 Post subject: Gy6 Hoarder garage sale.
PostPosted: Sat Feb 18, 2017 11:53 am
I've hoaded parts for far too long and haven't touched scooters in months. Its time for me to move on.
Located in San Diego, Ca. Local pick up is preffed but can ship at buyers expense.
Text or email is the fastest way to reach me (6I9)933-l428 Thereissmeister@live.com
GY6 150cc 157qmj. Skinny wheel and short axle. Was running when taken off bike - $200
Short case gy6 with 155cc bbk, one racing clutch, racing clutch bell, aftermarket springs, up so variator, and engi e mount to fit a metropolitan. (Can part out) - $200
Brand new gy6 and gy6 hub. 0 miles. - $360
Damaged gy6. Has a hole in the swing arm but will include an extra swing arm. Comes with short axle - $100
Gy6 50cc, has a hole in the swing arm - $40
Gy6, 6161mm bbk, 61mm head, 361mm stroker crank. Tapped case for oil cooler. 90% complete - $250
GY6 METRUCK
 Post subject: Re: Gy6 Hoarder garage sale.
PostPosted: Sat Feb 18, 2017 12:15 pm
1 1/2" muffler- $40
Gy6 header - $10
Keihin 24mm cv carb with uni filter and manifold - $40
Monkey hubs, spark plugs, flush turn signals, starter relays, race cdi, race coil, and weights. - $ask
Rfy shock. I believe its 320mm - $30
Gasket set - $5
63mm bbk - $80
GY6 METRUCK
PostPosted: Wed Apr 19, 2017 3:01 pm
Do you still have the stroker motor?
PostPosted: Tue May 09, 2017 4:59 pm
PM'd about Keihin 24mm cv carb with uni filter and manifold
PostPosted: Tue May 09, 2017 6:24 pm
Flush mount signals $?
'11 GET/mostly stock.. for now
My build:
viewtopic.php?f=93&t=107154
