Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Let's discuss how to get more top speed...
PostPosted: Wed Sep 05, 2012 4:16 am
GETSlim wrote:
this guy doesn't even own a Ruckus anymore...
what does HE know??
Enough to kick your ass!!! :army:
TRIGGER COAST ROLLERS
T.W.o.T MkII - PARTED
PostPosted: Tue May 14, 2013 6:16 pm
racerx wrote:
papajoe. You still have no idea what rpm's your hitting, just know your not hitting rev limiter right? I suggest a tach for tuning purposes. Higher rpm's will mean higher top speeds (usually). It may be time to try a different variator. If you were wise enough to get the wide band for carb tuning the tach seems a small expense for proper gear tuning. :meh: If you can't reach 10,500rpm with your current set up the Met gears will just make it even more difficult to reach current speeds.
hmm.. good point. So at max throttle... it just purrs along (sounds like a single prop airplane)... no bouncing off a limter.
I have a Vapor tach, but RPM readings flip out after 7-8k rpm. Strange because my other ruck has the same thing, wired the same way, and reads all the way to 10k+ rpm.
I also read that I should plug the Pair valve(?) on the valve cover when I read wideband. I didnt... just had it vented w/ a filter on it.
I also picked up am unlimited CDI, so I'll try that too...
Overall, its still fine for commute... but its always fun to go faster... :o)
Acceleration feels very good for a GET.
PostPosted: Thu May 30, 2013 10:43 am
pair valve is not on the valve cover. Its on the left bottom side of the head.
08 Metro- 64/58 club :banger:
viewtopic.php?f=92&t=63326
09 Metruck- SOLD
viewtopic.php?f=92&t=79193
ConElite for Mod 2016!!!!
PostPosted: Sun Jul 13, 2014 6:19 pm
so instead of making a whole new post......what can I do to get the most out of my stock GET engine?
PostPosted: Tue Aug 12, 2014 8:00 am
You can read. And by reading you would realize your in the Big bore section. Not the stock bore section.
09 Metruck- SOLD
