2017 8:13 pm
Same shock I use, it has less bounce than the NCY so it's better option for heavier riders. GLWS.
2011 Ruckus
PostPosted: Thu Jun 22, 2017 5:53 am
So what brand is it?
Orange Build Stolen!!!
viewtopic.php?t=105810
Build 2.0
viewtopic.php?f=94&t=107092
PostPosted: Thu Jun 22, 2017 6:09 am
They are made in the Adelin factory and left unbranded. This one is the non low down version.
2011 Ruckus
PostPosted: Fri Jun 23, 2017 6:35 am
Hmmm I need the low down but if you still have it when I get my build almost done I'll hit you up.
Build 2.0
PostPosted: Sun Aug 06, 2017 11:14 pm
My bad. I just ran across this shock on the bench and remembered I had it again. Haha. Bump for a good shock needing a good home.
Bryson
Pin it and Pray!
PostPosted: Sun Aug 20, 2017 4:58 pm
Hey,Is this a direct bolt on replacement for a stock shock on my 2007 Ruckus?? THANKS.Dale
