 Post subject: Big bore piston ring instructions
PostPosted: Tue Feb 23, 2010 10:23 pm
Taken from the Big Bore building thread over at ruckuscentral: http://battlescooter.proboards.com/inde ... 586&page=7
On this picture are the two thick rings (courtesy of android):
So the order is:
Ring 1 goes first - on top of the piston - closest to the cylinder head - with side B up
Ring 2 goes second with side A up
The ruckus manual and instructions that came with the wiseco piston differ in the way you should stagger the ring gaps for the two top rings (both manuals are the same for the bottom three rings).
So i just went with the wiseco piston instructions, and you place the top ring gap (as looking at the piston with the intake side up) to the 3 o'clock position, second ring gap - 9 o'cl0ck position, top oil thin ring - around 2 o'clock, oil wavy ring - 6 o'clock, and bottom oil thin ring - around 10 o'clock.
Thanks to Varroa for compiling the info .
 Post subject: Re: Big bore piston ring instructions
PostPosted: Thu Feb 25, 2010 2:25 am
hey maybe it makes sense to post a thread in "how-to" section with a link to this thread?
Blackruk wrote:
Sooo . . . who wants to sue somebody? :lol:
PostPosted: Thu Feb 25, 2010 9:44 pm
Done mang . Are you feelin' the power ? :canuck:
PostPosted: Fri Feb 26, 2010 12:16 am
i definitely am. at half throttle i got more power than i ever had with stock engine at full throttle.
PostPosted: Sun Feb 28, 2010 10:42 pm
How did you end up putting the rings?
PostPosted: Mon Mar 01, 2010 1:35 am
is that correct?
PostPosted: Tue Mar 02, 2010 1:02 am
Oh I was meaning did you put the notch in the top ring up?
PostPosted: Tue Mar 02, 2010 3:30 am
i put the "step" side of the ring down, as per chanito's recommendations.
PostPosted: Tue Mar 02, 2010 12:03 pm
What rollers/sliders are you using V ?
PostPosted: Wed Mar 03, 2010 12:48 am
worn out stock metropolitan weights. which reminds me: i need to order rollers and a belt. thanks.
