 Post subject: GET Kymco hub caps
PostPosted: Wed Jan 27, 2016 1:53 pm
These were made to cover kymco hubs when using douglas wheels. I have two styles to match the frame caps I already have out,Dome and Spike.
Hub caps are $60 shipped in the US and include paypal fees. Message me with any questions pay pal chrystian5030@gmail.com ImageImageImageImage
2011 Ruckus
 Post subject: Re: GET Kymco hub caps
PostPosted: Wed Jan 27, 2016 2:24 pm
Does it install from the back side? I like it a lot(jim carey voice). How likely is it to fall out? Can I get a diameter measurement? I have a 12x5 wheel (with an actual factory 4x140 bolt pattern) that is most likely a douglas but it has no markings on it. Thanks
TT-350z wrote:
Build Thread
PostPosted: Wed Jan 27, 2016 2:30 pm
They fit in very tight with an oring and it will not fit if your hub didn't need to be machined to be hub centric. I will still get you the diameter in a few hours when I'm get back in.
2011 Ruckus
PostPosted: Wed Jan 27, 2016 2:54 pm
Those are nice looking :banger: bet they'll be popular
PostPosted: Wed Jan 27, 2016 6:00 pm
So then these will only work with mojo hubs only?
Build Thread
PostPosted: Wed Jan 27, 2016 8:26 pm
Yes, if your hub fit the wheels hub bore without the hub being modified then this cover will not work. It only works for mojo type hubs. They are the most popular setups for GET rear wheels. I will PM you the diameter tomorrow.
2011 Ruckus
PostPosted: Wed Jan 27, 2016 8:27 pm
Thank you.
2011 Ruckus
PostPosted: Fri Feb 05, 2016 11:59 am
You should check and give people specs.
The 4/137 and the 4/144 wheels have different Center bore sizes.
BTW: Pretty nice covers.
08 Metro- 64/58 club :banger:
viewtopic.php?f=92&t=63326
09 Metruck- SOLD
viewtopic.php?f=92&t=79193
ConElite for Mod 2016!!!!
PostPosted: Fri Mar 04, 2016 2:12 am
received mine looks awesome
My first build
PostPosted: Mon Mar 13, 2017 9:00 pm
Hub caps are on sale $40 shipped. If you're unsure if this will fit your application please message me. They were made using Douglas red label 12x8 and 12x7 wheels and a modified mojo hub.
Thank you.
2011 Ruckus
