Post new topic Reply to topic  [ 219 posts ]  Go to page 1, 2, 3, 4, 5 ... 15  Next
 Post subject: Kitaco CDi for FI Zoomer
PostPosted: Fri Sep 25, 2009 3:31 am
Anyone tried one?
Kitaco CDI - Zoomer FI
Welsh and Proud
Bishop's Mods
My other ride has tits!!!
 Post subject: Re: Kitaco CDi for FI Zoomer
PostPosted: Fri Sep 25, 2009 7:03 am
no, but quite interested...
PostPosted: Fri Sep 25, 2009 8:37 am
Yeah that's the one i have. quite good. You have to tweak it alot to get the best fuel air ratio on the i-map depending on your setup. Probably best to put it on a dyno for best results but i'm cheap and trial and error works good for me :wink:
viewtopic.php?f=94&t=35850
PostPosted: Fri Sep 25, 2009 8:40 am
p.s there are 2 parts to it.
1) the actual cdi that maps in the battery box (much tidier and safer than the polini)
2) the imap to tune settings that relay back to the cdi
PostPosted: Fri Sep 25, 2009 9:04 am
what kinda gains do you get from it over the polini?
My Ride 2T in progress
PostPosted: Fri Sep 25, 2009 9:56 am
Not wanting to speak out of turn...but...
Think Polini only removes rev limiter, Kitaco does this (three different maximum rev settings), then with the USB unit allows fuel injection levels to be altered (+/- 40%) to tune engine further when combined with lighter roller weights.
PostPosted: Fri Sep 25, 2009 10:17 am
so you could tune each of the 3 max rev settings to 3 different injection levels? one for eco, one for straight roads and one for drag? or am i way off :D
PostPosted: Fri Sep 25, 2009 10:19 am
3 pre-set rev levels (with no fuel adjustment) - stock, 10k (I think) and 12k (from memory), then 4th option (if you have the USB link) to set rev limit (up to 15k I think) and alter fuel injection as mentioned.
PostPosted: Fri Sep 25, 2009 10:23 am
This is not true, the polini increases the rev limit from somewhere around 8K to somewhere around 10k.
The book says (7800 > 9800).
White fatty EFI-GET Ruckus
Please check out our Webshop and Facebook page!
PostPosted: Fri Sep 25, 2009 10:29 am
True, but moving rev limit to 9800 is the same as removing it completely.
(Here we go...the world and his dog are now going to post saying how they have exceeded 10k revs, whilst riding up a steep hill, doing 50mph, without a polini CDI (max revs 9.8k apparently) and with 7X8g rollers in their stock variator)
PostPosted: Fri Sep 25, 2009 11:03 am
No.. But when I duck on a flat piece of road, or go a bit downhill I do hit the rev limiter at a little over 10k rpm according to my Vapor..
PostPosted: Fri Sep 25, 2009 11:05 am
just like I said..... :wink:
PostPosted: Fri Sep 25, 2009 11:24 am
You don't have to believe me..
Hate me if you like :) MR = Max revs
PostPosted: Fri Sep 25, 2009 11:27 am
:clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap:
PostPosted: Fri Sep 25, 2009 12:10 pm
so you can just install the cdi and dont have to use the imap? (only if you big bore to get full potential) would be nice to try something new ive noticed tokyoparts are doing more stuff for the FI models now, would be good to see more FI mods wander how its guna go :D
