Post new topic Reply to topic  [ 154 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10, 11  Next
 Post subject: Re: Met Stretch Kits For Sale
PostPosted: Fri Mar 06, 2015 7:56 am
Well I had the week off because I was sick, so I spent some time every day to finish the stretches
I have a small amount up for sale check first post for info
PostPosted: Sat Mar 28, 2015 9:45 am
8)
PostPosted: Sat May 23, 2015 6:35 am
only 2 left for sale
PostPosted: Wed Jun 03, 2015 1:24 pm
are the 2 kits available for standard wheel or fatty?
My '03 Ruckus Build
TractionOptional.com
PostPosted: Wed Jun 03, 2015 3:54 pm
sold the last two the other day
PostPosted: Thu Jun 04, 2015 7:55 am
My '03 Ruckus Build
 Post subject: Re: !New! Met Stretch Kits With Fatty Upgrade Option
PostPosted: Mon Jun 08, 2015 4:38 pm
Mike155cc wrote:
Mike,
Did you have to bend the exhaust header (or cut and weld it) to fit the fatty with the stock exhaust or did you just add spacers where it mounts to the case next to the radiator? I know it's a chopped exhaust but same method should be fine with a stock length one I assume. Thanks.
2012 Ruckus: viewtopic.php?f=92&t=88609
2003 Ruckus Barn Find: viewtopic.php?f=92&t=93209
2004 Met:
viewtopic.php?f=4&t=89879[/color]
PostPosted: Mon Jun 08, 2015 4:50 pm
if you look closely you can see I added like 4 inches of straight pipe right past the bend where it comes out the engine
this kicks it away from hitting the wheel
thats the only weld you need
then where it bolts to the engine I used very long bolts and tubing to make spacers and to allow it to tighten down
no bending or anything needed
few people have sent me an exhaust to mod to fit the fatty, and shorten at the same time which I can do just ship one to me
I dont have any laying around
PostPosted: Thu Jun 11, 2015 10:30 am
Thanks, man. will definitely get back to you when it's time for the fatty. Much appreciated.
2004 Met:
PostPosted: Thu Jul 09, 2015 7:58 am
Would you happen to have any kits for just an eye to eye shock and ruck swing arm, no stretch???
PostPosted: Thu Jul 09, 2015 8:48 am
I have nothing left for stretches
any suspension parts I can still fab up easily
as for doing an eye to eye adapter
its possible, but I would need some more info on the shock
I never had to make a shock mount for that type yet
the length of the shock is important
it cant be too much shorter then the met shock without a total redesign of my shock mounts
PostPosted: Thu Jul 09, 2015 9:01 am
It is a Doppler style air shock.
I can get you the measurements later today.
What really after is the top and bottom mounts as I'm only doing a ruck swing, no stretch.
If it may seem too difficult for the air shock, I do still have the stock met shock and I can buy the kitaco met shock to use.
PostPosted: Thu Jul 09, 2015 11:00 am
yes I can make the top and bottom mounts no problem (for typical met shock)
I have metal here I can do that
just pm me the info
I need overall length
compressed length
and how wide the shock ends are
PostPosted: Tue Jul 14, 2015 6:46 pm
is it possible for you to make and eye to eye adapter for an air shock for a get :canuck:
Ruck build
viewtopic.php?f=92&t=81342
PostPosted: Sat Oct 24, 2015 8:32 am
Im starting the met stretches again im almost finished they will be ready for sale very shortly
I have redesigned the shock mounts, which will make it super easy now to mount the met shock to my kit.
example
I still send the shock mounts long, so you have a couple inches on both ends if you want to lower the bike
that way you choose the height you want
