Post new topic Reply to topic  [ 104 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7  Next
 Post subject: Re: 66cc Big Bore experience
PostPosted: Wed Oct 02, 2013 5:59 pm
kennyb7988 wrote:
I bought that oil dipstick breather kit, hopefully that will relive some of the pressure. My BB is a older model engine that does not have the vent for the PCV valve. Maybe I should install one of those to.
Jedi what "big car" did you install? I have a PC20 did you go PE or some other carb type? just curiouse.
yes put in the chain tensioner breather
along with a cheap plastic pcv valve and filter making it only suck in air
ive personally seen those older ones rui crank bearings even at as low as 2500 miles
ive read if you dont have that valve change oil as often as 500 miles
PostPosted: Thu Oct 10, 2013 5:41 pm
Well i ordered that dip stick breather kit from Scooter Parts place two weeks ago. Got a email confirmation but no shipping info. Emailed asking what was up got no response. I knew they were a hit or miss place, was hopeing i would get lucky. Anyone know of a place that sells this that will actually send it to me. IDK why that fucking place even stays open if it never fills orders. here is the part i am talking about, http://scooterpartsplace.com/head-breat ... 6-150.aspx
Thanks
KB
Kennybs Build Thread
viewtopic.php?f=94&t=70880&p=1227631#p1227631
PostPosted: Thu Oct 10, 2013 6:06 pm
http://www.shop.theruckshop.com/NCY-Oil ... 0-1282.htm
ruck1built
Quality. Custom. Fabrication.
Z125 Crew
PostPosted: Thu Oct 10, 2013 6:17 pm
AWESOME, thank you
Thanks
KB
PostPosted: Tue Oct 15, 2013 6:54 pm
Got the oil dipstick vent today. Hooked it up started it and when I go full throttle it spits oil out of the oil dipstick vent hose. I am guessing this is not supposed to happen?
Thanks
KB
PostPosted: Tue Oct 15, 2013 7:42 pm
yes its supposed to happen
thats the venting
which is why you run a line out of that up high, you might be able to get away with a filter
but it could get soaked in oil, so you may need an oil catch can
PostPosted: Tue Oct 15, 2013 8:33 pm
There is a line on it. Its prob 2.5ft long
Thanks
KB
PostPosted: Tue Oct 15, 2013 8:42 pm
and did you get a catch can?
you need to research more what extra parts you need before getting started
because now your going to have more expenses and wait time
catch can separates the oil and air
you will have to empty it once in a while whatever oil it holds
put back in the engine
a temp solution could be like 5 feet of hose coiled under the seat
hopefully it will trap enough oil not to blow out
and when the bike is off it may drain back in just depends on the angle and how much pressure is blowing out
PostPosted: Wed Oct 16, 2013 1:33 pm
I know what a catch can is and what it does. This part was rec commended by another member that put one on his GET. He said he connects the line to the frame, no mention of a catch can. In fact I have never seen a catch can on a GET motor. That is why I asked the question. Not because I don't know what one is! Seems like there is something up with this motor because there shouldn't be this much pressure build up. But maybe I am wrong up.
Thanks
KB
PostPosted: Wed Oct 16, 2013 1:57 pm
well you do realize its a big bore now correct
so your building up more pressure
If you run the hose in the frame thats fine too, as long as your not blowing out oil
you are so you need a catch can, or you have problems with the engine level or breathing
is your engine at the correct level, what are you doing with the breather hose on the head
and what year engine is it
does it have the timing chain tensioner breather valve
PostPosted: Wed Oct 16, 2013 3:45 pm
I don't know the year, it came from Standard Functions. It does not have the cam tensioner breather but I have one in the mail. The head vent tube hangs down and is pointed toward the ground.
Thanks
KB
PostPosted: Wed Oct 16, 2013 4:10 pm
is the head tube leaking oil too?
and you know when you get the breather you need to use a pcv valve and filter it right
PostPosted: Wed Oct 16, 2013 5:11 pm
The head vent tube is where the leak started. I didn't check it when I ran the venues dipstick I was to focused on watching the tube.
My old engine was a 09 so I have the PVC valve and filter from that.
Thanks
KB
PostPosted: Wed Oct 16, 2013 8:13 pm
ok make sure when sitting on the bike the engine sits level
if the head is facing down, it helps push out oil
run a long line off the head then at first
see if the leaks stop
then if that length works you could hide it all in the frame
just try different lengths and try to mount the hose upwards
so any oil that sits can drain back into the engine
worse case tie both lines into a catch can
you can make your own if your on a budget out of stuff laying around
PostPosted: Mon Mar 17, 2014 8:33 am
bump for updates. How did everything turn out Kenny?
I'm thinking of going BB and I'm doing research in the meanwhile to learn as much as I can before diving in.
